Alaskan Impreza Club
Old 11-15-2006, 05:01 PM   #1
Tommy V
Member#: 117284
2003 WRX Sedan
Default Is it worth re studding tires????
I just bought a set of tires and they could use a new set of studs. They got lots of rubber (tread) on them. Is it worth it? How much? Where should I go? Any thoughts?
Tommy V is offline   Reply With Quote
Old 11-15-2006, 05:29 PM   #2
edo2000
Member#: 68709
2012 WRX
red
I'm not an expert, but I don't think many shops do this anymore. It would require drilling holes and installing the studs. I had a set of worn studded tires that I wanted to use for summer on my pickup. The tire shop I talked to quoted me $30/tire to remove the studs... I ended up doing it myself.
To restud tires would probably considerably more, not sure though. Good luck.
edo2000 is offline   Reply With Quote
Old 11-16-2006, 03:36 PM   #3
akryder86
Member#: 74916
2011 WRX Hatch
Obsidian Black Pearl
Call Alaska Tire and Rim at 563-4398. They are located on Potter Drive. They are normally pretty good about there prices and I know they stud tires not sure if the restud though.
akryder86 is offline   Reply With Quote
Old 11-16-2006, 03:51 PM   #4
kyleblix
Member#: 73495
Audi Q5, Ford Raptor
post up the quote if you get one. i'd be interested to see what this cost
kyleblix is offline   Reply With Quote
Old 11-16-2006, 03:57 PM   #5
xplcitcustmz
Member#: 82935
1972 Ford pinto
Astro Turf
you can stud your own tires, ill bet if you guys pitched in 10-15 bucks you could buy a stud gun and do your own, i use to stud tires when i worked at Johsnon Tire, WORST JOB EVER, good money, 1.00 per tire, you could do close to 20 tires an hour though which is nice. The guns run on air compressors, or some are electric.
xplcitcustmz is offline   Reply With Quote
Old 11-19-2006, 03:14 AM   #6
Jaylyons1
Member#: 113884
2013 BRZ
kinda late, just saw the post...
i should buy one of those and start my own studding business ^_^ Be a good side job
Jaylyons1 is offline   Reply With Quote
Old 11-19-2006, 05:47 PM   #7
edo2000
Member#: 68709
2012 WRX
red
I noticed an ad in the Daily News classifieds on Friday, under the 'Tires' category- restud your used snow tires for $30/each. I can't remember the vendor's name, might have been Alaska Tire and Rim.
Is it worth heat cycling street tires that get used on the track 2x year? Fred Fredburger Tire & Wheel 14 09-30-2007 09:59 PM
Bigger plug spark...is it doable? Does it hurt things? Is it worth it? kaisersouse Normally Aspirated Powertrain 8 01-27-2006 06:35 PM
Winter tires... is it worth it? WRXVII Tri-State Area Forum 18 11-04-2004 09:33 AM
Do I need to do anything special before I re-install win XP? is it worth it to do? Eric SS Off-Topic 14 09-18-2003 05:16 PM
Is it worth autoXing on RE-92s? ezatnova Brakes, Steering & Suspension 22 01-17-2002 05:02 PM
