Old 11-13-2006, 01:57 PM   #1
bobru
Member#: 97861
Default 1995 Impreza fuse diagram
I need to replace the fuse for my cigarette lighter; but none of the fuses aren't marked. My fuse tester does not seem to be working. Can anyone tell me where I can find a diagram for the fuse box of a 95 Impreza Sport, or at least which one is for the lighter?
Thanks!
bobru is offline   Reply With Quote
Old 11-14-2006, 01:12 PM   #2
JDMWREX
Member#: 121445
1994 JDM RHD WRX
I have been asking the same thing No one knows??? PLEASE HELP.
JDMWREX is offline   Reply With Quote
Old 11-14-2006, 09:12 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
My info shows it is fuse #3 as the one you are looking for. It is a 15 amp fuse and it also supplies power to the remote control mirror switch.
You can use a common test light probe to check the fuses without pulling them out. You will notice that the top of the fuses have a small contact on each side of the element. If the fuse is good and power is on you should get a light by touching the probe on each side of the element and the clip lead attached to ground.
Will a PS pump from a 1993-1995 Impreza fit a 1998 Impreza? ChrisRT Brakes, Steering & Suspension 2 03-11-2009 08:26 AM
Fuse diagram? keoni004 Newbies & FAQs 0 11-04-2007 05:14 PM
1999 Impreza fuse box dawoods16 Electrical & Lighting 3 11-20-2006 09:54 PM
F S 1995 Impreza coupe 1995 coupe mile hi Private Vehicle 'For Sale' Classifieds 1 07-06-2004 01:22 AM
1995 Impreza 1.8L Wiring Diagram Imprezd Normally Aspirated Powertrain 0 09-17-2003 09:16 AM
