Old 11-12-2001, 10:24 PM   #1
joltdudeuc
Member#: 6119
1999 GM6
RBP
Default Questions on CATs
Hey,
I'm thinkign about replacing my CATs with high flow ones... i drive a NA 1999 2.5 RS... Gino, from Red Star Racing out here in the SF Bay Area, said it kinda sounds like i got a clogged up cat... and i proabably do, cause my exhuast smells a little funny.
What are my options? I have two CATs right?
-Gagan
joltdudeuc is offline   Reply With Quote
Old 11-12-2001, 10:32 PM   #2
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Your car has one cat, between the headers and midpipe. A high-flow cat can bump you 5-7 WHP. Call Cobbtuning (www.cobbtuning.com) and see if they have on in stock.
- Steve
zzyzx is offline   Reply With Quote
Old 11-13-2001, 05:56 PM   #3
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Default Do the 99s only have one cat??
The MYOO has two tween the header and midpipe.I just replaced mine with the Random Tech single high flow cat from Cobb.There is a noticable increase in performance.Expect a check engine lite though.
Rudy
jagcars26 is offline   Reply With Quote
Old 11-13-2001, 06:00 PM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Nope, two cats.
Keiho is offline   Reply With Quote
Old 11-13-2001, 07:17 PM   #5
joltdudeuc
Member#: 6119
1999 GM6
RBP
i don't mind extra hp!
are you sure one cat?? I look and i see two (or am i stupid and i'm looking at something else??)
what about torque? would i lose low end power?
-Gagan
Old 11-13-2001, 08:50 PM   #6
p-car
Member#: 5534
2000 Cliffdiver RS
Check the private classifieds for thread on the new Brullen headers with hi-flow cats (about $750 US).
p-car is offline   Reply With Quote
Old 11-13-2001, 10:06 PM   #7
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
this is the Random Tech cat. So far for the MY99 i have had no CEL so all is well and the power is there also. worth it IMHO.
Poppa smurf is offline   Reply With Quote
Old 11-13-2001, 10:25 PM   #8
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Default Re: Do the 99s only have one cat??
Rudy
You running headers? Low emission system efficiency/catalyst efficiency CEL?
If so, WRAP THEM.
Wrapping the headers will keep more heat in the exhaust and heat up the cat to it's operating temp (600-700F). A properly operating cat will prevent that CEL from appearing. Took two months of an intermittent CEL before I figured that out. Now I'm running great (cooler engine compartment too), sounding awesome (lot less noise in the cabin and the exhaust sounds sweet!!) with NO CEL. wwwooooooohhhhhhhhhooooooooo!!!
I'm really pumped. This was a thorn in my side for a long time
Dominic
ImprezaRSX is offline   Reply With Quote
Old 11-14-2001, 12:14 AM   #9
jagcars26
Member#: 2394
2009 Forester X
Dominic,,nope no headers yet,just the cat,stromung mid and tail.
Thanks fr the heads up though, when i get the headers ill wrap em fr sure.It kinda lets ya know the cat alone is freein up the exhaust when ya get a CEL,yep ive checked the code its the cat.
Rudy
Old 11-14-2001, 09:21 AM   #10
AC Lerok
Member#: 7918
2007 FSXT
Obsidian Black Pearl
hmph, my Borlas are wrapped and i'm still getting CELs since i've installed my Random cat.
i'm always the exception though, since wrapping seems to be the solution for almost everyone else.
the wrap really does make a difference in feel and in the exhaust tone, so i don't regret spending the time.
AC Lerok is offline   Reply With Quote
Old 11-14-2001, 09:42 AM   #11
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
Im planning on getting headers and a cat soon. what do you use to wrap the header? also, has anyone been emissions tested since installing said items?
thanks,
ben
tydon is offline   Reply With Quote
Old 11-14-2001, 01:29 PM   #12
AC Lerok
Member#: 7918
2007 FSXT
i (and others) have used this stuff called ThermoTec to wrap the headers, some have opted to coat the wrap with hi-temp sealer, others haven't. check it out at http://www.thermotec.com . i got mine at a local hot rod shop, you'll need to search around for it or otherwise order it from the website.
others have had their headers ceramic coated, i know nothing of this, do a search on the board for more info. it's a more expensive option, but i imagine that it looks a lot nicer than a mummified header.
the Random cat is supposedly CARB legal (that's what the paperwork that comes with it says), so emissions should not be an issue for anyone running it, unless your state has a visual inspection or they plug into the car's ECU while you're tossing CELs instead of using a tailpipe probe.
Old 11-14-2001, 08:49 PM   #13
joltdudeuc
Member#: 6119
1999 GM6
RBP
anyone got links to sites that sell high flow cats?
-Gagan
Old 11-14-2001, 09:21 PM   #14
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Make your own! Summitracing.com 2.25" catco cat, $60, two 02 sensor bungs, $12, a few feet of stainless pipe, and have the local muffler shop bend and weld. probalby cost you $150 or less. I don't think you can buy one premaid for that. (but I could be wrong. If I am, please tell me, I love to save money!)
yamarocket630 is offline   Reply With Quote
Old 11-15-2001, 12:53 AM   #15
synapse79
Guest
Member#:
yamarocket630
that is exactly what i plan on doing..
i had a catco on an integra and was very happy with it.. those things are huge..
Old 11-15-2001, 01:43 AM   #16
joltdudeuc
Member#: 6119
1999 GM6
RBP
Thanks Dude!
-Gagan
Questions on hollowing out cat sheikthin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-12-2005 10:08 PM
Question on installing heat shield on Prodrive 3rd cat pipe Orson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-31-2004 09:55 PM
Question on cat back meaning Scoobie Newbie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-16-2002 07:28 PM
Question on HKS Ti Cat-Back exhaust... Zigen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-06-2002 01:49 PM
Question on cats and stromung pipes? cvcsmkr Normally Aspirated Powertrain 2 12-31-2001 07:56 PM
