Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 11-09-2006, 08:53 PM   #1
TwrxZ
Member#: 110868
02 bugeye
stage 2
Default GM Boost Control Solenoid
ok i have 02 wrx full tbe/up/dp/no cats. i am thinking about buying the xpt stage 2 map. but there is an option of GM Boost Control Solenoid tuned version.......questions.......
1. what exatly is this GM Boost Control Solenoid? i know it replaces old one and help with target boost. other then that idk.
2. is is good with stage 2 tuned cars? will it over boost and if i get it what help will it give me?
3. whats everyones feed back who has it?
thanks guys SORRY for being a noob.
ps i did try and search i just found a write up on how to install and fix boosting prob with them.
TwrxZ is offline   Reply With Quote
Old 11-24-2006, 08:24 AM   #2
subaruwrx420
Member#: 80939
The GM solenoid is a three port unit versus the stocker that is bleed type system (two ports). It allows for more accurate boost control and quicker spool but you must be able to tune for it. That is, if you flash a map that was made to work with the stock soleniod but you have a GM unit, then you'll most likely boost spike.
I say the GM unit is good for any staged car, unless you have some crazy set up...my buddy ran it with his Stage II car without issue. But again, he tuned for it and was able to control boost better and spool sooner.
I have one on my car now and love it. Make sure you look around for a good price on it because I went to the GM dealer to purchase it along with the necessary pigtails connector and later found out that I over paid. Otherwise, it works great...I soldered it to my stock wiring and installed it per the instructions you found.
Hope that helps.
subaruwrx420 is offline   Reply With Quote
Old 11-24-2006, 08:35 AM   #3
TheMadScientist
Member#: 23717
2005 Big red
Hope that helps.
You don't need the conector. It costs all most as much as the solenoid.
TMS
TheMadScientist is offline   Reply With Quote
Old 11-24-2006, 09:23 AM   #4
subaruwrx420
Member#: 80939
^^Damn, I could have saved even more
Old 11-24-2006, 08:34 PM   #5
disque71
Member#: 57330
2008 WRX
i picked up the solenoid and pigtail for 26 buck shipped from rockauto.com
disque71 is offline   Reply With Quote
Old 11-29-2006, 05:19 PM   #6
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
I was having trouble finding this on rockauto.com . . any other site for a good deal ? ?
ALaDDiN is offline   Reply With Quote
Old 11-29-2006, 05:23 PM   #7
quazimoto
Member#: 70395
quazimoto is offline   Reply With Quote
Old 11-30-2006, 01:50 PM   #8
DieselClown
Member#: 36135
2005 WRX
I had a hard time looking through their stupid java based catolog too but it's there. check the following part numbers (courtesy of disque71)
ACDELCO solenoid part # 214474(notes GM part number 1997152)
ACDELCO ABS modulator pigtale part # PT374 (notes GM part number 12102747)
If you check under the ACDELCO part #'s, it should come right up.
used this discount code: 508020134918
for 5% off purchase
DieselClown is offline   Reply With Quote
Old 11-30-2006, 02:47 PM   #9
Turbo_Mike
Member#: 130276
2004 Pontiac GTO
LS1 T56 RWD
I'm using the perrin one. Pretty much the same thing as the GM version, just a lot more expensive. Expect to use 40% less duty cycle to hit the same boost, and it can hold boost at high RPM's waaay better than the stock unit.
Turbo_Mike is offline   Reply With Quote
Old 12-01-2006, 11:36 PM   #10
Freon
Member#: 88322
2009 BMW 135i
Freon is offline   Reply With Quote
FS: GM BCS boost, GM Boost Control Solenoid WILLFUTHEGREAT Engine/Power/Exhaust 12 04-20-2009 03:06 PM
FS: APS 65mm CAI, GM boost control solenoid & OEM boost control solenoid roninsoldier83 Engine/Power/Exhaust 9 10-31-2007 07:56 PM
fs: $35 shipped NEW GM Boost Control Solenoid BCS + GM pig tail wiring fastwrx25 Engine/Power/Exhaust 19 08-14-2007 08:29 AM
GM boost control solenoid Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-09-2006 01:42 PM
FS: GM Boost Control Solenoid and Harness BigBoosting Private 'For Sale' Classifieds 0 11-10-2005 01:56 PM
