Old 11-10-2006, 04:46 PM   #1
Sharkey
Member#: 131598
06 WRX TR
World Rally Blue
Default 06 WRX turbo upgrade question
Ive been going back and fourth on the idea of replacing my stock VF30 turbo with something bigger. But the whole issue is im not to sure of what to replace it with.
I have had some friend make some suggestions, but i dont belive they are entirely accurate, seeing as they both owned 04's with the 2.0L engines. From what i can tell right now the turbo is choking my engine pretty bad.... but also doesnt the VF39 choke out the STI a little bit? any insight?
Sharkey is offline   Reply With Quote
Old 11-10-2006, 05:58 PM   #2
105wrx
Member#: 75931
2005 hmmm STI?
Clark Tuned!
what a stock vf30? The wrx comes stock with the td04 from 02-06, the sti comes with the vf39..I dont know how you got a vf30 stock maybe you just misread somewhere..anyways yes the td04 is too small for the 2.5 block it jst doesnt get it done...i would recommend a vf39 or larger if you want to get rid of the choke....
105wrx is offline   Reply With Quote
Old 11-10-2006, 05:59 PM   #3
wakeskate
Member#: 124791
03 wrx
psm
i would get a 18g
wakeskate is offline   Reply With Quote
Old 11-10-2006, 07:10 PM   #4
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
The 06 is a td04 not a vf 30 like previouly mentioned. If you are serious hit up the classfieds or something looking for people with used trubos for sale maybe. I am pretty sure if you get a new turbo you ahve to upgrade the TMIC and perhaps the injectors and such. Search around more, you will find your answers.
Ryan
007WRX is offline   Reply With Quote
Old 11-10-2006, 07:12 PM   #5
dvang
Member#: 84188
05 legacy
caravan full of kids now
20g or green
vf39 for bout $300 if you is broke
dvang is offline   Reply With Quote
Old 11-10-2006, 07:22 PM   #6
Davenow
Member#: 23676
you dont have a stock VF30.
You have the same tiny ass TD04 that the 02-05 wrx has. And the STis VF39 is pretty much identical to a VF30 when it comes to power and spool anyway, so even if you DID have a stock VF30 (you dont, it never came stock on a WRX, anywhere) you would gain nothing by going to a 39.
Old 11-10-2006, 09:34 PM   #7
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
imo, the thing is to have a target hp goal. call/write deadbolt, forced performance, someone with REAL knowledge. know your set-up, that plus your goal will get an answer.
btw, (if you care to go this far), understanding the limitations of your internals (crank, piston rods, pistons) will help you pick a do-able target...
cellobro is offline   Reply With Quote
Old 11-10-2006, 09:41 PM   #8
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Originally Posted by dvang View Post
20g or green
+1
For a 2.5l that should be what your looking for.Anything else would be to small
Needles is offline   Reply With Quote
Old 11-10-2006, 09:43 PM   #9
DeadBolt Enterprises
Vendor
Member#: 34272
2005 STi
Crystal Grey
Which turbo to use really depends on your goals. If you are ust looking for a slight upgrade at low cost a VF30,39, or 22 would be nice.
There are quite a few other nice upgrades based on Mitsubishi center sections, which have the nice benefit of being rebuildable (the VF series are not rebuildable). Depending on your goals, there are LOTS of different options based on this framework.
DeadBolt Enterprises is offline   Reply With Quote
06 WRX Turbo Upgrade Question Xtant Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 133 09-08-2015 01:43 PM
06 WRX turbo Upgrade Questions. 06wrx_WRB Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-02-2010 10:16 AM
06 WRX brake upgrade question rkjunior Brakes, Steering & Suspension 1 04-26-2010 12:59 PM
06 wrx 18g upgrade questions Wannascooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-18-2010 03:07 PM
06 WRX Turbo Upgrade Progress drmichael Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 03-13-2010 03:21 AM
