Old 11-14-2006, 09:47 AM   #1
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Default What value do you run for your upgraded injectors?
I have modded stock injectors and im using the utec to scale for the stock ecu. I have tried in the past to simply reflash the stock ecu and it worked but it didnt work with a value of 850 in there, I had to put 672 in order for the trims to hover around zero. Also it felt like the car was jittery.
I am wondering what others are using for their injector size when reflashing, and what size the injectors actually are that are being installed.
Thanks in advance,
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 11-14-2006, 09:53 AM   #2
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
This is MRF's MAF table that will give you a SOLID idle and very good fuel trims:
http://forums.nasioc.com/forums/show...dded+injectors
He uses an injector value of 783 which is required to use his MAF table.
I am using this, along with a few others and it works well for all cars as long as you reach the requirements which are:
-stock airbox
akira02rex is offline   Reply With Quote
What DP do you run with your Cobb CBE? 02bugeyeWRX Newbies & FAQs 7 05-03-2009 12:11 PM
What DP do you run with your Cobb CBE? 02bugeyeWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-02-2009 10:30 PM
Just curious, what oil do you run in your built motor? PirateSanchez Built Motor Discussion 32 04-21-2009 10:15 AM
What psi do you run in your tires? gtbensley General Community 61 06-01-2008 07:35 PM
What DP do you run with your 06 wrx/sti? Mooneyes13 Newbies & FAQs 44 02-21-2007 11:41 AM
