Old 11-15-2006, 05:00 PM   #1
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Default Can I put a pump/pinks in at Cobb STG2?
Let's say you only have one vehicle and can't afford too much downtime, is it possible to go to stage two one weekend...then maybe if you get a chance during the week put in the fuel pump, then maybe a diff day put in the injectors? that way the following weekend you could throw on the turbo and intercooler? rather than trying everything at once?
Matth3w is offline   Reply With Quote
Old 11-15-2006, 05:10 PM   #2
slickrex
Member#: 89983
2005 vf39'd wrx
295whp stealth black
the exhaust parts shouldnt be a problem and neither would the fuel pump but the injectors would have to be tuned for so its not possible to drive around with them w/o a tune. im not sure about the turbo but i believe if you stay out of boost it would only be a more of a PITA to drive around in limp mode than just installing them all at once and getting a tune.
specifically what kind of injectors, turbo, and i/c?
slickrex is offline   Reply With Quote
Old 11-15-2006, 05:12 PM   #3
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
the exhaust parts definately wont be a problem, because i will run the 93 stg2 map from cobb once they are installed.
the end result is going to be a vf39, sti pinks, walbro pump, fmic, and one step colder plugs...and the exhaust and cobb ap of course. i am going to have a pdx ots map.
Old 11-15-2006, 05:15 PM   #4
dvang
Member#: 84188
05 legacy
caravan full of kids now
put on turbo and the injectors at the same time
injector install time 45mins
dvang is offline   Reply With Quote
Old 11-15-2006, 05:18 PM   #5
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
what about the intercooler...can i do this order:
1) exhaust (up, down pipe, cbe)
2) stg2 93oct cobb map
3) fuel pump
4) FMIC
5) turbo/injectors/plugs
Old 11-15-2006, 05:51 PM   #6
Farnsrocket
Member#: 83567
08 Outback
Obsidian Black Pearl
Possible? Yes.
Smart? No.
Farnsrocket is offline   Reply With Quote
Old 11-15-2006, 05:55 PM   #7
dvang
Member#: 84188
05 legacy
3) fuel pump
4) FMIC
if you have the uppipe off then throw your new turbo on
injectors are done pretty quick
do the fmic/ fuel pump/ plugs when conveniant
Old 11-15-2006, 06:05 PM   #8
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
Doing the turbo by itself would take almost the same amount of time as doing the turbo, up, and downpipe all together. I would do them all at once.
athakur999 is offline   Reply With Quote
Old 11-15-2006, 07:09 PM   #9
hondaeater69
Member#: 60324
you can do pretty much everything except the turbo and injectors without flashing the new map.
ya can't run bigger injectors without the new map.
and you shouldnl't run a larger turbo with the reflash of the new map.
Old 11-15-2006, 07:30 PM   #10
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
yea thats why i decided to do the turbo last.
Can I put PIAA driving lamps in fog light location? BEETROOT Interior & Exterior Modification 6 07-25-2009 07:53 PM
Can I put all "GM Synchromesh" in my tranny? Jaredm83 Transmission (AT/MT) & Driveline 52 04-03-2009 02:22 PM
Can I put 97 a ej25 in a 99 legacy? trinistyles Subaru Conversions 7 03-10-2009 10:06 AM
18g vs 20g compressor housing. Can you put a 20g wheel in a 18g compressor housing? NITROS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-17-2009 07:01 AM
Can I put 04+ Wagon tails in my 04+ sedan? electronfrost Newbies & FAQs 4 05-16-2005 05:39 PM
