Old 11-12-2006, 06:52 PM   #1
irelandbubaru
Member#: 112784
Chapter/Region: HIIC
OLD & BUSTED
Default What size injector and fuel pump?
I am looking at pushing approx. 400 to the wheels in the near future using a fpgreen turbo, what size injectors and fuel pump would be a good idea to run to support that kind of power and at the same time have room to go more on the hp if I want to? Also would it be wise to get a fuel rail? My car is a 2002 wrx.
irelandbubaru is offline   Reply With Quote
Old 11-12-2006, 10:35 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
The ej205 will be right at the edge at 400whp, and it will be a short life
Old 11-13-2006, 06:28 PM   #3
irelandbubaru
Member#: 112784
OLD & BUSTED
So are you saying that the stock fuel system could handle it? MY02 has about 33500 right know and I figured that at about 60000 miles the engine would bite the dust? What size injectors and size fuel pump would you recommend on running for this setup? Keep in mind that I am going to fun switchable boost maps so that I don't have to run the high boost require for 400 whp? thanx for the imput.
Old 11-19-2006, 11:53 PM   #4
ChgoJay
Member#: 71722
2004 WRX ZINGER!!!!
WORLDRALLYPLATINUMBLING
Your going to have a hard time hitting the 400whp mark with a Green unless your using C16 and a friendly dyno. A 255lpm walbro and modded stockers should be sufficent for that setup. Good luck.
ChgoJay is offline   Reply With Quote
WTB Turbo, Injectors and Fuel Pump, and springs hollywood12 Private 'Wanted' Classifieds 2 02-12-2007 10:29 PM
What size hose for fuel pump replacement? overdose Factory 2.5L Turbo Powertrain 0 09-14-2006 11:51 AM
MA: 02 WRX Fuel Injectors and Fuel Pump K2Skier Private 'For Sale' Classifieds 0 09-19-2003 11:33 PM
injector and fuel pump size? PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-12-2003 10:03 PM
Injectors and fuel pump upgrade whats best GC8? funscooby Normally Aspirated with bolt-on Forced Induction Powertrain 0 01-17-2002 01:42 AM
Message Board Statistics All times are GMT -4. The time now is 07:49 PM.
