Old 11-10-2006, 09:52 AM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default for reference, my latest ign. map
first, the table:
and a nice graph:
overall ignition correction is set to 10*, so add 10 to the entirety of the map. afrs at peak load are 11.7.
something recent that you may notice is the skewing of the load references to provide more granularity in the 2.5-4.5 g range. so far it's worked very well. i'm in the process of doing that to my fuel map also.
ken
Old 11-10-2006, 01:38 PM   #2
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
I would really like to know how to use EcuEdit...I can't understand how it works when I load up my map it asks for a def. file, etc.
Is there a tutorial somewhere?
akira02rex is offline   Reply With Quote
Old 11-10-2006, 01:49 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the easiest thing to do is grab a copy of xmlwrite, and use that to create a def file. the xmlwrite readme will describe its use.
then install ecuedit.
then put the xmlwrite-generated def file in the xmldefs subdirectory of ecuedit's install folder.
then run ecuedit, and open your .hex image file.
Old 11-10-2006, 03:19 PM   #4
Bolster
Member#: 22290
2002 WRB WRX Wagon
Excuse my ignorance here: What do the values in the cells in the top image represent? They are too low, I would think, to be timing (there's now way you're only running 6.37 degrees at 7000 rpm).
Bolster is offline   Reply With Quote
Old 11-10-2006, 03:51 PM   #5
Airboy
Member#: 72829
2006 WRX
2015 WRX
Check the line right below the image....
Airboy is online now   Reply With Quote
Old 11-10-2006, 10:00 PM   #6
Bolster
Member#: 22290
2002 WRB WRX Wagon
Ahh, that makes sense now.
Old 11-10-2006, 11:44 PM   #7
Gethin
Member#: 2998
Yeah having the whole ignition correction map at 10 makes it easy to spot where the ECU is pulling some timing.....just look at the log files, and look for where the KC value is not 10 ! I'm running a 10's map too.
Gethin is offline   Reply With Quote
Old 11-11-2006, 07:55 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
as a next step i'm going to plot out some oem ecu ign maps. i'm trying to discern a pattern of map "shape" across different platforms to see if we can make some generalizations. ecuedit's inherent graphic capacity makes it much easier to visualize these kinds of things. i'll probably ante up the money and buy a full version soon.
Old 11-12-2006, 10:59 PM   #9
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
Yeah, the uniform KC value across the entire map is a good idea. As pointed out before, it's really easy to spot where the ECU is pulling timing. You just have to do your homework on the base map and get the values right. Are you actually seeing engine loads above 5?
Ziggyrama is offline   Reply With Quote
Old 11-12-2006, 11:24 PM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i see engine loads of almost 7. a 5g load is around the 15psi boost range for me. 7g (well, 6.75) takes 25psi. i've got a thread on that subject here: http://forums.nasioc.com/forums/show....php?t=1099390
i am still running the stock airbox, stock maf tube, stock maf sensor, stock maf translation table. some addl. info here: http://forums.nasioc.com/forums/show....php?t=1118038
from what i've found, i have a feeling the vf23 is an unparalleled midrange performer due to its comparatively "exhaust heavy" flow balance. see also: http://forums.nasioc.com/forums/showthread.php?t=299097
ken
Old 11-13-2006, 09:29 AM   #11
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
How does the VF23's P20 exhaust side compare to my Big16g's TD05?
Is it bigger and more similar to a TD06?
Old 11-13-2006, 10:34 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i think it is closer to a td06 flow wise. this is from what i've picked up on some british bbses (22b.com, scoobynet).
it's very hard to directly compare the p's to the td's because the ihi "way of doing things" seems to go with a very large, free flowing housing paired with a smaller, tighter turbine wheel. the mhi "way of doing things" tends towards a smaller housing with a bigger wheel packed inside.
ken
Old 11-13-2006, 10:47 AM   #13
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
I want to know how a td06-16g will perform then.
Old 11-22-2006, 10:14 PM   #14
crazymikie
Member#: 56321
2006 Honda El Camino
Green
You could pick up an 8cm housing and see how that works out for you.
I am planning on doing that after I get my EGBP gauge installed
I'd like to do some comparisons before and after.
Mike
crazymikie is offline   Reply With Quote
Old 11-29-2006, 05:42 AM   #15
MRF582
Member#: 48219
. Always drive
the race line .
Mike
Sweet. Eagerly awaiting data.
MRF582 is offline   Reply With Quote
Old 01-10-2007, 01:49 PM   #16
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Dead images.
jblaine is offline   Reply With Quote
Old 01-10-2007, 02:09 PM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
issue with webhost, jeff... give it a little while.
Old 01-10-2007, 03:13 PM   #18
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
i made a rough draft 10KC map. Around my 800rpm and >2.0 Load, my total Base + KC is less than 10. If i set my KC to 10, then i would have a -value for my Base Ignition Timing. Is it ok to do that as long as my total ignition timing is the same?
druxboyz is offline   Reply With Quote
Old 01-10-2007, 04:22 PM   #19
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Yes, it is ok to have a neg timing value in the base map. You could actually run a negative value for total timing. It would just mean that your spark is AFTER TDC.
blkscooby is offline   Reply With Quote
Old 01-10-2007, 06:29 PM   #20
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Ken, your timing map is 99% identical to mine.
Old 01-11-2007, 08:48 AM   #21
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i'll have to change that right away then.
Old 01-12-2007, 04:45 AM   #22
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
that is damn smooth. Stock total timing is lumpy though, yours runs well like that? what are your mods?
Old 01-12-2007, 08:58 AM   #23
blkscooby
Member#: 44422
2009 G8 GT
Search my noob friend. You will find that Ride5000 has probably one of the fastest, self built, self tuned, low budget WRXs around. Oh yeah, and he knows his s**t.
Old 01-12-2007, 01:08 PM   #24
MRF582
Member#: 48219
. Always drive
the race line .
^^ +1
Old 01-12-2007, 02:21 PM   #25
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
yea, i know he knows his ****. i've read plenty of his posts. i also believe that its possible that he has added something or taken something out since he last posted his mods. Is it wrong for me to ask what his CURRENT mods are?
Morning nasioc people just like to read and write/chat to others anyway. Just like in real life, if you go to a meet and walk up to a guy that has his hood popped, is it wrong to ask him what he has under the hood to spark a conversation? Or would it be a bit rude of him to say "search under my hood, my noob friend, its right in front of you."
Also, free bump for his reference thread, that's always a friendly gesture.
My Latest battle with my Subaru Dealership..(Long) wrxsti Canada Region Forum 29 07-19-2013 10:11 PM
Latest Eclipse map DVD? wobbletop Car Audio, Video & Security 2 12-06-2005 08:49 PM
My Latest Mod and my car turns 100K today! Firewire Vancouver Impreza Club Forum -- VIC 2 04-12-2005 11:10 PM
My latest and last pics for a while. supermarkus North West Impreza Club Forum -- NWIC 10 09-01-2004 06:13 PM
My latest battle with my Subaru Dealership (long) wrxsti General Forum Archive 21 07-13-2000 11:03 AM
