Old 11-13-2006, 09:42 PM   #1
Kuj_05STI
Member#: 131173
05 STI
Default 05 STI gauge cluster color change
Hello, i was wondering which method i need to use when changing my gauge cluster lighting for my 05 sti
if its this one.... 1.) http://forums.nasioc.com/forums/showthread.php?t=690378
or...this one... 2.) http://forums.nasioc.com/forums/show...r+color+change
would like to make sure which method i need to use before i put her under the knife so to speak. thanks guys n` gals
My cluster currently looks as following if this helps,
Kuj_05STI is offline   Reply With Quote
Old 11-13-2006, 10:06 PM   #2
Okita Souji
Member#: 41097
2005 WRX
Those other tutorials are for the WRX. I don't think anyone has ever attempted this mod for the STi cluster since the electrical design is not the same as the WRX cluster.
Okita Souji is offline   Reply With Quote
Old 11-13-2006, 10:48 PM   #3
Mechie3
Member#: 120152
The STI Uses surface mount LED's, not light bulbs. While I have never attempted to do an STI, I would think you would need to disconnect power to the LED's somehow (this may required you to individually desolder them from the board) and then you can wire in your own led's.
Mechie3 is offline   Reply With Quote
DIY gauge cluster color change. Who's happy with the results? bcWRX-02 Interior & Exterior Modification 37 04-15-2009 04:01 AM
gauge cluster color change?????? wrxtuner7 Electrical & Lighting 3 09-15-2008 03:12 PM
Lightwerkz Gauge Cluster Color Change Wind25RS Interior & Exterior Modification 0 11-26-2007 01:12 PM
gauge cluster color change question imprezaBlue Interior & Exterior Modification 5 02-05-2007 05:57 PM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 03:08 PM
