Old 11-16-2006, 01:31 PM   #1
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Default How do I Clean the Crank Position Sensor?
How do I clean the crank position sensor? Do you just remove the alternator cover, then you're able to access the sensor? Or do you have to remove the sensor? Also, what do I use to clean it?
bcblues is offline   Reply With Quote
Old 11-16-2006, 02:16 PM   #2
x99percent
Member#: 27108
2004 STi
2004 A4
http://forums.nasioc.com/forums/show....php?t=1137751
One 10mm bolt holds it in. Unplug it, take it out, wipe it off, reinstall.
If it's really dirty, figure out WHY (leaky front crank seal or oil pump?).
x99percent is offline   Reply With Quote
Old 11-16-2006, 02:48 PM   #3
dmross
Member#: 2818
2000 2.5RS
Um, isn't it magnetic?
dmross is offline   Reply With Quote
Old 11-16-2006, 04:02 PM   #4
x99percent
Member#: 27108
2004 STi
2004 A4
...and if you're getting copious amounts of metallic bits stuck to your crank sensor, you might want to figure out where they're coming from.
Old 11-16-2006, 10:49 PM   #5
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I've never heard of anyone cleaning their crank sensor.
modaddict is offline   Reply With Quote
Old 11-17-2006, 12:11 AM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
I've seen a crank sensor covered in "crud" that caused misfire issues on a '02 WRX. Cleaning it made the misfire codes go away. The actual source of the problem was a leaky front crank seal.
How do I get the crank pulley off w/ motor out of car?(I've searched) pheonix991 Service & Maintenance 8 06-10-2009 10:28 AM
Question for people in the snow belt...how do they clean the snow in your area? GooseMan Off-Topic 32 03-19-2007 10:50 AM
How do you clean the STi engine safely? essogas STi Forum Archive 19 09-01-2003 11:56 PM
How do I clean the Perrin short ram air filter? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-24-2003 09:33 PM
how do i clean the engine? nhluhr Interior & Exterior Modification 25 05-15-2002 08:05 PM
