Old 11-12-2006, 01:38 PM   #1
devil13
Member#: 80559
2011 WRX
Question Quick fuel lines question
just installed a set of perrin fuel rail and forgot which is the feed and return. which hose goes to the fuel pressure regulator. if you are facing the fuel lines from the front: is it the top or the bottom line.
thanks.
devil13 is offline   Reply With Quote
Old 11-12-2006, 02:22 PM   #2
tdxflex
Member#: 13634
The hose from the fuel filter is the feed.
tdxflex is offline   Reply With Quote
Old 11-12-2006, 02:37 PM   #3
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
hmm his profile says 05 which means no fuel filter in the engine bay. I dont remember off hand. Find some engine bay pics from an 02 - 04 that has the fuel filter and then youll know which line is which.
snwman is offline   Reply With Quote
Old 11-12-2006, 02:41 PM   #4
devil13
Member#: 80559
2011 WRX
both lines has sometype of regulator? filter? in line. just need to know which is which?
Old 11-12-2006, 03:00 PM   #5
Jasper
Member#: 80136
2006 Ford F-150
theres no easy way to tell on an 05....i have one
ive had them off, but dont remember which is which (i think topmost line is the feed, middle is return, and bottom is the vent)
get a bucket, power up fuel pump, look for the line that fuel sprays out of (into bucket of course)
Jasper is offline   Reply With Quote
Old 11-12-2006, 05:16 PM   #6
devil13
Member#: 80559
2011 WRX
OK. I disconnected the lines(from the driver side firewall) and the bottom is the feed. So the top is the return and the middle is the evap. system? Right? So the top line(return) to fuel pressure regulator. The bottom line(feed) to brass fitting on fuel rail. The middle(evap) to blue T under intake manifold by throttle body. Please chime in if I'm wrong.
Old 11-12-2006, 09:42 PM   #7
Jasper
Member#: 80136
2006 Ford F-150
im almost 90% sure the bottom-most line is the breather that goes back to the charcoal canister.
earlier WRX's had a return-less system.
the 05's have a return line, back to the tank (which is why we dont have inline fuel filters. our "filter" is the mesh bag on the fuel pump pickup)...and because we have that return line, any crap in the lines gets sent back to the tank, rather than into the injectors.
the only way to tell for sure (without a FSM) if to prime the fuel pump, and see which line the fuel is pumped out of.
Old 11-12-2006, 11:03 PM   #8
devil13
Member#: 80559
2011 WRX
i did that and fuel came out of the bottom line. the top and bottom line has the quick connectors and the middle doesn't. so the middle is the evap line?
Quick Vacuum Line Questions fcfred Newbies & FAQs 1 03-14-2010 01:30 AM
Quick Brake line question ( Resolved) demo24 Brakes, Steering & Suspension 1 11-08-2009 10:46 PM
quick fuel line help Lachlan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-04-2007 08:41 PM
Need help quick!! Fuel line related eclone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-22-2006 09:55 AM
Evaporation Line/ Fuel Line questions Mnstr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-13-2002 03:17 PM
