Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 11-10-2006, 03:35 PM   #1
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default To much flow?
So im wondering if im injecting to much flow with my current system causing a missfire im seeing. This is all without using a wideband to really dial this in, it hasnt come yet.
Motor is a 2.0 with gt30r
modded stock injectors 22.7psi @ 5700rpm 58% duty cycle
800cc
Jets Aquamist:
M7 450 ccmin @ 100psi
M4 250 ccmin @ 100psi
The math puts these guys in combo at 11 gph, .18 ghm
Sound about right?
Im running about 70/30 meth
Token-Negro is offline   Reply With Quote
Old 11-10-2006, 09:51 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
What are you using to control the flow? Ie- Are you at max flow all the time? What rpm range do you usually see misfire in?
Old 11-10-2006, 10:14 PM   #3
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Well usualy right around 5500 + - 500rpm and the flow starts at 10 and 15 psi of boost.
Old 11-11-2006, 06:40 AM   #4
hippy
Member#: 36528
2002 Impreza Wrx
I don't really know what to say except that you're running a lot of injection(30+%). Maybe running less would help? Maybe running less petrol would help? Maybe this has nothing to do with your misfire? What are your mods? Maybe it would be a good idea to post a log?
peace
Old 11-11-2006, 07:38 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Aquamist recommends 50/50.
the math, to be sure, should look like this.
total injector flow x injector duty cycle x 10% = injector size
but Richard will reply as soon as he reads this.
but you second jet might be to big.
check the math, you should have less
than 200 cc.
Increasing Pump Size to Increase Flow While Reducing Oil Weight to Reduce Pressure? williaty Built Motor Discussion 13 05-25-2010 02:04 PM
How much flow gpm? Token-Negro Water/Methanol Injection, Nitrous & Intercooler Cooling 6 04-13-2006 03:10 AM
Explain Shaft Play and How Much is To Much mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-09-2005 08:17 AM
How much flow with stock inj and AFPR silver arrow Engine Management & Tuning 3 08-30-2005 09:01 AM
How much boost is to much boost? xtheviperx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-16-2002 08:49 AM
