Old 10-25-2012, 08:46 AM   #751
infinite012
Member#: 74392
2015 Forester
Sounds more like my old BMW horn. Actually, it sounds similar to most Acura, BMW, Lexus, and Mercedes horns that I've used/heard.
infinite012 is offline   Reply With Quote
Old 11-08-2012, 10:53 AM   #752
Hans84
Member#: 336971
2004 WRX Wagon
Thanks for the informative write up!
Hans84 is offline   Reply With Quote
Old 12-02-2012, 09:18 PM   #753
Bubakanush
Member#: 209975
2016 WRX
LBP
Soooo.. Installed my Supertones yesterday with the subimods harness. Anyway, I was out to dinner tonight and came back to a dead battery. I DID search this on google before and I know it has been discussed on the iwsti forums, however their server is down for maintenance tonight which doesn't help. And yes, I have installed the harness correctly, according to their website information, so that isn't the problem. I also read that this problem was very common with the subimods 4pin relay, however mine is the newer 5 pin so I didn't expect this to happen. In the mean time, the harness is removed and I am using my stock horns. Clearly the harness is still drawing power when not in use, which absolutely shouldn't be happening. Does this sound like a faulty harness? Or should I just not use a subimods harness at all anymore? I will be contacting subimods in the morning.
Bubakanush is offline   Reply With Quote
Old 12-02-2012, 09:45 PM   #754
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Just make a male to female wire an extend the stock power and u can't go wrong.
JavaBot is offline   Reply With Quote
Old 12-02-2012, 11:18 PM   #755
dibblejr
Member#: 94070
05 LGT
Throw the garbage harness you purchased in the trash where it belongs and follow all of our advice here. I have installed thousands of these horns without any failures.
It is such a simple harness to make.
JR
dibblejr is offline   Reply With Quote
Old 12-03-2012, 12:42 AM   #756
Bubakanush
Member#: 209975
2016 WRX
LBP
Edit: Subimods has been great throughout this process. Even though I'm making my own harness, they took mine back and fixed the problem for no charge. Top notch customer service. +1 for subimods.
Old 03-20-2013, 04:47 PM   #757
ABeastinWRX
Member#: 239469
2004 WRX
Thanks for the write up! Helped with the install.
ABeastinWRX is offline   Reply With Quote
Old 03-30-2013, 11:35 AM   #758
freddyo_0
Member#: 339277
2011 WRX STI Limited
Thanks for the write up. Between this and another guide, I installed my tones at 10pm in front of a friends house without issue (other than lack of light) lol.
freddyo_0 is offline   Reply With Quote
Old 05-23-2013, 07:42 AM   #759
PSBeachBum
Member#: 279870
2005 WRX Wagon
Nice write up. I am thankful for the Subimods harness and bracket. Took me about 15 minutes for the whole process! Hardest part was taking off the damn bracket included with the horns.
PSBeachBum is offline   Reply With Quote
Old 05-23-2013, 08:58 AM   #760
640k
Member#: 160315
2008 STI
can someone speak to if the supertones loose their "oompf" over time? I don't feel like I can hear them as clearly as I could when they were first installed.
640k is offline   Reply With Quote
Old 05-23-2013, 03:37 PM   #761
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
I havent measured or recorded them, but maybe one of us could do so, or simply compare them along side someone who just had them installed.
I took mine apart and painted the red to green, to match my color sheme. It didnt make them any quieter, as far as I can tell. Although, I think it may have changed the pitch/tone of the horns.
djtoone is offline   Reply With Quote
Old 07-08-2013, 08:11 PM   #762
Siress
Member#: 347295
2013 WRX 5DR
Those of you that've had a relay failure, where did you mount your relay and what steps had you taken to weather proof?
I'm waiting on the parts for this project, and the relay mounting location is the only thing left. I'm planning on using a relay socket and putting a condom over the whole thing. Probably won't matter where I put it at that point, and my preferred location is one that's easy to access from the engine bay; so probably right by the battery.
Parallel question, since I'm putting a plan of action together for a sub, possibly more, I'm considering a junction block off the battery for all of my future projects. Has anyone written anything about doing such a thing? I'll absorb all of the experience I can. Hell, a large enclosure in the engine bay for random DIY stuff sounds pretty awesome, and can double as a junction.
Siress is offline   Reply With Quote
Old 08-25-2013, 11:27 PM   #763
brian625
Member#: 365612
Originally Posted by Rippen Griffen View Post
Fixed the pic...terminals were wrong on the relay
sooo useful made the install a breeze
brian625 is offline   Reply With Quote
Old 09-14-2013, 05:45 PM   #764
WaveBye
Member#: 270425
2011 WRX
I know it has been posted several times, but here is another vote for installing without removing the bumper. On my 2011 WRX, I used the subimods bracket & harness, premounting and wiring the horns on the bracket before installation. There is plenty of room to reach under (thought I would need to enlist my super skinny son teenage, but not required). The physical horn swap was under 10 minutes. Running the wiring was another straightforward 10 minutes. The only longer time was threading the zip tie through the bumper bar to mount the relay. Once I got that through, there was still plenty of access room to mount the relay and clean up the other wiring, probably another 20-30 minutes for that part.
As for using the premade harness, I have the ability, but not the time to make my own harness (these parts have been sitting around for a month, and my next mods, the shifter sitting on the workbench now, is several weeks from going in). I wish the leads for the relay were longer, to allow mounting the relay in the bay, farther away from the elements, but otherwise it is a nice, clean installation in significantly less time.
WaveBye is offline   Reply With Quote
Old 09-20-2013, 01:55 PM   #765
AKFOWLER
Member#: 366222
2011 subaru WRX
lightning red
I agree the prewired harness is the way to go if your crunched for time. Admotorsports.com makes one ffor about 30 dollars that is great
AKFOWLER is offline   Reply With Quote
Old 11-21-2013, 09:12 PM   #766
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
USAFAndrei is offline   Reply With Quote
Old 11-24-2013, 11:35 PM   #767
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Old 11-25-2013, 02:22 AM   #768
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Old 11-29-2013, 02:49 PM   #769
HonduHunter
Member#: 28408
2002 vf48ed WRX
Are those leds in your grill??
HonduHunter is offline   Reply With Quote
Old 11-29-2013, 06:32 PM   #770
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
Yea. Alpina Rugged LED's. The are waterproof and can withstand -20 F temps.
Old 12-23-2013, 02:06 AM   #771
ToneWrx02
Member#: 239095
2002 Wrx
I may need help. Il post a picture of the wiring on mine later. I have wired everything in with relay and fuse etc etc.
Forst horns didnt work because of ground connection wasnt tight enough. After a small drive to test horns they worked. Then one worked. Then both stop working. Im going to double check the ground connection and move the relay near battery location instead of stock location horn. The only wire that isbt properly wired in is the extra positive wire to the second horn.
But even so the secondary horn was the last one to work. Il solder it on after work.
Also the stock horn works but one day it stoped working and later that day it worked again.. figures on inspection day..
But i dont believe that has anything to do with this setup. Since everytjing is wired correctly. I checked out the horn fuse as well. Checks out. Checked the fuse to the battery to relay as well. And override it with a wire to make sure fuse wasnt bad.
Im thinking its the ground wires. Woth vibrstion they must of becsme abit loose
ToneWrx02 is offline   Reply With Quote
Old 01-07-2014, 02:30 PM   #772
onsit
Member#: 292225
08 WRX (16g)
For those curious to weather proof your relays, there are things called relay sockets that provide a mechanical connection, and allow for easy re-installation. IN the rare event a relay blows.
Id imagine you plug in your relay, electrical tape the connection, then tuck it away.
onsit is offline   Reply With Quote
Old 01-07-2014, 05:18 PM   #773
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I would personally not tape the socket to the relay, I did it once on my headlights harness and it can act as a water trap and cause shorting out issues. I drained my battery a couple times by having the HID low beams turning on durin the night before I figured the problem. When I removed the tape, rusty water escaped from the connection area.
I guess you'd notice a horn sticking overnight though but you get the point.
frederik is offline   Reply With Quote
Old 01-08-2014, 09:52 AM   #774
onsit
Member#: 292225
08 WRX (16g)
If you look on the Lightwerkz Harness. That is exactly what they do Relay + Relaysocket, shrink wrap probably. But still prone to moisture.
Old 01-08-2014, 05:09 PM   #775
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I would be ok with tape on the socket like in this picture, but not tape on socket extending over relay (which is the error I made).
How to: Install Alpine HU-Currently Have Sony gtwagon941 Car Audio, Video & Security 13 02-15-2006 01:35 AM
How to: install Megan coilovers? spooledwrx Interior & Exterior Modification 12 01-20-2006 12:14 AM
How to: Install a new clutch no_rex_yet Off-Topic 11 11-12-2004 02:45 PM
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 11:18 AM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 11:37 AM
