Old 11-12-2006, 09:44 AM   #1
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
Default Hydrolock
I parked my car in my buddies steep driveway yesterday and left it there for 2.5 hours. I opened the hatch to put my stuff in the back and noticed the tank was really low. I thought, since the install is new that there could be a leak. I searched but could not find one. I figured I'd call my mechanic on Monday and he would figure it out. I tried to start it and guess what happened? It turned over a few times. I tried a second time and that was it! I'm assuming hydrolock. Today, I am going to remove the plugs and try to blowout the liquid. I hope it works. On monday I'm calling the manufacturer and going to ask why my kit didn't come with some sort of valve to prevent this? I really hope there is no damage!
Rexfan is offline   Reply With Quote
Old 11-12-2006, 10:32 AM   #2
widespread panic
Member#: 104944
What type of WI kit do you have?
widespread panic is offline   Reply With Quote
Old 11-12-2006, 02:16 PM   #3
PolarisSnT
Member#: 85905
2004 WRX
Well if there is no famamge to the motor, which you will be lucky you didnt breaka rod, a checkvalve is a simple fix. Coolingmist has a nice one that is simple to install and would prevent any of this. Good luck.
PolarisSnT is offline   Reply With Quote
Old 11-12-2006, 03:05 PM   #4
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
Snow. I dont think this kind of thing should have happened. I almost gaurantee it was NOT an install issue ( 3rd one from Snow in one week and like 8 WI in two weeks from this tuner). A professional install no doubt.
Yes, the car is fine, however there could be some sinarios that could cause a problem, but this one turns out ok. Yes, a checkvalve ftw! Going thru the Snow instructions, it looks like they fo not use a checkvalve.
c'dalerider is offline   Reply With Quote
Old 11-12-2006, 03:15 PM   #5
Ultimate Collision Center
Member#: 69072
The snow pumps do have a checkvalve built in, it is nice to install a second one in line but I have been using the snow kit for well over a year on my evo now and have not had this issue once. Let me know if you need any help with anything...sorry to hear about your situation and I hope all is well with your motor...
Ultimate Collision Center is offline   Reply With Quote
Old 11-12-2006, 06:27 PM   #6
Rexfan
Member#: 50993
02 WRX Wagon
Well, I got the plugs out and had my buddy turn the motor over a few times. I could see liquid blowing out. I put the plugs back in and she started right up. Question is, what is the best way to prime the system?
Old 11-13-2006, 03:03 AM   #7
PolarisSnT
Member#: 85905
2004 WRX
Manually ground the system yourself. For my setup, which uses a pressure switch, I just disconnect the ground going to the switch and touch it to the strut tower bolts until the nozzle sprays liquid.
Old 11-13-2006, 09:33 AM   #8
Rexfan
Member#: 50993
02 WRX Wagon
Thanks for the tip. I'm going to check with my mechanic to if if that will work with my setup. If it does, I wont have to drive 1+ to have him do it.
Rexfan
motorcycle hydrolock help... WRX4me Mid Atlantic Impreza Club -- MAIC 0 09-03-2002 04:19 PM
Might have Hydrolocked! need info please Eric SS Normally Aspirated Powertrain 15 07-18-2002 02:28 AM
Hydrolock scare!!! Eric SS South West Impreza Club Forum -- SWIC 7 07-15-2002 07:16 PM
Hydrolocked! Richard L. North West Impreza Club Forum -- NWIC 14 11-16-2001 01:19 AM
('93-'01) hydrolock? s Impreza Forum 8 04-17-2001 12:30 PM
