Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 11-16-2006, 05:29 PM   #1
rechrgd
Member#: 132354
Default Anybody use symthetic oil?
Hi, I bought the wife a new '06 Tribeca Limited a couple of months ago and did the first oil change today. I used the regular oil the the dealer recommends this time in order to be sure the rings seal properly. I plan on switching to Mobile 1 10/30 from now on. I've had great luck with synthetics in the past and am just wondering I've anyone has heard of any downs sides to using it in a Subaru. I will be in big trouble with the wife if I were to bring any harm to her new baby.
rechrgd is offline   Reply With Quote
Old 11-16-2006, 08:15 PM   #2
Archee
Member#: 132374
Subaru Stars Sync Mobil one
Hi,
well here the thing SUB's dealer told me that the idle is going to be little rough with Synt. Oil but I'm running the Mobil One for about a year and I have to admit that now rough idle. You gain little performance if car is empty. However, I have a feeling it takes little more gas. It's the way you drive it. I did what was recommended. First oil run to brake in period 3K miles and then Synt. Oil. No problem what so ever. I alwasy put the best gas and I always put Mobil or Exxon. Maybe little crazy but I have bad experience with cheap gas. Good luck
Archee
Archee is offline   Reply With Quote
Old 11-16-2006, 08:49 PM   #3
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I wait till 10,000 miles then switch to synth. I've done this with the last 7 new scoobies I've owned and never had a problem.
Peaty is offline   Reply With Quote
Old 11-19-2006, 04:04 PM   #4
su-be3
Member#: 78702
2004 BAJA Turbo
Frost Pearl White
Cool
I have used Valvoline 5W30 Durablend in all of my cars for the past 15 or so years. Never had a problem, and I, being of the old school, change the "break in oil", at 1,000 miles, then go to the half synthetic half regular oil route.
I also change the oil every 4,000 miles. What do you think of going 7,500 miles, as per the owners manual. Good idea or not?
I would appreciate any feed back.
Thanks.
Keep it under 90, folks.
P.S. I am picking up a new Tribeca on Tuesday, those of you who know of me from the Baja Forum, now you know why.
su-be3 is offline   Reply With Quote
Old 11-19-2006, 04:34 PM   #5
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I make my first oil change at 1000 miles too. There is no break in oil though or no special oil that is, I just like to change it at 1000 then 4, 7 and at 10K I go to synth. Personally I think 7.5K is too long. If you really want to know how your oil is doing, send it to Blackstone for an analysis:
http://www.scoobymods.com/forums/showthread.php?t=4718
Old 11-19-2006, 06:21 PM   #6
SoDealer
Member#: 67960
I agree
Old 11-19-2006, 08:11 PM   #7
sube do
Member#: 124459
2006 WRX limited
ASPEN WHITE
When i got my tribeca I put a 1,000 miles on it then switched to Mobil 1. I change it every 7,000 miles. My tribeca has 22,00 on it never any problems. Also just bought a new WRX I am going to follow the same schedule.
sube do is offline   Reply With Quote
Old 11-19-2006, 08:12 PM   #8
kickitjp
Member#: 60035
Chapter/Region: PRSIC
+1
People change their oil too soon (aka 3K). 6- 7 k is about right.
kickitjp is offline   Reply With Quote
Old 12-16-2006, 09:40 PM   #9
mbutkus
Member#: 103713
Cool oil
I use Mobil 1 or whatever is on sale....
I change every 7K with the past 7 cars I owned... nare a problem nor oil use.
I bought a fumoto valve.. for some $30... well worth the cost. The oil now drains in the catch pan... not all over the frame like the first two times.
Wish I could find something to replace those plastic screw/bolts for the oil filter cover. It takes me more time to get them out then the oil change.
mbutkus is offline   Reply With Quote
Old 12-18-2006, 09:26 AM   #10
hawker800mech
Member#: 53923
2013 Legacy Limited
I usually wait until my second oil change (about 4-5000 miles) before going to synthetic. As for the time interval, I tend to change at about 4-5000 miles for N/A unmodded cars. With the new oils today I'm sure they don't "break down" like the old ones. Plus, I always use the oem filter or Purolator (oem on the older Subies). Never Fram. I tend to stick with 10w-30 vs. 5w-30. My previous Subie (WRX) would use the 5w oil about 1/2 to 1 quart between changes. Not so much the 10w oil. All this, of course, is a matter of personal taste and experience.
hawker800mech is offline   Reply With Quote
Old 12-27-2006, 04:55 PM   #11
Kmunch
Member#: 131311
07 B9 Tribeca Ltd
Diamond Gray
An article in Consumer Reports a year or so ago stated that todays oils are so good that you needn't change them any more often than 7500 miles. I think that's why a lot of manufacturers have changed their tunes in recent years. I'm old school too...used to do it every 3000 miles. But heck, if I can more than double that number, why not?? I've never tried the synthetics....but have read a lot of good stuff about them. I don't see how they could do any harm, tho.
Kmunch is offline   Reply With Quote
Anybody used Motul oils?? -Eric- Service & Maintenance 8 03-18-2007 06:40 PM
Does anyone use a oil extractor (Tempo Oil boy) when doing a oil change SlimSE Service & Maintenance 8 12-12-2005 07:10 AM
anybody ever use 5w40 oil? godfather2112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-16-2004 03:40 AM
Anybody uses 15W-40W motor oil? Is it for trucks only? Dealer Xing Off-Topic 20 04-17-2004 08:47 PM
