Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Private Classifieds
Old 11-13-2006, 06:17 PM   #1
fujiwara_yingyu
Member Sales Rating: (6)
Member#: 116351
2009 CFRP GR WRB STI
2006 EVO IX MR
Default what kind of catalytic size should fit on GC?
I am going to change the high flow catalytic. I phoned the muffler supplier. They have 3 inch, two and quarter , and two and half. Which size should work on Gc? Thanks for answering my question
fujiwara_yingyu is offline   Reply With Quote
Old 11-13-2006, 09:30 PM   #2
rs_two_five
Member Sales Rating: (7)
Member#: 99206
2007 WRX wagon
02C
please don't quote me.. but.. I believe the stock cat pipe size is around the 2 1/4 size. But the problem is.. you don't just have one cat, you've got two of them. The first of them coming from the motor has a 90 degree bend within the cat itself, and the second cat (further downstream) is just a straight flow through design. Honistly.. I wouldn't really bother replacing your cats, cause you'll loose quite a bit of bottom end torque which as all us 2.5RS owners out there know.. thats about the only power we've got..
As for a decent setup, just replace your exhaust header, and the cat-back section.. it helps quite a bit top end, and you still maintain a decent amount of power down low. My setup is Borla Gen2 header with Greddy Evo2 catback and stock catalitic converters, and it sounds bloody awesome, not too loud, and plenty of rumble
Oh and just a note.. if you go equal length header, you'll loose the boxer rumble sound (ie OBX unit) but the borla is unequal length so you actually create a boxer rumble.
rs_two_five is offline   Reply With Quote
what kind of up-pipe should i get? Imprezzed22 Mid West Subaru Owners Club Forum -- MWSOC 9 07-07-2003 04:22 PM
What kind of Sparkplug wires should I get? And where? Costas Service & Maintenance 4 04-22-2003 04:01 PM
What kind of exhaust system should i use MadMatt017 Proven Power Bragging 7 02-12-2003 01:55 PM
What kind of diff. fluid should be use? Nanase Transmission (AT/MT) & Driveline 3 10-30-2001 11:08 AM
What kind of mobil 1 should I use? Ru fan New England Impreza Club Forum -- NESIC 5 04-25-2001 05:29 PM
Message Board Statistics All times are GMT -4. The time now is 08:11 AM.
