Old 11-17-2006, 11:22 AM   #1
redlegacygt
Member#: 82994
1997 Legacy GT
Rio Red
Default After a Trans flush.....
So i just got a trans flush to see if that would fix the problem i was having. It made it alot better but there is still a small about of bind and the AT oil temp light still comes on. So my question is, after a trans flush and the adding of some stuff called B&G conditioner, should i still add the lubegaurd?
Also, im going to change the rear diff flud. Does the ecu need to be reset after doing these things?
-Astin
redlegacygt is offline   Reply With Quote
Old 11-17-2006, 01:11 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Well, resetting the ECU after a trans flush might not be a bad idea to clear the code, but the diff has no electronics in it, so it wouldn't do anything for that.
Wiscon_Mark is offline   Reply With Quote
Old 11-17-2006, 01:24 PM   #3
redlegacygt
Member#: 82994
1997 Legacy GT
Rio Red
yeah i knew it didnt have any electronics, but just didnt know if it was worth reseting after a flush.. i guess ill just add the lubeguard tonite and see if that takes away the rest of the binding...
99 OB Trans overhaul, Valvebody from IPT or EcuTuning? Farmboy0007 Transmission (AT/MT) & Driveline 1 06-03-2010 11:28 AM
Abs light on after flush crazycraig Brakes, Steering & Suspension 5 04-08-2005 11:29 PM
Strange sound after coolant flush? JohnGalt00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-01-2003 05:44 PM
HELP: My car overheats after flushing cooling system! CastleBravo New England Impreza Club Forum -- NESIC 9 08-16-2003 06:57 PM
a/c blowing hot air after coolant flush mofoporn Service & Maintenance 31 08-12-2002 07:47 PM
