Old 11-14-2006, 08:50 PM   #1
wrxgti
Member#: 102908
2002 WRX Wagon
WR
Default 16g helpppp
so i got this super 16g turbo from a friend who was going to put it on his talon and it has a different exhaust housing inlet/outlet, than the reg suby, how can i mate it up to our up pipe/downpipe without fabricating new flanges on the dp and uppipe? are there adaptors? this is what they look like.
wrxgti is offline   Reply With Quote
Old 11-15-2006, 02:41 AM   #2
quezanart
Member#: 83072
2016 WRX
Lapis Blue Pearl
Compare that turbos layout to your stock TD04, or even pictures of bolt on suby turbos. I'm not an expert but from the looks of it you are going to need more than just flange adapters, you're going to need custom piping as well. It also looks like the compressor side outlet will not mate up to the stock suby setup.
I think you're going to need to do a lot of customizing to get this turbo to work in a suby. Perhaps someone with greater expertise than my own can correct me if i am wrong.
quezanart is offline   Reply With Quote
Old 11-15-2006, 05:51 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...'aint happenin.......and stop cross posting
Old 11-15-2006, 10:43 AM   #4
WReXd
Member#: 114101
93 Impreza L Swap
It'll take so much money, it's not worth it. Sell it and buy your own suby-made 16g.
WReXd is offline   Reply With Quote
Old 11-15-2006, 02:34 PM   #5
prometheum
Member#: 92003
04 bicycle!
not happening, see if you can get wrx flanges from deadbolt
prometheum is offline   Reply With Quote
Old 11-15-2006, 02:39 PM   #6
rexspeedmaster
Member#: 123103
2003 WRX
Full 07 STI trans
that is so much different from a bolt on turbo to a WRX. my suggestion would be to sell it and buy a 16g made for a wrx. they are probably around the same price.
rexspeedmaster is offline   Reply With Quote
Old 11-15-2006, 03:52 PM   #7
CynicX
Member#: 48199
06 WRX
You need :
Definately not worth the time and effort unless you are just one of those people determined to make something work....
BTW thats a TD05H-16G-7cm2 pictured from www.forcedperformance.com for 699.00, pretty standard. Unported, 510 CFM which they will upgrade for you (ported, big16g, evo3 16g, even 18g) for a charge. But its a direct bolt on....
Good Luck...
CynicX is offline   Reply With Quote
TD05 Evo III 16G 2_Liter_EJTurbo Pre-2002 Factory Turbo Powertrain 5 06-06-2010 09:38 AM
*Help* I need help choosing the better 16g..TD05 Big 16g or FP 16g or EvoIII 16g? min88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-04-2009 12:38 AM
Setup Apexi S-AFC II !! Helpppp EstebaN WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-21-2004 03:12 PM
will vf22 solve boost creep? HELPPPP pierceman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 11-20-2003 01:17 PM
('93-'01) need to set up a deal, but PMs are gone helpppp Sin Impreza Forum 2 06-07-2001 10:58 AM
