Old 11-18-2006, 01:33 AM   #1
aakrusen
Member#: 77308
'02 WRX
Default Hub centric ring, needed?
I just bought a new set of wheels and they came with hub centric rings. Do I need to install these with the wheels? I've never used them on any other car includin my 02 WRX.
aakrusen is offline   Reply With Quote
Old 11-18-2006, 03:00 AM   #2
Charge
Member#: 3313
Is the center bore correct? If not...then yes, you need to use the rings.
You can technically get away with out them...however, you better be darn sure that the wheel fits snugly on your hub when you torque it down. Some are more "generic" in application and they might not sit entirely flush against the hub without the rings.
Charge is offline   Reply With Quote
Old 11-18-2006, 06:41 AM   #3
Canonshooter
Member#: 103479
'07 Forester XT
Newport Pearl Blue
Providing the rings fit the hub correctly, use them!
Take a ring and make sure it fits over the hub with little play. If so, insert them into the hub opening on the back of the wheel. The purpose of these is to distribute the load between the lugs and the hub.
FWIW, my Oz Ultraleggeras came with rings and I use them.
Canonshooter is offline   Reply With Quote
Do I need Hub centric rings? VitorBelfort041 Tire & Wheel 2 04-10-2009 12:04 PM
hub centric rings needed? haberkorn Tire & Wheel 6 03-20-2009 07:34 AM
Hub centric Ring needed for Volks CE28N? SubyWRXSti Tire & Wheel 20 07-06-2008 04:33 PM
Hub centric rings needed subywrx Tire & Wheel 9 09-01-2005 03:55 PM
need info on hub centric ring size NOTimprezed Tire & Wheel 8 02-10-2005 11:41 PM
