Old 12-03-2001, 12:22 PM   #1
Momo
Member#: 1544
2012 SWP hatch
Question Changing MT oils
I know how to change the engine oil, but I am wondering about the other one. There is a really small dipstick way in the back, on the bottom for the manual transmission. How do I change it, when, and what should I use? thanks.
Momo is offline   Reply With Quote
Old 12-03-2001, 10:52 PM   #2
quicksilver
Member#: 2538
Changing the tranny oil is actually easier than changing engine oil. Drive the car up on ramps or a lift and locate the bolt on the underside of the tranny. It should be right between where the the header pipes come together. Make sure the oil is warm and simply unscrew the bolt and let the old fluid pour out into a pan. Some will get all over the header heat shields. Mop this stuff up fast or it will smell bad for way too long! Clean off the magnetic plug on the end of the bolt and reinstall to proper torque specs. Fill up through the hole in the top of the tranny where the dipstick resides. I think it holds 3.7 qts, but I'm not sure. I used Mobil 1 75w90 gear oil. It shifts smoother but sometimes the synchros don't engage well. I used this in the rear diff. also and managed to pick up 3 mpg! Oh, I changed mine around 20k.
-Mike
quicksilver is offline   Reply With Quote
Old 12-04-2001, 12:06 AM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Whatever oil you use, make sure it is GL-5 rated.
ANZAC_1915 is offline   Reply With Quote
Old 12-04-2001, 03:14 AM   #4
Momo
Member#: 1544
2012 SWP hatch
thanks guys.....but do I really have to lift the car up? or can I just crawl underneath and get to it?
MT oil change @ 15K RacerX Service & Maintenance 12 03-15-2004 11:01 AM
Just changed MT oil to Motul Gear 300 hellopat Transmission (AT/MT) & Driveline 15 10-02-2003 04:56 PM
Dumb question : MT oil change? alvyman Transmission (AT/MT) & Driveline 5 08-09-2003 09:36 AM
Changing MT Oil? e_a_olson Newbies & FAQs 9 09-04-2001 10:43 PM
Changing MT oil, and Rear Diff. Oil in a MY00 RS?? joostin420 Technical Forum Archive 2 10-06-2000 08:46 PM
Message Board Statistics All times are GMT -4. The time now is 01:00 PM.
