Vancouver Impreza Club
Old 11-13-2006, 03:11 PM   #1
jlam86
Member#: 86822
2004 WRX
Default rsb interfering with control arm
Last night, I decided to stiffen up my whiteline adjustable sway bar to it's max as I was already in the second to last setting. Now, when I jack the car up to the point that the rear wheels lift off the ground, the sway bar will interfere with the lateral link. I'm just worried that when I take my car in for servicing, they may not know and jack the car up and wreck something. Is this normal??
Last edited by jlam86; 11-13-2006 at 10:17 PM. Reason: lateral arm not control arm
jlam86 is offline   Reply With Quote
Old 11-14-2006, 03:51 AM   #2
buster
Member#: 41811
02 WRX
Mine barely grazes it if I set it on 26. keep in mind that is with your suspension fully extended.
buster is offline   Reply With Quote
Old 11-14-2006, 12:56 PM   #3
jlam86
Member#: 86822
2004 WRX
when I have my car raised then install it, the swaybar will rest against the lateral link and won't even lower my car back to it's original position. I had to install it with the car on the ground, but assisted with a jack.
now, when raising it, after a certain point, it will rest on the lateral arm and that is my main concern.
thanx for the input buster
Old 11-14-2006, 04:38 PM   #4
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Just so you know, you are supposed to install swaybars with the vehicle on the ground and the suspension under load. Otherwise you're going to have problems. Try reinstalling it without the jack.
chrisarella is offline   Reply With Quote
Old 11-14-2006, 04:45 PM   #5
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Ramps come in handy when dealing with swaybars.
Mirage is offline   Reply With Quote
Old 11-14-2006, 04:53 PM   #6
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
+1million
Old 11-14-2006, 04:59 PM   #7
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
OR if you're too cheap to buy ramps, you can always try to park with one wheel up the rounded-end of the sidewalk driveway. Your car will be tilted to one side, but you should have enough clearance to get underneath your car.
Just a suggestion. Of course, you yourself bear all responsibility if you do decide to try to work on your car in this manner.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 11-15-2006, 12:01 AM   #8
jlam86
Member#: 86822
2004 WRX
i've got it ont he car and have no issues with its' operation. My main concern is that if i take the car to a mechanic and they are unaware of the rear sway bar hitting the lateral link, will it damage it? or will the swaybar resting against the lateral link not too big of a deal?
sorry if this question seems noobish
Old 11-15-2006, 12:04 AM   #9
buster
Member#: 41811
02 WRX
I would think it will be fine, the most it would do is rest on it. If you were jumping and it extended quickly it might hit it hard.......but then we aren't doing that so nevermind.
Old 11-15-2006, 12:10 AM   #10
jlam86
Member#: 86822
2004 WRX
ye I anticipated that but i'm not flying off curbs so for it to be that extended, it's will be slim to none. thanx
WTB:04-07 STI front control arms... WRXCutiee Private 'Wanted' Classifieds 0 06-03-2010 03:39 PM
FS: STi Control Arm, OEM Control Arm, STi Transverse Links, '02 WRX OEM Suspension shoooter_j Suspension/Brakes/Handling 3 01-23-2008 11:11 PM
rsb interfering with lateral link jlam86 Brakes, Steering & Suspension 20 12-21-2006 11:00 PM
rsb interfering with control arm jlam86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-14-2006 04:12 PM
Cusco GF RSB, 2pot rear brakes, adjustable rear control arms, GF roof rails tbd Private 'For Sale' Classifieds 8 02-29-2004 05:57 PM
