Old 11-13-2001, 03:31 PM   #1
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
Question Help! Constant Sulphur smelll!
What can I do to get rid of it or is it something that I shouldn't worry about? I'm worried about my subie. I've given it a visual check and don't see anything amiss. What should I do next?
Robmat
Robmat is offline   Reply With Quote
Old 11-13-2001, 03:34 PM   #2
ryball
Member#: 10433
1942 Kettenkrad
WR Blue Pearl
Take a look at the owner's manual or do a search. I think that there was something about the CC causing sulfur smells with higher octane or race gas... hope that helps.
ryball is offline   Reply With Quote
Old 11-13-2001, 03:42 PM   #3
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
I have always use 87 octane.
Old 11-13-2001, 03:53 PM   #4
lempdawg
Member#: 12264
2000 Impreza 2.5RS
Pearl Blue Ridge
I also had a problem with sulphur smell. Shortly after my check engine light had come on. Went and got the code run and the told me it was the O2 sensor. Apparently there was a recall on the 2000 Impreza 2.5RS for the O2 Sensor. The problem went away for about 20k miles but the check engine light came on today and the O2 sensor was the culprit. To bad it's no longer covered under my warranty any more.
lempdawg is offline   Reply With Quote
Old 11-13-2001, 04:53 PM   #5
RaceCarRiot
Member#: 6542
1997 Ver IV
i dunno...my car is developing this funny burning smell every time i drive it...
it used to be an occasional thing, like if i ran on the highway for a long time in hot weather, but now i can smell it every time i get out of the car...it was even tricking in through the vent on low speed when i had the windows up this morning.
it smells like sort of like oil, but i'm not burning any, so i don't think it's that...what does mobil 1 smell like if it starts to burn? or is that even a problem with synthetic?
argh. the car is running fine as always, but i smell it everytime i park it and get out...
-adam-
RaceCarRiot is offline   Reply With Quote
Old 11-13-2001, 06:04 PM   #6
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
I have already had the O2 sensor replaced and not too long ago. The car seems to run fine, it just smells bad
Robmat
Old 11-13-2001, 07:23 PM   #7
joltdudeuc
Member#: 6119
1999 GM6
RBP
i got that smell also... i'm gonna repalce my cat(s)...
(i don't know if i have one or two!)
-Gagan
joltdudeuc is offline   Reply With Quote
Old 11-14-2001, 12:07 PM   #8
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
-Gagan
you have two.
Tkacik is offline   Reply With Quote
Old 11-14-2001, 02:13 PM   #9
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Robmat, give us the whole story... I'm guessing you just recently put your STi exhaust on with a new custom midpipe?
I had the same problem with sulfur smell for about 2 weeks then it was gone. Had to do with the treatment material on the SS midpipe. I wouldn't worry unless it never goes away in a month or so.
Jon
omahasubaru is offline   Reply With Quote
Old 11-14-2001, 03:02 PM   #10
whitt
Member#: 8928
0216 02 WRX & 16 WRX
White & Lapis Blue
Default Yup
Hopefully it goes away, but if it is not a new exhaust system it sounds like the cats, when the material in them is used up it begins to smell like sulfer, not all bad though this could be the perfect time to put on a high flow cat
good luck
DW
whitt is offline   Reply With Quote
Old 11-14-2001, 03:02 PM   #11
Blindeye_03
Member#: 4418
2016 Focus ST
Have a look at your cat(s).
-justin
Blindeye_03 is offline   Reply With Quote
Old 11-14-2001, 03:34 PM   #12
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
It is a new (used though) muffler and new midpipe, but I had this smell before the new parts. How can I phsically tell if it is the cat(s)? I'm headed in for service Friday, so I will ask the dealer as well.
Robmat
Old 10-12-2009, 09:33 AM   #13
ChildrenOfNiobi
Member#: 185847
What would you all consider a "normal" mileage to replace the cats? My Tribeca has about 35k miles and yesterday I started it and it started to reek of sulfur immediately.
Is that an expensive service to have done?
ChildrenOfNiobi is offline   Reply With Quote
Old 10-12-2009, 06:23 PM   #14
GrundleJuice
Member#: 165749
more than 35k... but lots of things may effect the life of the cats. i would verify that there are no other problems before messing with the cats @ 35k. Have been using odd-ball gas or messing with the tune or anything?
Old 10-12-2009, 07:46 PM   #15
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
+1.
I ran my CAT's until ~150K miles until I finished upgrading the exhaust and using new HFC's.
My wifes 99 Impreza L (2.2L) has ~110K miles on the OEM CAT.
Emission parts should last 100K + miles, this is a US Federal mandate!
motor swap help STI longblock into a Legacy gingertooth Legacy Forum 6 06-01-2010 09:16 PM
Dran-o? Mr. Plumber? Concentrated sulphuric acid? Asinine Off-Topic 58 10-10-2007 05:17 PM
Subbie survives in Sulphur, La for four days, and rolls over a 100k in the escape Tex-WReX Texas Impreza Club Forum -- TXIC 9 09-27-2005 12:08 PM
Oil Smelll LyveWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-12-2004 08:17 PM
Help! Constant backfiring DJ626 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 02-02-2003 07:53 PM
