Old 11-18-2006, 03:32 AM   #1
qtr_wrx
Member#: 109567
Smile So at 80K miles, what bushing need to be changed?
I'm thinking of some new bushing for my car, it has done 80k miles (04 impreza) so what to look for? cuz I can feel that there is some body roll when I go hard on corners
I mostly drive in a spirited way on touges, going and coming back from work and I do some autoxing
my only mod is megan coilovers
qtr_wrx is offline   Reply With Quote
Old 11-18-2006, 09:56 AM   #2
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
How many miles on the coilovers? If you are feeling more body roll you might start with making sure the coils are still living and don't need to be rebuilt. Then I'd look at swaybar endlinks and make sure they're still intact. Those are the two biggies for body roll.
Scooby921 is offline   Reply With Quote
Old 11-18-2006, 02:20 PM   #3
qtr_wrx
Member#: 109567
ummm I only did 10k miles on my coilovers, and I'm really happy with them, but I want the car to be more stable at hard cornering, that why I want to change the old OE bushing for more fun
Old 11-19-2006, 07:48 AM   #4
qtr_wrx
Member#: 109567
still looking for input ?
Old 11-19-2006, 09:43 PM   #5
Gonz
Member#: 18642
2005 Impreza WRX STi
usually a "soft " feeling comes from worn shocks. In your case coilovers.
Did you check the sway bar bushings and sway bar link condition as mentioned above ? Going to an aftermarket sway bar link is a good way to get a bit " tighter" feeling.
Gonz is offline   Reply With Quote
Old 11-19-2006, 10:25 PM   #6
jamal
Member#: 71875
98 Legacy GT
my wheels fit
you could put on stiffer control arm and lateral link bushings. Also swaybar bushings and solid endlinks if you haven't already.
I recently put on kartboy solid endlinks and they really livened things up. Right now I'm trying to find some whiteline swaybar bushings so I can put on a bigger front bar, and I would eventually like to replace all the lateral link and control arm bushings.
I think superpro bushings are easier to press in than noltecs or group N because they're three pieces. Well, the front control arm bushings are anyway.
jamal is online now   Reply With Quote
Future plans for EJ257 hybrid...what needs to be changed. CoolRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-05-2007 01:03 PM
When do wastgates need to be changed out? japslapr Newbies & FAQs 10 09-11-2006 04:27 PM
If i get an STi shortblock...what else needs to be changed? SpamMansXe Normally Aspirated with bolt-on Forced Induction Powertrain 6 05-26-2004 03:05 PM
Bush needs to be in Public Speaking 101 Car Ramrod Off-Topic 96 10-08-2002 06:07 PM
