Old 11-12-2006, 09:18 AM   #26
brcewane
Member#: 63990
Flat Grey
brcewane is offline   Reply With Quote
Old 11-12-2006, 03:04 PM   #27
Durmiente
Member#: 75771
thanks. truly a masterful piece of work. Two thumbs up on that one!
Durmiente is offline   Reply With Quote
Old 11-12-2006, 03:13 PM   #28
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Impreza GC8
Great job!
Kudos for an original DIY project.
4wdrift is offline   Reply With Quote
Old 05-06-2008, 07:04 PM   #29
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
great write up!
how would i do it if i wanted to keep the starts stock chrome and just paint the backing?!
CoBB_tHiS! is offline   Reply With Quote
Old 05-06-2008, 09:35 PM   #30
brcewane
Member#: 63990
Flat Grey
Originally Posted by CoBB_tHiS! View Post
great write up!
Best way I found was just to take paint thinner and a bunch of Q-tips and rub off the paint around the stars and leave the stars...
Just dip the Q-tip in the thinner and rub away
This was the result when I used Orange
Old 05-07-2008, 05:42 PM   #31
Durmiente
Member#: 75771
yeah, the chrome is pretty tough to remove.... it takes extra rubbing. I would start by using small amounts of the goof off stuff with a Qtip... don't saturate the whole thing. Just dip the Q tip in the remover and rub away the paint carefully, and I would imagine you should be fine with keeping the chrome on there. You may even be able to use something less severe, such as nail polish remover, to get just the paint and keep the chrome intact.
I think it was tough for me to remove all of the chrome. However, I think some did fall off with little effort. If you don't saturate the whole thing in the remover, you should be fine.
Old 05-07-2008, 06:47 PM   #32
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
sounds perfect thank u
Old 05-08-2008, 06:55 AM   #33
asianhulk
Member#: 77529
05 Beat up Jeep
Alaska Black
great write up!
I did this by using sandpaper, since the blue is painted over the stars, worked well for me
asianhulk is offline   Reply With Quote
Old 05-08-2008, 07:10 AM   #34
mygreenbird007
Member#: 154767
2004 PSM WRX ASPL 35
2001 BRP 2.5RS
Wow this thread is back from the dead - non-chlorinated brake cleaner also works very well to just remove paint and not the chrome.
Learn from my mistake - Make sure that your emblem does not have any cracks or rock chips when you apply whatever solvent you choose. I made that mistake when I first did it and it seeped into between the plastic layers and clouded the plastic. The rock chip was tiny, but it still did it.
mygreenbird007 is offline   Reply With Quote
Old 05-08-2008, 03:56 PM   #35
Walker Dooley
Member#: 134568
02 WRX [MBP]
96 2.2L [SOLD]
Ah the little things that tie it all together. This is how I wanted to do my wheels on my black bug eye, and painted corner lenses, and now Im considerin the badge aswell.
Nice write up!
Walker Dooley is offline   Reply With Quote
Old 05-09-2008, 08:27 PM   #36
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
wat grade sand paper
Old 05-10-2008, 05:29 AM   #37
wrxkid77
Member#: 175081
2003 WRX
WOW! that is beautiful... i might have to do gold stars with blue background
wrxkid77 is offline   Reply With Quote
Old 05-10-2008, 07:13 AM   #38
Eugene Onegin
Member#: 165094
2011 OutBack Sport
Sage Green Metallic
I'm going to try it but in green.
Eugene Onegin is offline   Reply With Quote
Old 05-27-2008, 04:29 PM   #39
DellWRX
Member#: 89733
'08 WRX Hatch
nvm, got it
DellWRX is offline   Reply With Quote
Old 05-27-2008, 05:34 PM   #40
iRick.
Member#: 158155
hmmmm...i wonder how completely clear would look...
*ideas begin and looks at old red badge from a friend sitting on desk*
iRick. is offline   Reply With Quote
Old 05-27-2008, 09:38 PM   #41
Durmiente
Member#: 75771
^ weird. Remember that the grill will show through... so it will look like flat black.
Something I think that would look cool would be all silver/grey, with just the circular edge part done in red (or not at all, if you prefer). I'm not sure if there would be enough contrast to get the stars to show up that way, but it the light hits it just right, it could look really cool like that. Or, you could try leaving a touch of the chrome on just the edges of the stars and painting the rest all silver/grey, which might look neat as well.
I'm too lazy to redo one of mine, but it would be cool if someone tried something like that
Old 07-16-2008, 02:50 AM   #42
TimeAtk
Member#: 170432
3076 Apollo Rotation
Im in the process of painting my emblem, but the paint won't seem to stick very well to the emblem for some reason. There are tiny blotches on the paint, anyone know the reason for this?
Should I keep throwing light coats on the emblem and let it cover up?
Thanks in advance
-Cliff
TimeAtk is offline   Reply With Quote
Old 07-16-2008, 03:13 AM   #43
loganlz
Member#: 178675
1993 Impreza gc8
soo sick would it be the same to do with an i badge?
loganlz is offline   Reply With Quote
Old 07-16-2008, 03:23 AM   #44
div
Member#: 131193
wrb
Great write up.
div is offline   Reply With Quote
Old 07-16-2008, 04:28 AM   #45
Karna
Member#: 176638
04 WRX 20G
great little trick!
do you have a write-up on how to do the whels with the red lip?
Karna is offline   Reply With Quote
Old 12-21-2008, 08:41 AM   #46
mostasz
Member#: 170512
2012 WRX
Ice Silver
Great looking bugeye! I like colors!
Good job on badge. I will do something like that Want to match my time attack wheels too
Any closer pictures of calipers?
mostasz is offline   Reply With Quote
Old 12-21-2008, 08:47 AM   #47
mostasz
Member#: 170512
2012 WRX
Ice Silver
Just came trough my mind...
If badge is clear, maybe some LED under stars, and semi-transparent stars would make good effect? Light coming trough stars...
Would it be too rice?
Old 12-21-2008, 10:06 AM   #48
shaner
Member#: 69275
cool mod!
shaner is offline   Reply With Quote
Old 12-21-2008, 02:10 PM   #49
SILINC3R
Member#: 198052
9105 Legacy SS/SpecB
Rio Red and SWP
wow looks good. might consider just dont want to steal you idea
SILINC3R is offline   Reply With Quote
Old 12-22-2008, 07:40 AM   #50
Lamb155716
Member#: 155716
2008 Spesh Pitch Pro
2010 Spesh Roubaix Elite
looks very nice!
your car is very clean as well...just need a fat tire and wheel setup
Lamb155716 is offline   Reply With Quote
How to paint your stock wheels criscross79 Interior & Exterior Modification 545 04-10-2012 05:10 PM
Video Intruction of how to debadge your SUBARU minx1225 Interior & Exterior Modification 15 03-21-2006 05:30 PM
How To Keep Your Subaru Alive (V2 Manual) NewDriverOlderRide Private 'For Sale' Classifieds 0 01-20-2006 11:43 PM
How to paint your seats reconracer Interior & Exterior Modification 62 08-26-2005 01:23 PM
How to paint your aftermarket rims? o2sys Interior & Exterior Modification 2 06-29-2005 04:51 PM
