Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 11-07-2012, 10:28 AM   #1
Aceitup1011
Member#: 337225
2013 XV Crosstrek
Tangerine Orange
Default front strut bar help
Could i get some measurements from some of you.
I'm looking to see what the distance is between the strut s.
I'm looking for a front strut bar but want to make sure they will fit first.
As i have a 2013 crosstrek, i want to see if they will match up.
If some of you could measure the distance between corresponding bolts that would be great.
Aceitup1011 is offline   Reply With Quote
Old 11-07-2012, 11:52 AM   #2
Wicked Performance
Member#: 265606
Front strut bars for the GD chassis are a dime a dozen, Im sure someone could let you test fit one. We take them off all the time when they run into clearance problems with other more useful upgrades.
You didnt ask, but Ill tell you a front strut bar does next to nothing on most subarus (besides the aesthetic appeal)
M@
Wicked Performance is offline   Reply With Quote
Old 11-07-2012, 12:27 PM   #3
WRXLTD
Member#: 136314
2014 Grand Cherokee
^ +1
Get a lower brace instead...you WILL feel a difference with it.
WRXLTD is offline   Reply With Quote
Old 11-07-2012, 12:31 PM   #4
Wicked Performance
Member#: 265606
OP has a crosstrek, im sure NOONE knows what fits these yet lol
Old 11-07-2012, 01:02 PM   #5
Aceitup1011
Member#: 337225
2013 XV Crosstrek
Tangerine Orange
M@
Thanks for the head s up.
Now more about this brace bar under neath?
Old 11-28-2012, 03:53 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
It's called an H-brace. I've heard they work great too, however, the bolts need to be tighted to like 150+ lbs or something. Given their location, this is something a lift may be better suited for. It's important to keep those tight.
But also remember, for the newer models ('08+), I'm sure they don't have these supplied by eBay vendors yet.
cmiovino is online now   Reply With Quote
Old 11-28-2012, 05:18 PM   #7
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Save your money, don't get a front bar. Use your money some place else.
Bikelok is offline   Reply With Quote
Old 11-28-2012, 08:32 PM   #8
Vaughn Performance
Member#: 170489
It was said somewhere, that Subaru actually gave the Crosstrek a much more reinforced chassis then the standard Impreza already, to better put up with offroad abuse one would assume. I doubt there is any bracing out there period for this car, let alone any that would yield any substantial improvements.
What is it your trying to get your Crosstrek to be better at?
-Anthony
Vaughn Performance is offline   Reply With Quote
Old 11-29-2012, 12:31 AM   #9
Aceitup1011
Member#: 337225
2013 XV Crosstrek
Tangerine Orange
-Anthony
I guess cornering, taking sharp turns but after driving around more and more I'm thinking i don't need one. Guess it was more of an impulse thing.
Old 11-29-2012, 01:00 AM   #10
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
M@
i actually found that a PROPER front strut bar(a 'solid' one piece one, no joints) was a great mod for the gd chassis.....ESPECIALLY when combined with a lower arm bar and hd cowl stays and other than stock front strut tops
my 02 creaked and groaned and popped quite a bit going down a friends unpaved driveway.....added the front tower bar and my friend, who was the most 'un-car' guy i ever knew, noticed the difference immediatly and said the car felt 'more solid' than it had been...and NO creaks or pops or groans anymore.... wonder why??
the front end of the gd chassis is as stiff as an over cooked noodle ...look at how far the firewall deflects on a gd when you push hard on the brake pedal that is why a mc brace improves the brake feel so much
...dunno as much about the gr...but there are a good few that have had cracked firewalls....maybe something to RECONSIDER in your modding approach
Old 11-29-2012, 05:32 PM   #11
Vaughn Performance
Member#: 170489
The normal cornering stuff, i.e. larger swaybars firmer springs etc....... would work out to improve tarmac handling, but might inhibit it a bit off road. Larger swaybars would loose some wheel independence, though they would probably help greatly on paved road. Though I suppose you could always unhook the swaybars for off road if you wanted. I run 22mm front/rear bars on my wagon for tarmac, and unhook the front bar for RallyX
So that's a upgrade you could consider. I haven't messed with a Crosstrek yet, I know the normal standard Impreza accepts WRX parts. Haven't looked at a Crosstrek close enough to see if all the underpinnings are the same, though I suspect they are.
-Anthony
Old 11-30-2012, 12:37 AM   #12
Aceitup1011
Member#: 337225
2013 XV Crosstrek
Tangerine Orange
Thanks for all the replies everyone....
Anthony very helpful thanks
