Old 11-15-2006, 01:07 AM   #1
bwawuz
Member#: 100424
2002 WRX Wagon
Default MY02 Wagon: New clutch...problems...need help
MY02 wagon
i just changed my clutch to a spec stage 2, and installed koni's/gc coilovers/mrt camber plates (in the garage with hand tools, it sucked). suspension feels solid. problem is when i let off the gas there is a sound developing into vibration in the rear end. sounds like the driveshaft might not be lined up i think, but i marked the driveshaft and rear diff with paint as per the subaru manual. did i miss something in aligning the driveshaft? as soon as i put the clutch in the sound ceases. it's more of a low tone more vibration at 40mph in 4th gear. i also jacked the rear end up by the rear diff and was wondering if that might have hurt it. i'd jacked up E30's at the rear diff before so i didn't think it would be a problem on the rex. also, when i get on it and shift at 6k rpms when i put the clutch in there is a slight slapping sound as if there's something loose in the drivetrain. Please help, sry if i sound like a newbie.
bwawuz is offline   Reply With Quote
Old 11-15-2006, 12:36 PM   #2
bwawuz
Member#: 100424
2002 WRX Wagon
any takers? i really need to get this fixed.
Old 11-15-2006, 12:47 PM   #3
elsanto
Member#: 34832
1989 M3
did you put a lightened flywheel in also per chance?
elsanto is offline   Reply With Quote
Old 11-15-2006, 01:12 PM   #4
bwawuz
Member#: 100424
2002 WRX Wagon
no sir. stock flywheel, new pilot bearing. fyi, spec stage 2 is definitely more grabby than stock, but not too bad, takes a lil different driving style.
after much reading it seems that the slapping/clunking sound might just be the normal subie rear subframe setup, am i wrong in that assumption?
Old 11-15-2006, 02:17 PM   #5
Bolster
Member#: 22290
2002 WRB WRX Wagon
You didn't hurt the car jacking it up by the rear end. That's for sure.
Bolster is offline   Reply With Quote
Old 11-17-2006, 01:37 AM   #6
bwawuz
Member#: 100424
2002 WRX Wagon
bummp
Old 11-17-2006, 09:32 PM   #7
koblerone
Member#: 128587
2002 wrx
black
...when I first installed my new clutch I had the exact same problem. I didn't resurface my flywheel. I just tried to sand it as evenly as possible with an orbital sander. I think this caused the clutch to be too grabby at first and the car shook like hell when I would slowly release the clutch with no gas. The rear diff. shook the most. After about 200 miles it went away completely.
koblerone is offline   Reply With Quote
Detailed description of my clutch problem need help Norcalrallyist Subaru Conversions 1 10-04-2006 08:59 AM
Clutch problems, need help pinter Transmission (AT/MT) & Driveline 6 07-14-2005 05:52 AM
clutch problem - need help Willis Normally Aspirated Powertrain 8 05-04-2001 06:11 PM
('93-'01) Clutch problem need help dvs81n Impreza Forum 0 04-24-2001 06:13 AM
('93-'01) clutch problem, need help. Scooby25 Impreza Forum 3 04-14-2001 02:58 PM
Message Board Statistics All times are GMT -4. The time now is 06:54 AM.
