Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 11-16-2006, 11:08 AM   #1
NYCshopper
Member#: 5126
Default Road Test: 2007 Nissan Altima 3.5SE (Car & Driver)
http://www.caranddriver.com/roadtest...tima-35se.html
Unruly no more. Famous for its torque-steering tantrums, this mid-sizer gets even more power and straightens up its act.
Could downsizing be the fashion once again? It is at Nissan. This new Altima is fresh off the chopping block.
With high gas prices, itís logical to think that automakers are reaching for a quick mpg improver. But fuel was still cheap when the new-in-2002 model returned to the incubator for its next-cycle redesign. And Nissan had a different goal: Ramp up the sporty feeling that separates the Altima from its more reserved Camry and Accord competitors. Nissan wanted quicker responses, more agility, and easier maneuvering in the metro madness.
So the wheelbase was abbreviated almost an inch, and nearly three times that much came off overall length. Width is up a fraction, height stays the same.
And sportiness? If you choose the SE version with the 270-hp V-6 and six-speed manual, hang on. Engine output is up 20 horsepower in the advertising but more in the car, thanks to the deflationary effect of the latest SAE rating system. Weight, at 3357 pounds, is 137 more than the Altima we tested in February 2003. Thinner sections of higher-strength steel bring a stiffer structure ó you can feel the difference ó with a small weight increase.
The stronger engine easily makes up for the extra pounds. Getting from 0 to 60 at 5.9 seconds ties the 2003 car; the new one runs away in the quarter-mile, finishing at 99 mph (96 in the older car). Elapsed time for both cars is the same, 14.6 seconds. Fuel economy is up 1 mpg on the highway compared with the old base model, to 21 city and 29 highway, creditable for a mobile with this much zing.
The big news is not the numbers, however. The V-6 Altima has always been powerful, and itís always been nasty for torque steer in the lower gears. Enough already, Nissan decided. The fix: Lower the powerplant 0.6 inch to level the half-shafts and equalize the joint angles side to side. Steering geometry is also significantly revised.
The 3.5 has torque enough to easily buzz the tires on launch. But thereís little tugging on the wheel now and little deviation in the path when the power goes down. Unruly no more, this front-driver.
V-6 Altimas come in SL and SE versions. SE, the sporty choice, has a stiffer suspension calibration with crisp-riding shocks. Its wheels are up one inch in diameter and wider by a half-inch to 7.5. It gets lower-profile 215/55R-17 all-season tires and faster-ratio power steering. Steering effort now rises with speed, a first for the Altima. Over the road the ride is reassuringly quiet, a pay-off for the newly stiffened structure, but the shocks donít hide the bumps. Compared with the SL version, the SEís moves are muscular. The seat is on the hard side with very good lateral support in the backrest. The left-foot dead pedal is perfect.
We measured 0.81 g on the skidpad, with determined understeer at the limit. The independent rear suspension was redesigned for less jacking and better control of roll-rate changes. As cornering forces rise, the car is less twitchy now.
Four-wheel discs are standard, stopping from 70 mph in 180 feet. Nissan changed its brake-pedal linkage to what it calls a double-pivot design, this to keep the brake response similar in both hard and easy stops. It works. Pedal response is agreeably linear, never touchy.
Too bad the same cleverness hasnít been applied to the clutch and shifter. The clutch has an unsatisfying effort curve as the pedal comes up, making it harder than it should be to anticipate engagement, and the shifter clunks through its prominent detents. The Altima is no BMW in this regard; no Honda, either.
The outgoing Altima was a huge success for Nissan, lifting sales from 137,000 of the older, smaller-bodied version in 2000 to 255,000 last year, making it the fourth-highest-selling car in the U.S. Hoping to continue this impressive conquest into Camry-Accord territory, Nissan has endowed this new model with a strong features list, starting with standard-equipment keyless entry and pushbutton starting. No huzzahs from us on this item ó with the ignition keyhole gone, the bulky fob now takes up a cup holder. From an ergonomic standpoint, the fob shape is too susceptible to getting its buttons inadvertently pushed in routine handling. Who popped the trunk?
Other upgrades: Door and center-front armrests are padded now; front and side airbags plus curtain restraints are standard equipment; the front seats have active head restraints for rear-impact protection; trunk space is up 15 percent to 18 cubic feet, very large for the class; the glove box has been enlarged to steamer-trunk dimensions; and the dash and door-panel textures are exceptionally classy. In the back seat, headroom is down by 0.8 inch, legroom is up 3.1. The cushion sits low.
Although the instrument cluster still shows you three dials, the annoying, seemingly misaligned tunnels are gone, replaced by a single-lens grouping of much improved graphics. Weíre less smitten by the exterior. Most peculiar is the way the front view gets into an argument with the side view when they meet in the front fenders. Thereís nothing cautious about the Airbus-theme taillights, either.
Not that we think me-tooing the Camry is the best way to compete with Toyota. This Altima is brave in its styling, thorough in its equipment list, refined in its manners, and it responds to the spurs with gusto. There will be a hybrid version early next year, too. Jet-taillight lovers, your car has arrived.
NYCshopper is offline   Reply With Quote
Old 11-16-2006, 11:08 AM   #2
NYCshopper
Member#: 5126
Old 11-17-2006, 03:06 AM   #3
mountjonas
Member#: 93859
2013 Appliance
6MT
not bad, but that steering wheel design makes it look wide.
mountjonas is offline   Reply With Quote
Old 11-17-2006, 03:36 AM   #4
02redwagone
Member#: 87067
02 Old but tasty
SRP
Very nice sporty family car. The steering wheel reminds me alot of the one in my 02.
02redwagone is offline   Reply With Quote
Old 11-18-2006, 04:54 AM   #5
fastwrx25
Member#: 126441
03 bugeye
Thats a nice looking interior.
Not a fan of the exterior looks though...
fastwrx25 is offline   Reply With Quote
Old 11-18-2006, 07:39 PM   #6
rice h8r
Member#: 94524
^ + 1 on the outside being eh.
seems like a good car, got rid of the torque steer FTW!
NYCshopper, why do you use your time to quote all these mags and whatnot and to take the time to post all the pics from the gallery? Seems like you put a LOT of time into posting all these threads for us. I've been always curious WHY you do it... I know you said you have a lot of free time but you could do other things?
I'm just curious, not saying anything bad. I'm sure everyone, including me appreciates you giving all this info to us. NYCshopper for News and Rumors mod!!!!!!!
rice h8r is offline   Reply With Quote
Old 11-19-2006, 10:15 PM   #7
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
Really like the new center console and the new dash.
Old 11-19-2006, 10:52 PM   #8
Chiketkd
Member#: 71634
In hibernation...
+1 Interior looks hot, but the exterior? The front end looks bland...and those tail lights!
Chiketkd is offline   Reply With Quote
Old 11-20-2006, 05:32 AM   #9
fastwrx25
Member#: 126441
03 bugeye
word word!!
the tail lights and rear remind of the new mitsu eclipse.......and the eclipse is very ugly
Old 11-20-2006, 08:48 PM   #10
Eyeflyistheeye
Member#: 69694
2014 EuroPinto 5MT
w3rd!
Eyeflyistheeye is offline   Reply With Quote
FS/FT: 2002 Nissan Altima 3.5SE d r i v e n Private Vehicle 'For Sale' Classifieds 5 01-04-2010 07:48 AM
Tested: 2008 Nissan Altima 3.5SE Coupe (Car & Driver) NYCshopper Non-Subaru News & Rumors 18 05-22-2007 03:51 PM
Road Test: 2007 Nissan QASHQAI (4car UK Site) NYCshopper Non-Subaru News & Rumors 2 01-18-2007 02:52 PM
Full Test: 2007 Nissan Altima 3.5 SE (edmunds.com) NYCshopper Non-Subaru News & Rumors 4 12-25-2006 07:00 PM
Road Test: 2007 Nissan Sentra by Motor Trend NYCshopper Non-Subaru News & Rumors 0 11-01-2006 08:14 AM
