Welcome to the North American Subaru Impreza Owners Club Saturday August 2, 2014
Old 11-14-2006, 03:00 AM   #1
cbourbs
Member#: 117749
Default i heard you have to purge meth sytems?
do you have to purge meth systems every time you use it, or is it just when you park the car in the winter? Or can you just use it without doing that, i heard it was corrosive!!!
cbourbs is offline   Reply With Quote
Old 11-14-2006, 11:32 AM   #2
Ultimate Collision Center
Vendor
Member#: 69072
Its nice to purge the unit but is not 100% necessary, I don't have a purge on my system, just before I do a WOT pull I do a couple runs where I build enough boost to prime the lines...
Ultimate Collision Center is offline   Reply With Quote
Old 11-14-2006, 05:44 PM   #3
kn0bby8
Member#: 97644
2006 WRX
Recently I have noticed that when I start my car if I slam the gas my flow light doesn't light up right away. This has never happened before. Is it a winter thing? Are there aftermarket purge things that can be installed? I worry casue if I am at the track and my car sits in the stage lanes the lines will not be purged by the time I get to the line.
kn0bby8 is offline   Reply With Quote
Old 11-15-2006, 04:52 PM   #4
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Test button?
CoolRex is offline   Reply With Quote
Old 11-16-2006, 07:39 AM   #5
hippy
Member#: 36528
2002 Impreza Wrx
The only reason an n2o kit needs to be purged a lot is cause the tank is constantly being turned on and off. With a water injection system that has a solenoid or check valve, purging the system should only have to be done when the kit is first installed, and if the tank runs out of water. In all other situations, the tubing should already have water in it. Making a purge kit would not be an easy task with a pump controller based system. You'd need 2 solenoids, a switch, and a y fitting for the tubing that goes to the check valve. The the y fitting should be as close to the check valve as possible, and the switch should ground the pump and purge solenoid. The second solenoid(which stops flow of the system) would be turned on with a boost switch.
The flow light isn't hooked upto anything that detects flow. It's a light that's hooked upto a pressure sensor. Once the pressure goes above a given amount, the light goes on. The light doesn't turn on immediately because the pressure needs to build a bit first. If it's not happening as quick as before, you might wanna look into reasons why the pressure of your system wouldn't build as fast. Could have to do with the settings on your controller, the boost the car is running when the system kicks in(since your controller probably uses boost to dictate flow), and so on.
peace
Old 11-16-2006, 01:12 PM   #6
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
I was under the impression that it was, in fact, a flow sensor and not a pressure sensor. I could be wrong though. Hippy is right, you do have flow before the flow light comes on. It is just under the flow or pressure threshhold of the sensor.
bcblues is offline   Reply With Quote
Old 11-16-2006, 03:02 PM   #7
kn0bby8
Member#: 97644
2006 WRX
Originally Posted by CoolRex View Post
Test button?
Coolingmist kit have no test button! I wonder why!
Old 11-16-2006, 05:09 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
Originally Posted by bcblues View Post
I was under the impression that it was, in fact, a flow sensor and not a pressure sensor.....
Coolingmist advertises it as a "clog nozzle/flow detector" when in reality it is a pressure sensor.
peace
Old 11-16-2006, 05:19 PM   #9
CMTech
Member#: 121945
Its not really necessary, however if you want one just do this:
1) get yourself a toggle switch.
2) take one end of the rocker switch and ground it to the chasis. Take the other end and hook to the ground wire of the pump leave that wire connected to the controller.
3) the trunk mount tank will never lose its prime unless it runs out of fluid.
When you turn the switch on it will make the pump and system work. You will want to make sure the switch is off while you are running the car.
CMTech is offline   Reply With Quote
Hey OT, I heard you LOVE to do hw... smithsmithy Off-Topic 29 12-16-2008 12:38 AM
Do you have a job that you have to wash your hands before you go to the rest room? ooberdoob Off-Topic 20 10-21-2006 03:21 AM
Do you have a certain glass you have to drink out of?!?! HalfBaked Off-Topic 12 10-05-2005 11:59 PM
Do you have to have a B.A. in Business to get an MBA? Eric SS Off-Topic 15 04-19-2004 11:30 PM
Do any of you have REALLY annoying syblings you have to deal with? LinuxGuy Off-Topic 29 12-04-2003 01:08 AM
