Old 11-15-2006, 08:05 PM   #1
tokstad
Member#: 113903
World Rally Blue
Default Noob question on flashing back to stock
I tried searching but didn't find much. I have a 2002 that I want to flash to stage 2, I was thinking of buying the tactrix cable and the XPT stage 2 map.
From what I've read it's possible to flash the OEM ECU ~100 times. So doing this and then going back to stock shouldn't be much of an issue in theory.
My concerns are:
1) If I go stage2 (but save my stock map) then flash back to the stock map before taking the car in for service, will this void my warantee? Will they be able to see the ECU has been comprimised?
2) Has anyone had any problems (performance or ECU wise) flashing their ECU to the stage2 map XPT
http://www.plasmatize.com/osecuroms/...asc&highlight=
3) Does this pose any long term risk to my ECU (permanent damage)?
Thanks...
tokstad is offline   Reply With Quote
Old 11-15-2006, 11:20 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Here is a quote from the Enginuity Forums on the reflash limit:
Originally Posted by ev8siv3
I'm pushing over 2500 flashes, I do about 5-10 a day when developing maps.
consensus is that the 100 reflash limit is a myth. going 25x that limit with no problems seems to prove that.
1. No they should not be able to tell that the ecu has been reflashed if you copy your stock map beforehand.
2. I haven't heard of any problems but I would check osecuroms.org for those.
3. There are some risks such as. If your computer crashes while reflashing, you could end up with a dead ecu but as long as you leave the car on and the computer connected you may be able to save it. If the battery voltage is too low, could have a reflashing problem. I check the battery voltage with ECUExplorer before I reflash any car to make sure it is above 12 volts.
Old 11-16-2006, 09:02 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
It probably sold ALOT of AP's though!!!
Old 11-16-2006, 11:06 AM   #4
Master2192
Member#: 83254
98 2.5 RS
04 WRX
I am not so sure, I know a guy that sold his AP and went UTEC because of the reflash "limit"
Problems flashing back to stock... THEVERGE Open Source Reflashes 4 12-21-2007 12:20 AM
Flash back to stock question (gutted uppipe) Humboldt wagon Newbies & FAQs 12 10-26-2007 09:57 PM
need help on flash back to stop on ap wrxraaca Engine Management & Tuning 1 01-12-2006 03:05 PM
Can ecutek be flashed back to stock?? MachinesWRX Engine Management & Tuning 1 11-30-2005 08:20 AM
can eku-tek flashed ecus be flashed back to stock programming? dothespeedlimit Engine Management & Tuning 2 03-29-2004 01:22 PM
