Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 11-09-2006, 11:29 PM   #1
blueribbon
Member#: 22668
2006 AE86 Levin it
NA1
Default UTEC on JDM V7
My setup is EJ257 bottom end with JDM V7 heads running stock JDM V7 ecu.
I was wondering if a UTEC that was on a wrx would work with my setup?
Thanks
Mike
blueribbon is offline   Reply With Quote
Old 11-10-2006, 04:15 PM   #2
cegpcola
Member#: 97987
The Wagon shaped
paper weight
According to the guys at TurboXS when I called on the same setup yesterday, Yes it will work. But you will have a CEL for the fuel injectors. The new Delta system will work without throwing the CEL, but either will do the trick. If you are like myself and live in an area that does not perform emissions checks, just use the old Utec. If you have to pass emissions though, I would sell the old UTEC and by the Delta. I hope this helps!
cegpcola is offline   Reply With Quote
Old 11-10-2006, 06:08 PM   #3
blueribbon
Member#: 22668
2006 AE86 Levin it
NA1
Cool thanks.
If I use the old UTEC would I still retain my avcs?
Mike
Old 11-10-2006, 06:20 PM   #4
cegpcola
Member#: 97987
The Wagon shaped
paper weight
Yes. From What I understand, The UTEC will not control anything with AVCS. So the Wires going to and from the ECU to AVCS Control simply get routed through the UTEC, but with unaltered signals. The only problem is a CEL that has something to do with the injector voltage to low.
USDM Exhaust on JDM V7 STI Swap? Zaider Subaru Conversions 2 10-21-2009 05:59 PM
utec for jdm v7/v8 f4ej267 Engine/Power/Exhaust 0 08-09-2008 01:53 PM
what is weight on jdm v7 sti rims? PolePosition08 Tire & Wheel 3 05-18-2005 07:42 AM
question on JDM V7 / V8 and USDM STi V6 Subaru Conversions 1 05-14-2005 03:06 AM
utec on jdm motor phatroksek Engine Management & Tuning 6 01-06-2004 10:01 AM
