Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 11-10-2006, 10:11 AM   #1
NYCshopper
Member#: 5126
Default Test Drive: 2007 Chevrolet Tahoe LT 4WD (CanadianDriver.com)
http://www.canadiandriver.com/testdrives/07tahoe-lt.htm
Introduced early in 2006 as a 2007 model, the full-size Tahoe SUV continues to evolve into a more 'car-like' and less 'truck-like' vehicle (even though it is based on a body-on-frame truck chassis).
The new Tahoe's smoother, more aerodynamic exterior styling, classier, better-finished interior, and quieter, more comfortable cabin, signal a move away from its rough truck heritage.
Yet, it would be wrong to say that the new Tahoe is less capable as a truck: for 2007, it offers a stronger frame, more horsepower, improved handling, better steering, a higher payload capacity, more cargo room, and even better fuel economy with the 5.3-litre V8 engine thanks to a new cylinder deactivation system.
However, the Tahoe's curb weight, which was already pretty hefty in 2006, has increased for 2007. The 2007 Tahoe 2WD's base curb weight has risen by 130 kg (287 lbs) to 2374 kg (5265 lb). The 2007 Tahoe 4WD is 142 kg (314 lb) heavier, with a curb weight of 2512 kg (5524 lb).
Despite this weight gain, fuel economy has improved when equipped with the 5.3-litre V8 (standard on 2WD Tahoes) and the optional 5.3-litre 'flex-fuel' (ethanol-capable) V8 engine (standard on 4WD models). The reason is the addition of Active Fuel Management (AFM) to both 5.3-litre engines. This automatic cylinder deactivation system allows the engine to run on only four cylinders when coasting or under light load situations, thereby saving fuel.
With the new 5.3-litre V8 flex-fuel engine running on gasoline, the official average (combined) fuel economy rating for a 2007 2WD Tahoe is 12.8 L/100 km (22 mpg Imp.). That's a significant improvement over last year's 14.4 L/100 km (20 mpg) for 2WD Tahoes without AFM. 2007 4WD models with the 5.3-litre flex-fuel engine average 13.1 L/100 km (22 mpg Imp.) compared to 15.1 L/100 km (19 mpg Imp) in 2006. As you will soon see though, real-world fuel consumption is considerably higher.
A 4.8-litre V8 engine without Active Fuel Management became available in August, and its published fuel consumption is about the same as the previous 4.8-litre engine, averaging 13.3 L/100 km. You can order this engine on 2WD models for $1,125 less than a 5.3 model.
It's interesting to note that the new 5.3-litre V8 engines with AFM get better fuel economy than the 4.8-litre powerplant.
However, when using E85 fuel (85% ethanol, 15% gasoline) in the 5.3-litre V8 flex-fuel engine, fuel consumption increases dramatically, averaging 17.2 L/100 km (2WD) and 17.6 L/100 km (4WD). This is because ethanol doesn't have as much energy per litre as gasoline does and burns less efficiently. The upside is that ethanol is made from domestically grown corn and other crops which can help make North America less dependent on foreign oil. Currently however, there are very few E85 filling stations in Canada.
Interestingly, Chevy will be introducing a new 'Two-mode Hybrid' Tahoe in 2008 that should get much better fuel economy.
In terms of its size, the 2007 Tahoe has the same (2946 mm/116 in.) wheelbase as the 2006 model, but its overall length has increased by 81 mm (3.2 in.). Its width is about the same as its predecessor, but the track has been widened substantially: in front by 81 mm (3.2 in.) and at the rear by 26 mm (1.0 in.). In addition, the standard tire size is now 17-inch rather than 16-inch, and new 18-inch and 20-inch tires are now available. The Tahoe's wider track and larger tires combined with a new coil-over-shock independent front suspension provide more stability when cornering and noticeably improved handling and ride.
Another benefit of its stronger frame is increased payload capacity: 2WD models now have a maximum payload capacity of 832 kg (1835 lb) compared to 690 kg (1522 lb.) last year. The 2007 Tahoe 4WD now has a payload capacity of 806 kg (1776 lb.) compared to 721 kg (1590 lb) in 2006.
However, maximum towing capacities have dropped slightly from 2006. 2007 Tahoe 2WD models have a maximum towing capacity of 3402 kg (7500 lb) compared to 3493 kg (7700 lb) for 2006 models. 2007 Tahoe 4WD trucks can tow up to 3720 kg (8200 lb) vs 3810 kg (8400 lb) last year.
A trailer towing package is standard equipment on all Tahoes. It includes hitch platform, trailer receiver, seven-wire harness, and electric brake controller jumper harness.
As well, all Tahoes include a standard four-speed automatic transmission with a push-button 'Tow-Haul' mode that adjusts shifting points to accommodate a heavy trailer, and a standard transmission oil cooler.
Pricing and trim levels
For 2007, Tahoe 2WD and 4WD models come in LS and LT trim, while top-of-the-line LTZ models come in 4WD only. Base LS 2WD models start at $43,105 with the 4.8-litre V8 engine, and $44,230 with the 5.3-litre V8. Base LS 4WD models start at $47,450. Mid range LT Tahoes start at $45,580 (2WD) while the new LTZ 4WD Tahoe goes for $61,075.
My test vehicle, a mid level LT 4WD model had a base price of $48,525, but a host of options raised this price considerably. My loaded truck was equipped with $14,725 worth of options, and its as-tested price with Freight and A/C tax came to $64,590.
One of the biggest improvements to the Tahoe is its stylish new interior. It's much more car-like than the previous model, and better finished too. The attractive round gauges have a pleasant green/blue backlighting, and the dark dash plastic is relieved by generous amounts of wood trim on the dash, doors and central instrument panel. The centre-dash controls and bright-green displays are easy to see and use.
The Tahoe can be ordered with seating for six to nine persons, depending if you want bench seats or buckets. A three-person 40/20/40 split front bench seat with a folding centre armrest is standard, as is a second-row 60/40 split three-person bench seat with centre armrest. Optional are first and second row bucket seats (second row with folding inboard armrests), and a third row split bench seat that can be a two or three-seater, and is removeable and flippable. Seat heaters are available for the first and second row seats, and heater/A/C controls for the second row are also an option.
My test truck had two front bucket seats, two centre buckets and a two-person third row seat, for a total of six seats. I found the driver's seat comfortable on long drives and it includes adjustable height and lumbar support. A huge armrest/storage bin between the front seats is big enough to store a laptop. The second row buckets are also very comfortable with plenty of head and legroom, however I noticed that the second row windows only roll-down about half way. The third row seat is not very comfortable because of the raised floor, and there's very little cargo space behind it. If you want a third row seat with decent legroom, and adequate cargo space behind, I would recommend you buy the longer Suburban. However, if you only use the third row seat occasionally, and you need a vehicle that's easier to park, the Tahoe is the better bet.
Cargo room has been increased slightly in the 2007 Tahoe. One or both split third row seats can be tumbled forwards, or removed entirely, and the second row bucket seatbacks can be folded flat, leaving a flat surface that's big enough room to slide in a 4X8 sheet of building material.
I liked the remote key fob with a push-button tailgate opener and rear window opener. This solves the problem of having to fumble for the door latch while carrying grocery bags or other items.
The step up into the driver's seat is quite high (56 cm/22 in.), but my vehicle had running boards, a feature I'd recommend unless you're planning on off-road driving. LTZ models even offer running boards that automatically lower when you open the doors. The driver sits up high in the driver's seat and has good visibility, with the exception of the rear three-quarter view that is partly blocked by the second row head restraint.
My vehicle had optional leather seats which come as part of a $7,395 LT3 Preferred Equipment Group which also included tri-zone automatic climate control, power adjustable pedals, ultrasonic rear parking sensors, remote starter, MP3 compatible CD player, XM satellite radio, Bose speakers, universal remote, side curtain airbags, power heated folding mirrors with curb tilt, and ground illumination. My Tahoe also had the optional $2,915 Navigation system/radio with voice activation, and iPod auxiliary input jack. The navigation screen doubles as a touch screen for some radio functions, and it also functions as a rear-view camera display if you order that option.
A rear DVD player and screen is also available on LT and LTZ models.
Front airbags are standard but side curtain airbags are optional and seat mounted side airbags are not offered. On a vehicle in this price range, I think side and curtain airbags should be standard equipment.
I found the optional back-up sensors to be very useful when parking. A series of yellow and red lights at the rear of the cabin, and audible beeping tones tell the driver how close they are to an object behind the vehicle. Red lights and a continuous tone indicate the vehicle is only about 20 cm away from a solid object.
I also found the Tahoe's large side mirrors - the right one is convex for spotting cars in the blind spot - very handy. This is a big vehicle, and it's a good idea to know where other cars are around you.
Driving impressions
During the week that I had the Tahoe, I found myself continually surprised at how easy it was to drive. It may be smaller than a Suburban, but it's still a massive vehicle, particularly if you're driving downtown in busy traffic. Still, I found it relatively easy to manoeuvre and easy to park if I could find a big enough parking space. The steering is light and accurate, the visibility is pretty good (the back-up sensors really help), the engine has plenty of power, the brakes are very responsive, the transmission is smooth and responsive, the ride is comfortable, and the handling is quite stable. The cabin is surprisingly quiet, and of course very roomy.
Admittedly, the Tahoe seems to take up the whole lane that you're driving in, and from the look on other driver's faces, it appears to be very intimidating purely by virtue of its bulk, because it's not that bad looking. Being almost six and a half feet tall, the Tahoe looks like it's going to scrape the roof of some underground parking lots, and I found myself involuntarily ducking. And in a car wash, the side mirrors need to be folded in to avoid damage.
With 320 horsepower and 340 lb-ft of torque (up from 295/335 in 2006) the 5.3-litre V8 provides snappy acceleration, even for a vehicle this heavy. The switch from eight cylinders to four cylinders is virtually undetectable and doesn't affect performance, but there is an instrument display that shows you instant fuel economy readings in V8 and V4 modes. The standard four-speed automatic transmission shifts smoothly, and includes the push-button Tow-Haul mode which generally keeps the transmission in lower gears for longer periods to compensate for the weight of a trailer. The transmission has a column-mounted shifter that frees up space in the centre console area for storage.
The V8 engine's new Active Fuel Management system does work to reduce fuel consumption but I was only able to average 19.4 L/100 km (15 mpg Imp) in the week that I had the Tahoe, much worse than its advertised 13.1 L/100 km (22 mpg Imp). The instant fuel economy gauge revealed wild variations in fuel consumption in V8 and V4 modes (see photos). Coasting downhill in V4 mode, the engine sips as little as 2 L/100 km (140 mpg Imp.), but accelerating uphill in V8 mode, fuel consumption can go over 50 L/100 km (6 mpg Imp).
My 4WD truck had GM's Autotrac 4WD, an electronically-selectable system which allows the driver to choose between 2WD High (rear-wheel drive), 'Auto' (full-time 4WD) which varies torque between the front and rear wheels and can be used on dry or slippery surfaces; 4WD High (part-time 4WD) for slippery surfaces only; 4WD Low, a low gear for creeping over severe inclines and poor surfaces; and Neutral. With all these choices, Tahoe drivers have the type of 4WD traction they need for most types of roads. As well, all Tahoes have standard all-speed traction control and StabiliTrak stability control with a roll-over avoidance system designed to automatically compensate for understeer and oversteer, and help prevent rollovers.
The Tahoe's new front coil-over-shock suspension (replacing torsion bars) provides a comfortable ride and good damping, even with the optional 20-inch 275/65R tires, and in combination with the Tahoe's new rack and pinion power steering (replacing re-circulating ball) provides sharper steering response and cornering stability. However, the Tahoe's turning circle of 11.9 metres (39.04 ft.) is slightly wider than the previous Tahoe (11.7 metres (38.3 ft.). Standard on LTZ models is the Autoride air suspension, a damping control system that automatically adjusts to road and driving conditions, based on body and wheel motion sensors. I didn't have the opportunity to try this suspension, but I found the basic suspension plenty good enough.
All in all, this is a very satisfying vehicle to drive, but it's disappointing that even with Active Fuel Management, it sucks gas like a pig (although I've never actually seen a pig suck gas). For full-size SUV owners, this is the price to be paid for a hefty towing and hauling capacity, a roomy cabin, a generous cargo capacity, and occasional off-road ability.
NYCshopper is offline   Reply With Quote
Old 11-10-2006, 10:11 AM   #2
NYCshopper
Member#: 5126
Part 2
Verdict
Considerably more stylish inside and out, the 2007 Chevy Tahoe offers better driving manners, a quieter cabin, and decent towing and hauling capacities. But even with its new automatic cylinder deactivation system, real-world fuel consumption is very thirsty.
Pricing
Base price: $48,525
Options: $14,765 (LT3 Preferred Equipment Group: leather, tri-zone automatic climate control, power adjustable pedals, ultrasonic rear parking sensors, remote starter, MP3 compatible CD player, XM satellite radio, Bose speakers, universal remote, side curtain airbags, power heated folding mirrors with curb tilt, ground illumination, $7,395; 20-inch tire and wheel package, $1,565; Navigation system/radio with voice activation, auxiliary input jack, $2,915; Power liftgate, $530; 2nd row leather bucket seats, $700; 2nd row power fold and tumble, $515; 2nd row heated seats, $240; 3rd row two-passenger 50/50 split folding/removeable seat, $505; heated extending side mirrors, foldable, $75; Rearview camera, $235)
Freight: $1,200
A/C tax: $100
Price as tested: $64,590
More pics @ the Link...
Old 11-23-2006, 02:19 AM   #3
HellBinder
Member#: 132385
94 RHD Legacy
w/wrx swap. White
Hahahahah
HellBinder is offline   Reply With Quote
Old 11-23-2006, 11:59 AM   #4
InvertedB
Member#: 82455
Chapter/Region: HIIC
2006 Saab 9-3 2.0T
SportCombi
$64,590 for a Chevy Tahoe? Don't that have a niche vehicle called the Escalade already?
InvertedB is offline   Reply With Quote
Old 11-23-2006, 05:54 PM   #5
Eyeflyistheeye
Member#: 69694
2014 EuroPinto 5MT
No, that's in Canadian Tire Money...
Chevy thinks their new uglyarse Tahoe and Silverado are so great, when the next Sequoia and Tundra comes out, they're gonna severely outclass them
Eyeflyistheeye is offline   Reply With Quote
Old 11-23-2006, 08:09 PM   #6
importdriver
Member#: 96927
Canadian dollars like someone said above..
You think thats bad? $48,000 Cdn for a brand new STi... $35,000 for a new WRX.
importdriver is offline   Reply With Quote
Old 11-24-2006, 07:34 AM   #7
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
I have an '02 Tahoe. Last weekend, I went looking around at new trucks and SUVs to replace the Baja because the wife and I needed a new tow vehicle in addition to the Tahoe. (She does horse shows and I auto-x... had one schedule conflict last year, and this year will be more).
The new 2007 Chevy trucks are leaps and bounds above the older gens they replace through quality of materials inside, comfort, noise, etc. We took a 2007 'Classic' 6.0L out for a ride (The classic is really a 2006.5... still the old version of the truck) and turned around within a mile. This wasn't a truck that I wanted to tow a car 1/2 way across the country in.
Then we took out a new 2007 Silverado Z71. Freaking night and day between the two (Classic vs new); quieter, brakes were phenominal, steering much better (and a bit tighter) cabins were much better appointed, comfortable. This was a truck that surprised me so much that I put it #2 on the list.
If the dealer felt like moving any more on the price, I'd probably own one right now. However, I bought an '06 Nissan Titan. They moved a little more on the price, and what I was able to get in the Titan, it would have cost about $3K more in the Chevy.
But the new Chevy trucks.... if you're looking for a new one, go try them. Not the 'Classic', (again, that's just the same old truck they have been making) but try the new Chevy Silverado/GMC Sierra... much, much better than dad's old truck.
--kC
KC is online now   Reply With Quote
Old 11-25-2006, 02:22 PM   #8
InvertedB
Member#: 82455
2006 Saab 9-3 2.0T
SportCombi
That sucks, quite a bit of money for those. Made the rookie mistake, missed the Canadian website.
Old 11-26-2006, 12:51 PM   #9
GooseMan
Member#: 2462
2012 Volvo S60 T5
2005 Triumph Sprint ST
thats why I bought my WRX in the US Came out to approx $26K CAD
GooseMan is offline   Reply With Quote
Test Drive: 2007 Saturn Vue Green Line (CanadianDriver.com) NYCshopper Non-Subaru News & Rumors 1 02-20-2007 11:46 PM
Test Drive: 2007 Jeep Wrangler Unlimited X (CanadianDriver.com) NYCshopper Non-Subaru News & Rumors 0 01-31-2007 12:03 AM
Long-term Test Drive: 2007 Toyota RAV4 V6 Sport (CanadianDriver.com) NYCshopper Non-Subaru News & Rumors 2 01-15-2007 05:23 PM
Test Drive: 2007 Honda CR-V EX (CanadianDriver.com) NYCshopper Non-Subaru News & Rumors 0 01-11-2007 10:59 AM
First Drive: 2007 Chevrolet Aveo LT (edmunds.com) NYCshopper Non-Subaru News & Rumors 3 10-23-2006 07:42 PM
