Old 04-09-2014, 04:03 PM   #526
Elgreco
Member#: 386401
Has anyone seen the pink carbon fiber inlay that some people have done? I couldn't find pics but they came out pretty cool.
Elgreco is offline   Reply With Quote
Old 04-10-2014, 02:29 PM   #527
P43
Member#: 136953
07 Wrx
Grey
Default brake cleaner
I haven't read through this whole thread, but a few years ago there was one that used brake cleaner to remove the background paint. I did this on my 07 badges and it worked great. It left the chrome stars intact and rubbed off the blue cf look. They were repainted grey to match my car, but were eventually stolen I'll try to find that thread-
P43 is offline   Reply With Quote
Old 04-10-2014, 02:37 PM   #528
P43
Member#: 136953
07 Wrx
Grey
Old 07-21-2014, 03:59 PM   #529
VTenge
Member#: 370632
2013 Black Hatch STi
Stasha
Default 2013 STi Badge
I haven't found any any information on painting the badge of a 11+ impreza so i bit the bullet and and did it myself.
Here are my notes...
A little zap of the heat gun and a butter knife took the badge right off
it looks like this once it is off the trunk door
it separates into two pieces
I used Purple Power and brake cleaner to get the paint off. The brake cleaner worked better than the purple power so i ended up using it more often. this process of removing the paint took 1.5 to 2 hours (while watching TV) with the aid of q-tips and little wooden dowels. the badge didnt crap or chip or anything with the purple power / brake cleaner.
You can see the checker board pattern in blue that does not get removed. I had to wet sand this off (water + dish soap + sand paper). Upon sanding it i realized i probably could have sanded the whole thing but that's just how it goes...
After wet sanding and the silver is removed and you can start painting the stars. i did red stars and black background since that is my theme. you can paint outside the lines and not worry about it since you can hit it with the sand paper again once it dries.
before plast-x
after plast-x
then spray paint the crap out of it and let it dry in the sun
VTenge is offline   Reply With Quote
Old 07-21-2014, 03:59 PM   #530
VTenge
Member#: 370632
Stasha
i plast-i dipped the chrome around it
on the car
Old 07-21-2014, 04:07 PM   #531
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
i like how you snuck your grinder into the photo
07VTRex is offline   Reply With Quote
Old 07-21-2014, 04:29 PM   #532
Karb0n
Member#: 390943
2015 Wrx
355/368
Do you think this same method would work for the 15 ? I want to do front and back badges. Unless someone is bored and wants to make a set and sell them to me lol
Karb0n is offline   Reply With Quote
Old 07-21-2014, 04:42 PM   #533
2015wrxwrb
Member#: 395264
I think this method should work as well for 2015 wrx shift knob (gear indicators). I am going to give it a try tonight.
2015wrxwrb is offline   Reply With Quote
Old 07-21-2014, 05:27 PM   #534
Ultimateone
Member#: 48025
15 Mustang GT
It does, I painted my cover to red to look exactly like the JDM/STI knob
Ultimateone is offline   Reply With Quote
Old 07-21-2014, 08:14 PM   #535
Wrbboost
Member#: 362505
on the car
what did you use to reattach the badge
Wrbboost is offline   Reply With Quote
Old 07-21-2014, 10:06 PM   #536
MRSTI28
Member#: 163534
2005 STI
CGM
i really need to do this to mine
MRSTI28 is offline   Reply With Quote
Old 07-22-2014, 12:52 PM   #537
VTenge
Member#: 370632
Stasha
3m double sided tape/adhesive from autozone/walmart works great. it is basically exactly what Subaru uses to attached the badges. just cut it to the same dimensions as is seen when you remove the badge
Old 07-22-2014, 01:54 PM   #538
VTenge
Member#: 370632
Stasha
From what ive seen of the 15 badge it looks the same with the checkered pattern and is most likely the same paint / material. Try it out and let us know!
Old 07-22-2014, 04:31 PM   #539
dpotter
Member#: 303049
Looks clean
dpotter is offline   Reply With Quote
Old 07-22-2014, 09:07 PM   #540
Wrbboost
Member#: 362505
cool, what grit sand paper did you use?
Old 07-23-2014, 09:37 AM   #541
VTenge
Member#: 370632
Stasha
I used 600 but i would recommend 1000+, 600 was the highest in stock at my home depot.
Old 07-23-2014, 11:44 AM   #542
Karb0n
Member#: 390943
2015 Wrx
355/368
Yea looks the same to me,I wasn't sure if it was mounted the same! I'm going to attempt to do the front and back badges soon. Ill post them when finished
Old 07-25-2014, 10:58 AM   #543
SeanRS203
Member#: 378600
05 Subaru WRX
Don't know if someone has already asked this. But is it possible to just remove the chrome stars and leave the paint?
SeanRS203 is offline   Reply With Quote
Old 07-25-2014, 04:11 PM   #544
Wrbboost
Member#: 362505
I'm sure you could but it would be difficult cause the chrome is the worst part
Old 07-25-2014, 05:00 PM   #545
SeanRS203
Member#: 378600
05 Subaru WRX
I want to remove the stars then put an LED light behind it so the stars will light up. If i do it I'll try to put pics up!
Old 07-25-2014, 05:06 PM   #546
Wrbboost
Member#: 362505
yea I would just sand an outline around the stars and do a LED light cause it's gonna be hard to distribute the light evenly behind just the stars
Old 07-25-2014, 05:23 PM   #547
SirRichieLee
Member#: 331655
2006 WRX Wagon
Crystal Gray Metallic
I'm sure he could set it up how they do letters that are lit up on custom motorcycles
SirRichieLee is online now   Reply With Quote
Old 07-25-2014, 06:59 PM   #548
TheMackDaddy
Member#: 383508
Very helpful, just finished doing it to my own!
TheMackDaddy is offline   Reply With Quote
Old 07-25-2014, 09:21 PM   #549
SeanRS203
Member#: 378600
05 Subaru WRX
Default How to paint your Subaru badge, both the stars and the background!
Yea the even distribution is the hard part. Idk I have replace a rear diff I found out today so this will have to go on the back burner for now sadly :/
Old 07-26-2014, 12:30 AM   #550
Wrbboost
Member#: 362505
ummm what does that have anything to do with this thread? maybe I missed something?^
How to paint your stock wheels criscross79 Interior & Exterior Modification 545 04-10-2012 06:10 PM
Video Intruction of how to debadge your SUBARU minx1225 Interior & Exterior Modification 15 03-21-2006 06:30 PM
How To Keep Your Subaru Alive (V2 Manual) NewDriverOlderRide Private 'For Sale' Classifieds 0 01-21-2006 12:43 AM
How to paint your seats reconracer Interior & Exterior Modification 62 08-26-2005 02:23 PM
How to paint your aftermarket rims? o2sys Interior & Exterior Modification 2 06-29-2005 05:51 PM
