Welcome to the North American Subaru Impreza Owners Club Monday July 27, 2015
Old 01-04-2007, 01:11 AM   #26
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
I just completed installing my Supertones using your 'instructions', but with a couple of tweaks:
1. I used 14/16 guage speaker wire for the power lead and ground lead, whereby I twisted the +/- ends to connect to the female connectors to the relay, and I was able to ground the horns together. This way I didn't have to use vampire clips.
2. I used dielectric grease and heat-shrinked all my connections - I'm a neatness freak.
3. I installed the horns on the hood latch release area.
wrXmon is offline   Reply With Quote
Old 01-04-2007, 09:06 AM   #27
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Excellent write-up!
Based on what has been said, not only do the horns look good, but that they are producing a louder tone - which is what you want.
What I don't understand is since the Supertones are supplanting the stock horns, then why is there the need for the secondary relay? Is there a substantial difference in amperes [draw] between the Supertones and the stock horns? If there is, then I see the need for the relay.
I know that outside of the US laws, rules, requirements and availability of equipment and parts can and has varied and thus when one purchased such a kit, whether for primary or secondary installation purposes, one got a complete kit.
Just curious; and thanks.
Old 01-04-2007, 09:12 AM   #28
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
The reason for the relay is because the OEM horn wires are pretty wimpy which can potentially prevent the horns from drawing enough current to be their loudest. With the relay, you use the OEM wires to trigger the relay then wire up the horns so they have essentially a direct connection to the battery with some adequate wires.
Old 01-06-2007, 12:55 PM   #29
dirtnyureye
Member#: 92573
2005 Saab 9-2x Aero
Midnight Black Metallic
So everyone is REMOVING their stock horns? Say it ain't so Joe!
dirtnyureye is offline   Reply With Quote
Old 01-06-2007, 03:26 PM   #30
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Mine are disconnected, it sounds a little silly with both sets of horns. Glad to see this was of help to everyone who used it ....and thanks for the feedback on what you changed from what I did
Dave
Car vs. Driver is offline   Reply With Quote
Old 01-06-2007, 05:42 PM   #31
kamil212
Member#: 90596
2009 Scrambler
Bitches love Scramblers
Thanks a lot for this write up,
Just installed mine today.
The only thing I did different was that I went with two vampire clips into the ground wire (3 connection for the relay and each horn)
kamil212 is offline   Reply With Quote
Old 01-07-2007, 02:08 PM   #32
O2-GGA
Member#: 23222
02 Prodrive wagon
Great write up. I installed mine last Thurs..
O2-GGA is offline   Reply With Quote
Old 01-07-2007, 04:42 PM   #33
dirtnyureye
Member#: 92573
2005 Saab 9-2x Aero
Originally Posted by Car vs. Driver View Post
What to do:
2. Disconnect one of the factory horns (or both if you desire). Don't cut the connectors, you will need to use one of them later.
~CvD
What do you do with each wire that runs to each factory horn?
1 factory horn lead attaches to the hella relay. Where does the other factory horn lead go??
Old 01-07-2007, 07:04 PM   #34
Psydotek
Member#: 44168
2003 Yellow WRX
You can let the other horn wire just dangle or leave the OEM horn plugged in and in place.
Or do what i did:
Old 01-07-2007, 08:49 PM   #35
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
You can either disconnect it, or leave it connected. Your choice Sorry I wasn't clear about that, but both of mine are disconnected. In reality, you can leave both of them connected if you want, but you'll need to splice into one of them if you do.
Hope that helps.
Old 01-08-2007, 12:39 PM   #36
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
nice write up, installed mine yesterday
cnstman is offline   Reply With Quote
Old 01-14-2007, 01:07 AM   #37
Doctor Subie
Member#: 115994
2006 STI
Excellent write up. I used this write up, along with placing the horns on the hood latch bolts, and the wiring diagram in the middle of this post here:
http://forums.nasioc.com/forums/show...=510523&page=5
to perfection! I also used heat shrink tubing, and anti-oxidation grease (similar to dielectric grease I believe), and wire loom to cover it all up.
Doctor Subie is offline   Reply With Quote
Old 01-14-2007, 10:55 AM   #38
wrXmon
Member#: 115454
My '02 WRX Wagon
Originally Posted by Doctor Subie View Post
... and wire loom to cover it all up.
I went back and covered all exposed wires with wire loom, and found some better heat shrink covered cable ends and replaced them too.
Old 01-14-2007, 12:54 PM   #39
lethal1
Member#: 118403
2002 Infiniti Q45
Dark Blue
Psydotek,
Is that a third Supertone?!! If so what a great idea!!
lethal1 is offline   Reply With Quote
Old 01-14-2007, 01:29 PM   #40
Psydotek
Member#: 44168
2003 Yellow WRX
Originally Posted by lethal1 View Post
Psydotek,
Yep, i've got 3 supertones. One for every sound frequency, 300Hz, 380Hz, and 500Hz.
I picked up the "made in india" kit (the 300/380Hz combo) then added the 500Hz horn later. The little tab in front of the radiator is a nice mounting spot. I was able to pick up the single horn from www.rallylights.com.
Old 02-07-2007, 10:11 PM   #41
just smurfy
Member#: 135893
2012 Smart Car
murdered out w/ stickers
Talking
I've got mine on order and I'm no electromotrician, but I'll give it a shot
**looks up the word "relay" in the dictionary**
I've got calibrated noise dosimeters at work, I'll measure them and post when I get them installed - and see how close to 118 they really are! - with appropriate hearing protection of course.
just smurfy is offline   Reply With Quote
Old 02-14-2007, 10:05 PM   #42
just smurfy
Member#: 135893
2012 Smart Car
Default Supertone noise measurements
OK, if anyone is still reading this thread, I installed a 300/500 MHz set of Made in Germany Supertones behind the grill of my rex.
I measured the noise today using a calibrated noise dosimeter. The results are as follows:
Within 2 inches of the horn: 135 to 141 dbA
Six feet away at knee height: 118 dbA
Six feet away at head height: 110 dbA
Hearing protection is recommended in any workplace above 85 dbA and required above 90 dbA average over 8 hours. I think every 3 decibels the sound pressure energy doubles. The remaining interpretation I'll leave to you. Just a little industrial hygiene for y'all.
Old 02-15-2007, 08:28 AM   #43
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
That's impressive. I feel bad for any bastard that decides to cut me off ... no, no I don't.
Old 02-15-2007, 09:54 AM   #44
Psydotek
Member#: 44168
2003 Yellow WRX
Oh snap! Good thing i got 3 of them...
Old 02-15-2007, 10:11 AM   #45
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Originally Posted by USAF_Pignose View Post
sound clip of the actual horn i havent been able to find 1 i know they are MUCH louder but i dont want the tone of a mack truck or the high pitch honk of a ferrari.
i had posted a sounclip of the supertones compared to stock meep meep horn. (MY00RS).
The clip does not do it justice at all. However, the look on other peoles faces when they poop their pants does.
moogoob is offline   Reply With Quote
Old 02-15-2007, 02:24 PM   #46
vinithing
Member#: 59414
05 STi
I just installed mine today. I followed the write-up in this post. The only thing I did differently was plug the wire from the factory horn directly into the relay. I thought it would be a little cleaner that way. Well the horns dont work right now. I was wondering if that was the cause. Any help would be great!
vinithing is offline   Reply With Quote
Old 02-15-2007, 03:14 PM   #47
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
That shouldn't make a difference. Check to make sure you have good grounds and that your wires are all connected to the correct numbers on the relay.
I'd simply trace each wire to make sure it's all hooked up correctly. I'm going to assume you either have a bad ground or something not connected correctly.
Old 02-15-2007, 04:11 PM   #48
vinithing
Member#: 59414
05 STi
I also bought solid copper wire for some reason so I don't know if that would matter. For my grounds I did them in the same place as you did. When I took off the bolt the little washer fell and I lost it, could that matter? I am just throwing ideas out there. Thanks for the quick reply
Old 02-15-2007, 04:41 PM   #49
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Did you sand/file off the paint so your ground hits bare metal?
Old 02-15-2007, 05:18 PM   #50
vinithing
Member#: 59414
05 STi
No I just took out the bolt and put the horn wire and the other one back and tightend it up. Do you think that is the cause??
How to: Install Alpine HU-Currently Have Sony gtwagon941 Car Audio, Video & Security 13 02-15-2006 01:35 AM
How to: install Megan coilovers? spooledwrx Interior & Exterior Modification 12 01-20-2006 12:14 AM
How to: Install a new clutch no_rex_yet Off-Topic 11 11-12-2004 02:45 PM
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 11:18 AM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 11:37 AM
