Old 11-10-2006, 01:39 PM   #1
M3NACE
Member#: 130255
2000 S4 2+, S4 Stg 3
silver, yellow
Default Quick Code Question
Got in the car this morning - check engine light - came on. Plugged in the AP and it read code PO302 (2nd cylinder missfire I believe). I've done a search and figured out what it meant.
Anyways, the light is still on, but the car runs great, no hesitations or weird noises, so im assuming it must of misfired once, threw the code, and now it just needs to be cleared.
Can I clear the code myself?
Do I reflash the ECU, then re-run the 20psi map thats i've been running on the AccessPORT - will that work?
Thanks in advance for any help!
Micah
M3NACE is offline   Reply With Quote
Old 11-10-2006, 02:01 PM   #2
hondaeater69
Member#: 60324
you can clear the code with the reset ecu feature on the AP, that is what is what i suggest doing. see if it comes back.
Old 11-10-2006, 02:08 PM   #3
prometheum
Member#: 92003
04 bicycle!
i had a random misfire once during a 1,000 mile road trip, i could feel it misfire 2 or 3 times, cleared the code and never came back
but wouldn't hurt to check your spark plugs, see of the coil packs are properly seated, etc
prometheum is offline   Reply With Quote
Old 11-10-2006, 02:09 PM   #4
hondaeater69
Member#: 60324
true, never hurts to take a peak at the plugs, but i would reset first and see if it comes back before digging the pugs out.
Old 11-10-2006, 02:25 PM   #5
Bayley
Member#: 49763
2004 WRX
Jetzt mit 25% mehr Motor!
Now that you know what it is, reset the fault code and see if it comes back.
My personal observation is that 9 out of 10 misfire codes seem to be tied to fouled spark plugs in these cars.
Bayley is offline   Reply With Quote
Old 11-10-2006, 02:43 PM   #6
M3NACE
Member#: 130255
silver, yellow
It sounds reasonable to check the plugs, but they were replaced like 1500 miles ago, and havent given me any trouble since, so this could have just been a random mis-fire that threw the code.
So I just reset the ECU and run the 20psi map again and all will be good?
Old 11-10-2006, 02:49 PM   #7
pornie
Member#: 5620
if the 20psi map is your basemap, no need to reload it. just reset the ecu.
pornie is offline   Reply With Quote
Old 11-10-2006, 05:30 PM   #8
M3NACE
Member#: 130255
silver, yellow
Alright, well I reset the thing, turned it back on, sputtered a bit, loaded the 20psi map and all is well, no more code, so it must of been a one time thing.
Thanks for the help guys.
Old 11-11-2006, 11:54 AM   #9
M3NACE
Member#: 130255
silver, yellow
Last night, after a total of about 150 miles of driving throughout the day, I was pulling out of a parking lot and the engine light popped on.
I hooked up the Accessport and checked the code, this time it was PO301, cylinder #1 misfire I believe.
What would be causing this?
I mean its not like it comes on alll the time, but I was able to drive around for quite a while and it came up. Yesterday morning when it came up the first time it was as I was pulling out of my driveway, low RPM, and last night pulling out of a parking lot, low RPM.
Any ideas? Is a misfire bad for my engine - is it like predetonation or does it just mean the piston did not fire when it was supposed to?
Thanks for any help
Old 11-11-2006, 07:06 PM   #10
prometheum
Member#: 92003
04 bicycle!
Thanks for any help
2 types of misfire
one is caused by the spark plug not firing when it is supposed to, which will toast your cat/turbo
the other is caused by the fuel injector not spraying
Old 11-11-2006, 08:18 PM   #11
hondaeater69
Member#: 60324
what kind of plugs, and what were they gapped to?
Old 11-11-2006, 11:45 PM   #12
M3NACE
Member#: 130255
silver, yellow
Not sure the type of plugs, i'll find out in the morning, but the previous owner said he changed them like 1500-2000 miles ago, and that they're a step colder (also that they were about $60, so they must be high quality). Im running an 18G by the way. I assume they're properly gapped. Also, it has new 750cc (3k miles ago) injectors.
Its just kind of weird that it only does it once every several hours, and not like every few minutes, or per revolution.
Old 11-12-2006, 09:57 AM   #13
hondaeater69
Member#: 60324
i vote it's the plugs. plull them, find out what kind they are and how they're gapped.
Old 11-12-2006, 01:41 PM   #14
M3NACE
Member#: 130255
silver, yellow
Havent pulled them yet, looks like its a PITA to get them out, but I did get the box they came in:
Denso Iridium Power, U-Groove Tapered cut, Ultra-Fine, .4mm iridium.
I10
IK22#4
5319#4
I hope this information is helpful, like I said earlier, they're a step colder than the stock plugs, could this play any sort of role?
BTW, should I just avoid driving it until I figure out whats wrong, or do you think its ok to drive since its not misfiring that much?
Thanks again for the help guys.
Micah
Old 11-12-2006, 02:03 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
DO NOT **** with the gap on those plugs or you will make paperweights outa them!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-12-2006, 02:33 PM   #16
M3NACE
Member#: 130255
silver, yellow
Yeah, if thats the case, then I dont think the previous owner tried to gap them. Or he did and realy 'fooked' them up?
What do you guys think?
BTW, everytime I reset the ECU, does that 'count' as a reflash, or does it only reflash if I load a new map? I hear you can only do that about 100 times on the stock ECU, so each time I reset the code, does that take one reflash away from the 100?
Old 11-12-2006, 03:34 PM   #17
prometheum
Member#: 92003
04 bicycle!
no resetting the ecu is not a reflash
Old 11-12-2006, 03:37 PM   #18
M3NACE
Member#: 130255
silver, yellow
Ok just making sure that im not wasting my 'reflashes' everytime I reset the damn code...
Anyone have input on the specific plugs that are being used, asides for the fact that they shouldnt be gapped?
Old 11-12-2006, 05:39 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
Go buy a set of $2/ea NGK BKR7E plugs...gap them .028" - .030"......install them and see if yer misfire goes away
Old 11-12-2006, 07:44 PM   #20
hondaeater69
Member#: 60324
i agree, get a cheap set of ngk coppers and throw'em in. chances are those are either the wrong plugs, or the gap got messed up. i don't know what that type of iridium is for, i just run plain ole coppers and change'em every 25K or so. I think on a car with as many mods as yours (as well as mind) one should be looking at the plugs fairly often but that's just my HO.
and they're not that hard to get to, just remove the air box on the one side and the washer tank on the other side and they're a walk in the park. people make more out of doing plugs then they actually are... even my green ass can do'em
Old 11-12-2006, 09:00 PM   #21
M3NACE
Member#: 130255
silver, yellow
Sounds great, thats what i'll do. BTW, are the plugs listed above a step colder than the stock ones, how important is this, and are you positive on the numbers, i'd hate to get the wrong ones a second time!
Old 11-12-2006, 09:02 PM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
NGK BKR7E(NGK stock #6097) is one step colder and that plug gapped as posted above is what ya want, no doubt.
Old 11-12-2006, 11:33 PM   #23
M3NACE
Member#: 130255
silver, yellow
Thanks, i'll see able tackling the job this week, i'll let you all know what happends.
Old 11-13-2006, 09:10 PM   #24
M3NACE
Member#: 130255
silver, yellow
Alright,
I just finished a minute ago, got the plugs you reccomended (only $1.77 each ), gapped them to about .030" and installed them. It fired right up, I reset the ECU and we'll see if the CEL light stays off in the new couple drives!
I'll keep you guys updated. Hopefully this fixes the problem.
Old 11-13-2006, 11:35 PM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
how did the other plugs look?????
A quick code delete question. OUScooby Engine Management & Tuning 0 10-18-2009 04:40 PM
wiring question / ecu code question snailpower Engine Management & Tuning 4 01-07-2006 10:09 PM
Quick CEL question code P0133 speedracer47 Normally Aspirated Powertrain 0 01-28-2003 03:57 PM
Quick oil question, need quick answer. garface Service & Maintenance 8 12-06-2001 02:54 PM
Quick tire question. Please answer quick!! KURB21 Brakes, Steering & Suspension 2 07-02-2001 04:40 PM
