Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-17-2006, 12:11 PM   #1
redlegacygt
Member#: 82994
1997 Legacy GT
Rio Red
Default Swap using an 05 lgt motor...
i did a few searches and couldnt find anything so i figued id ask. Has anyone tried or put a 05 legacy gt turbo motor into any older legacy's?
I might be able to get my hands on one, but dont know if its still as straight foward (other the wiring) like the wrx motors or if it will work... anyone know?
-Astin
redlegacygt is offline   Reply With Quote
Old 11-17-2006, 12:20 PM   #2
badbasser98
Member#: 104801
2011 WRX Limited
-Astin
Straight forward??!
Supposedly the wiring is a nightmare to the average person...
badbasser98 is offline   Reply With Quote
Old 11-17-2006, 12:31 PM   #3
redlegacygt
Member#: 82994
1997 Legacy GT
Rio Red
what i meant was straight forward to those who have done a few wrx swaps and even more straight forward to those who do swaps for a living like (ECS) (Area1320) thats all..
never said i personally thought it was straight foward, geesh...
Old 11-17-2006, 12:36 PM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I've heard that the 05+ have a lot more complicated electronics, which would make it more complicated. (IE...i believe you can't swap the cluster without a dealer ecu reflash.) Things like this would prove to be a PITA in a swap.
fibuz is offline   Reply With Quote
Old 11-17-2006, 12:40 PM   #5
badbasser98
Member#: 104801
2011 WRX Limited
easy dude, I was just busting your balls a bit. It wasn't a personal attack. I knew what you were getting at...
Old 11-17-2006, 12:40 PM   #6
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
that sucks^ i wanted to snatch that 05 longblock also but maybe bidding on a wrx donor car that's salvage is a better idea!
choung
illegal2.2 is offline   Reply With Quote
Old 11-17-2006, 12:46 PM   #7
redlegacygt
Member#: 82994
1997 Legacy GT
Rio Red
bb98- no harm done, its all good..
i figured the electronics would be a lot different. I just didnt know if swapping a dash would help fix some of those problems, but then again i dont know if a newer dash would fit either... i'll prob. call ECS on monday see what they have to say... but im guess the difference in electrical is going to be a no go from some of the reading i've done...
Old 11-17-2006, 12:49 PM   #8
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Also doubt the dash will fit. Stick to wrx/sti engines, they're pretty well documented.
Old 11-17-2006, 01:05 PM   #9
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
What fibuz said is true (about the cluster) however those clusters are really nice, so I wouldn't have a problem with swapping that in too
Wiscon_Mark is offline   Reply With Quote
Old 11-17-2006, 01:08 PM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Aren’t we talking about a long-block motor only? What does dash complexity, 05’ immobilizer ECU, and other electronics have to do with it? Just cuz you install a suby 2.5l turbo motor which came out of a LGT, doesn’t mean you have to run all LGT wiring/ecu.
You should be able to run any FI harness and matching ECU with that motor, or portions of said harness and standalone EM. Plenty of folks run AVCS equipped heads and motor wiring with WRX harnesses, etc. It can be done…
For example, I run and 02' wrx chassis harness + ECU, on a 06' STi 2.5l shortblock, with 05' wrx heads...
xcntrk75 is offline   Reply With Quote
Swapped in an 05 sti motor - now breaking up BoostyTSi Built Motor Discussion 3 10-08-2009 05:11 PM
07 STI Motor Swapped in an 05 WRX W/PPG Straight Cut Gears! 1/4 Mile Times & HP/TQ mrtrex Proven Power Bragging 2 07-21-2008 01:37 PM
Which Stainless Lines to use with 05+ LGT brakes on wrx lazybummm Brakes, Steering & Suspension 0 11-10-2007 08:04 PM
05 lgt motor in 97 lgt what fmic/turbo to use warped-v Legacy Forum 5 04-24-2007 03:46 PM
05 lgt motor in 97 lgt what fmic/turbo to use warped-v Subaru Conversions 1 04-21-2007 05:41 PM
