Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-17-2006, 01:41 AM   #1
BlackPearlX
Member#: 118165
2006 WRX /
2004 Forester
Default Prodrive Springs + Rear WhiteLine Sway 20mm = ?
I want to put Prodrive Springs and rear sway bar on my Xmas list... but I wanted to check if anyone had this particular set up before I do that...
WRX must have loweing springs and rear sway to limit amount of body roll and give some stability on turns... as well as better tires than re92.... but what about front sway bar? I feel that wrx understeers too much and by putting front sway, I will make it understeer even more...
I could not find wrx with above specs in my area, so I was wondeing if anyone drives their wrx with springs and only rear sway... Is there a need for a front one or do u think it is a waste of money...
thanks
BlackPearlX is offline   Reply With Quote
Old 11-17-2006, 03:25 AM   #2
remowgn
Member#: 41149
09 FXT
SSM
The prodrives + 20mm rear is a good combo. I wouldn't go any higher in the front until you get a bigger rear bar. You'll want to keep the rear the same as or slightly larger than the front.
I have a 24mm rear bar and the stock front right now.
remowgn is offline   Reply With Quote
Old 11-17-2006, 06:48 AM   #3
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
It really boils down to how you drive the car and how you want it to handle.
Installing a larger front bar will raise cornering grip limits, and only increases understeer when those limits are reached.
A major cause of understeer in the Impreza is the front tires' camber curve -- an anti-lift kit is a simple and very effective solution.
Spenk is offline   Reply With Quote
Old 11-17-2006, 11:31 AM   #4
EnterTheDragon
Member#: 6511
Get an adjustable bar 20-22-24 such as a whiteline and then you can adjust accordingly.
EnterTheDragon is offline   Reply With Quote
Old 11-17-2006, 12:15 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
DINGDINGDING!!!
Spenk gave you the winning answer.
You are correct in your thinking that a front bar will increase understeer, but that is more than offset by the really crappy dynamic camber curve on these cars.
Old 11-17-2006, 12:30 PM   #6
uathatis
Member#: 117300
i think a 20mm rear bar is a mininmum... just cause 20/17 setup is just so strange usdm factory shi((
prodrives stiften a little.. i think the guessed springrates are around 180/180ish
with the stiffer up front that will help the camber stay the same and allow much less understeer. likewise same for the back
i think my 225/195 rate springs helped more than my 20mm rsb for the turn in
turning with springs was way more balanced and limits were MUCH more predictable with my setup right now
more gas = nuetral to a small amount of oversteer perhaps...
since the prodrives are ... a smallish spring upgrade, having a larger bar up front would probably be great.
but don't listen to me, i'm just a n00b
at worst... if the 22mm adj whiteline swaybar on front with the 20mmrsb is too much understeer for you... just put it on the softest setting until you get a 22 adj rear bar
IBi'm getting22fsb first then 24 adj rsb...
is it right ot think it takes more stiffness in the rear for a wagon to swing a little bit of that extra weight
uathatis is offline   Reply With Quote
Old 11-17-2006, 05:05 PM   #7
bzbuzz
Member#: 116052
2011 STI ( Sold )
I also have a Prodrive springs with stock tires. And got oem 20mm rear sway bar installed last week. I really like the tighter feeling on rear and oversteer. I used to have 37f/35r tire pressure, but now I adjusted it to 35f/35r so reduced oversteer little bit to more neutral. While enjoying it, I feel front of my car is loosing traction more. so, I ordered 22mm whileline front sway bar to see if i could get tigher feeling on front. i am a noob so correct me if i am wrong.
bzbuzz is offline   Reply With Quote
Old 11-17-2006, 06:31 PM   #8
BlackPearlX
Member#: 118165
2006 WRX /
2004 Forester
Thanks for responses guys! They were helpful
ButtDyno to me:
"I have a huge freakin front bar and a 17mm rear bar (smaller than stock).
I am also running crazy stiff springs. To make the understeer go away you
want a decent sized front bar too, as well as a good alignment, maybe -2
in the front. Maybe camber bolts."
Prodrive RB320 Suspension, Prodrive Springs, and Whiteline too! WorldOne Suspension/Brakes/Handling 16 10-12-2007 01:32 PM
Cobb Catted downpipe, Samco hose set, Prodrive springs, Complete whiteline sway setup hinduluv Private 'For Sale' Classifieds 17 01-16-2006 08:47 PM
FS:No.Cal- Prodrive springs, momo, Whiteline caballo77 Private 'For Sale' Classifieds 11 07-30-2005 12:47 PM
Prodrive Springs & Whiteline Rear Swaybar BzY Private 'For Sale' Classifieds 7 01-01-2004 07:47 AM
FS: Prodrive Springs & Whiteline Rear Swaybar BzY Mid West Subaru Owners Club Forum -- MWSOC 2 12-30-2003 02:06 AM
