Old 11-10-2006, 02:25 AM   #1
benw
Member#: 103320
1998 swapped
Forester L
Default Pump Failure People... did you damage anything?
For those of you who have had a pump die, did it do any damage to the motor? Please describe what tipped you off that the pump was dead and how it happened. I'm wondering if a single tiny LED is going to be my only indication, or if the power drop-off will be noticeable as well.
benw is offline   Reply With Quote
Old 11-11-2006, 12:23 AM   #2
PolarisSnT
Member#: 85905
2004 WRX
Hasnt happened to me but if your tune is agressive with the alcohol on and the pump fails than catastrophic engine failure will happen. If the tune isnt so agressive and it fails, well you might get away with it. You would get a tone of knock and your CEL would flash, plus the car would fall on its face it this happens.
PolarisSnT is offline   Reply With Quote
Old 11-15-2006, 11:06 AM   #3
Brian-ATL
Member#: 106011
2005 WRX STi
I was going thru meth super fast. I used the test button while parked and saw the meth leaking from the pump. Didn't cause any issues for me.
Brian-ATL is offline   Reply With Quote
Old 11-15-2006, 11:14 AM   #4
FNR32
Member#: 84147
03 WRX
Ive had a friend whos pump failed two times, both times he was just driving mildly to work and back and had no failure ( it's an evo but still). Rumor has it a certain type of meth ruins the seal and casues the failure. Don't know how true that is, but since he has switched brands he never had failure again.
FNR32 is offline   Reply With Quote
Old 11-15-2006, 02:30 PM   #5
PolarisSnT
Member#: 85905
2004 WRX
Well post up the names cause Id like to know if Im in danger. I run 100% denatured alcohol.
Old 11-24-2006, 01:51 PM   #6
chibich
Member#: 79134
2004 STI
bump. I want to get meth injection but I am afraid of this happening, so i would love to hear what other people have to say.
chibich is offline   Reply With Quote
Old 11-24-2006, 04:58 PM   #7
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
I have had two pumps fail on me. Both were from Snow Performance. The first one I knew it had failed, because I was getting knock, for seemingly no reason, so I hooked up a test/prime switch, and turned on the pump and it didn't do anything. Next pump just failed the other day. I had ordered a pump from cooling mist since they rate their pumps for meth. I was going to replumb my system in the next week or so, to use shorter hose runs, to retain a little more pressure. So driving around, and the car would run fine in
1,2,3 gears, but knock in 4th under boost. So I think the pump was on it's last leg, and couldn't push back the boost pressure, so I don't think mix was even getting to the nozzle. So put the cooling mist pump in, and waddaya know, I got some response and torque back I had been missing and not really noticed, and no more knock. This I can say if you do get a system, get a good safeguard. Also put a test/prime switch in. It is easy to wire. Just hook the switch up to a 12V power source, and then to the pump power wire. Everything will run normally, and your controller will still work. The controller doesn't apply power to the pump until it reaches the right boost pressure and turns on the pump. So the switch is just another way of sending power done the line to turn it on. Splice the switch in between the pump and controller, on the wire that the controller sends voltage to the pump with.
By the way, no engine damage that I can tell. I really pay attention to my safeguards, and CEL when I drive it. That is part of the game, yes alky is kinda risky, but if you are not willing to invest the money in a good safeguard system, and be attentive when you drive it, you are asking for trouble.
DP
DonkeyPunch is offline   Reply With Quote
Old 11-25-2006, 11:40 AM   #8
benw
Member#: 103320
1998 swapped
Forester L
thanks DP that is a good post.
I'll be running the Coolingmist 150 psi pump on 50-50 and will definitely use a test switch.
Old 11-25-2006, 02:30 PM   #9
kn0bby8
Member#: 97644
2006 WRX
Maybe a stupid question but how are you gonna know you are actually spraying when you hit the test button. Also, I don't think you can just spray when your at idle.
kn0bby8 is offline   Reply With Quote
Old 11-25-2006, 07:02 PM   #10
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Do you have a LED to indicate when your pump is running. Usually there is a wire running out of your controller to hook to your LED. Usually it is just the power wire from the controller to the pump. You splice the pump in there. I also have 1/4" push to connect union in the middle of my supply line running from the pump to the injector that I can take the supply line apart to see if it is actually moving liquid.
Here are the fittings I am talking about:
http://www.fastenal.com/web/products...l.ex?sku=68424
With the LED and union, you can tell that your pump is healthy
DP
Old 11-26-2006, 12:23 AM   #11
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
I occasionally hit the test button on my controller while idling in the driveway....you can hear the engine bog a bit and smell the alcohol. Between doing that and visually inspecting the pump I feel very comfortable w/my system (SMC).
I had a pump issue once. Two of the screws holding the pump body together worked themselves loose and alcohol/water sprayed my engine bay. Realized it on the first boosted pull in 4th (UTEC flashed the CEL indicating knock), pulled over and checked the engine, went home and Loctited the screws in question and it's been fine for nearing 15,000 miles since.
As someone else mentioned.....you need to be VERY diligent in your maintenance/inspection. But IMHO it's an amazing modification w/regard to its benefits.
mindchatter is offline   Reply With Quote
Old 12-18-2006, 09:23 PM   #12
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Interested in pump failures and brands.
silver arrow is offline   Reply With Quote
Old 12-19-2006, 04:43 PM   #13
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
I have had two snow pumps fail on me in the span of about a year. I am now running a coolingmist pump. If this pump should happen to fail, I am going to aquamist.
Did I damage anything? The Blue Pilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-26-2005 07:23 PM
'stage 1' reflash people. did you feel the gains with just a reflash? DoctorNick Forester Forum 16 04-09-2005 06:50 PM
How many people did you call right after midnight? DrBiggly Off-Topic 24 01-02-2004 11:26 AM
Uppipe/downpipe/header people- did you pass emissions? Lightning Jack Newbies & FAQs 0 03-31-2003 09:27 AM
So did you learn anything in your first year at college? StuBeck Off-Topic 28 02-28-2003 11:38 AM
