Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Interior/Dressup/Audio & Security
Closed Thread
Old 03-01-2007, 04:58 PM   #1
GST Motorsports
Vendor
Vendor Sales Rating: (8)
Member#: 130434
Default GReddy 52mm Gauge Package $590 Shipped!! Blitz and HKS! RACETECH Seats Now Available!
GReddy Electronic 52mm Gauges
GReddy’s 52mm electronic gauges feature new and improved Red LED backlighting, for a new look and long life. Black gauges now have a black face and red indicator needle. White face meters now have Red lettering. Also new is pressure values are displayed in standard (PSI) values. The temperature gauges remain in Celsius.
Having a proper gauge setup in your car is very important. Boost gauges help your tuner properly monitor boost levels. E.G.T. and other gauges such as oil temperature or pressure allow you to know what your vehicle is doing and how well it is performing. Monitoring your vehicle is something everyone should be doing so how are you watching over your vehicle?
Boost, E.G.T., Oil or Water Temp. and ATI Center Meter Pod $590 SHIPPED!!
Blitz DTT DC 2 (Silver) $110
The BLITZ DTT (Dual Turbo Timer) DCll is a one of a kind item. This is the only turbo timer in the world that incorporates a turbo timer with a boost gauge. The digital boost display can read up to 2.5hkpa (36.75psi) and also includes a digital boost peak hold. This unit also features the two-piece design that allows the user to virtually mount the turbo timer anywhere in the vehicle.
**Harness required at additional cost. ($17)
HKS EVC Boost Controller Call or PM for pricing
HKS celebrates the 20th Anniversary of the original Electronic Valve Controller (EVC) with an all-new EVC boost controller model. The original EVC released in 1987 was the first commercially available electronic boost controller, and revolutionized the aftermarket industry. HKS’ 20 years and five EVC generations of boost control knowledge has been harnessed into this all-new EVC.
The new HKS EVC has improved boost stability for maintaining pressure at high RPMs providing increased top-end power, and a new mapping feature allows boost pressure to be precisely tuned for throttle + RPM (or vehicle speed). The new EVC also offers a selectable kPa or PSI unit of measure, and a unique warning feature where if over boosting occurs, boost pressure can be programmed to drop to a user preset level. The new target boost setting and volume knob with three button user interface makes setup and tuning intuitive and simple. The design of the new EVC features a sleek black case with a clear acrylic faceplate and a positive lit LCD display offering a sophisticated look.
High Boost Capability
  • 250kPa/36PSI
Target Boost
  • User inputs target boost level, and the EVC automatically adjusts pressure to reach desired level.
Offset Function
  • If boost exceeds or does not achieve user’s target, boost pressure can be offset to reach desired level.
Map Correction Mode
  • Boost pressure can be fine tuned for: Throttle Position, RPM, Vehicle Speed, Throttle Position + RPM, or Throttle Position + Vehicle Speed.
Dual Boost Mode Settings
  • Separate A and B boost levels can be input independently from each other, and selected depending on driving conditions.
Scramble Boost Function
  • When the scramble boost trigger is depressed a preset boost increase will occur for a predetermined time (0-60seconds).
  • External Scramble Boost Trigger compatible.
Metric or SAE selectable monitoring
  • Users can choose during initial setup metric (kPa) or SAE (PSI) boost pressure measurement for monitoring.
Warning Function with Boost Drop Feature
  • A user preset warning level can be set where visual and audible alerts occur if the warning level is reached. Boost pressure can be preset to drop too a user defined level if pressure reaches warning level.
Analog and Digital Boost Monitoring
  • Boost pressure can be displayed in both an analog bar graph format and a digital numerical value.
Additional Digital Monitoring
  • Along with Boost Pressure two additional vehicle vitals can be monitored: Throttle Position, Engine RPM or Vehicle Speed.
Selectable Analog Monitoring
  • The digital bar graph can be set to monitor: Boost Pressure, Throttle Position, Engine RPM or Vehicle Speed.
After Image Function
  • Users can set the EVC to display the highest boost pressure reached for 3-seconds after the throttle has been released.
Peak Hold
  • The EVC will store to memory and keep displayed the maximum boost achieved.
Data Lock
  • To prevent accidental data changes from occurring, the EVC can be locked with a user defined four digit code.
Positive LCD display with LED Lighting
  • Black foreground with white background and LED lighting provides excellent visibility during both daytime and nighttime use.
Dimmer Function
  • Brightness of display can be adjusted for user comfort.
Rear Mounted Wiring harness
  • For a clean and simple installation the wiring harness connects to the back of the EVC unit.
RACE TECH SeatsCall or PM for pricing
RT 1000
Fabric covered with a gloss gel coat fiberglass shell. Great for road and track useage, popular with people who have back problems or difficulty sitting for long periods of time. Also available in a wide model.
Section A B C D E F G Weight
Inches 23.6 22.8 15.3 18.9 19.6 34.25 26.8 14.33 lbs / 6.5 kgs
Comes in full black fabric.
RT 4009
Comes in black fabric with grey suede wear patches and a black gel coating. Call for info on other colors. Also available in wide model.
Inches 23 24 14.5 19.5 20 34 25.5 19.5 lbs / 8.5 kgs
RT 4009 HRV
Viper head restraint seat, official seat of the Daimler-Chrysler Dodge Viper Competition Coupe. 1st Choice for Grand Am Cup and Speed World Challenge Teams.
Fabric covered with a gloss gel coat fiberglass and kevlar/carbon-fiber shell. Thick foam padded headrestraint and shoulder supports for best possible support. Removeable cushions from mid back to lower thighs.
Comes in black fabric with grey suede wear patches and a black gel coating. Viper logo optional. Call for info on other colors. Wide model also available.
Inches 23 24 14.5 19.5 20 34 25.5 20.9 lbs / 9.5 kgs
Happy to answer any questions.
Thanks,
Greg
510-264-9049
GST Motorsports is offline
Old 03-22-2007, 01:35 PM   #2
GST Motorsports
Vendor
Member#: 130434
UK weekend starts on Thursday bump!
Cheers,
Greg
Old 03-23-2007, 03:58 PM   #3
AlxSti
Member Sales Rating: (19)
Member#: 94615
|'06 STi 341/356|
Delaware REALTOR®
hey.. can i get a price on those new greddy electirc gauges? i need black face boost (psi) and egt (f) shipped to 19709. thanks! also, how well do these match up with the sti cluster?? and do they have an opening sweep?
AlxSti is offline
Old 03-23-2007, 06:22 PM   #4
GST Motorsports
Vendor
Member#: 130434
AlxSti,
PM sent.
Thanks,
Greg
Old 03-23-2007, 06:45 PM   #5
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTOR®
ive got no pm's..
AlxSti is offline
Old 03-23-2007, 08:28 PM   #6
GST Motorsports
Vendor
Member#: 130434
Sorry web connection acting up today. Check now.
Thanks,
Greg
Old 03-24-2007, 04:15 PM   #7
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTOR®
ok.. got a pm, but still no price..
AlxSti is offline
Old 03-26-2007, 07:13 PM   #8
GST Motorsports
Vendor
Member#: 130434
PM received and responded.
Old 04-11-2007, 10:33 PM   #9
acetey
Member#: 144695
2003 Wrx
Hey Greg,
Do u happen to sell STi Optitron Cluster with 260km/h (outer ring) &160miles (inner ring) display on the speedometer?
rgds,
ace
acetey is offline
Old 04-12-2007, 06:01 PM   #10
GST Motorsports
Vendor
Member#: 130434
acetey,
Sorry we do not.
Thanks,
Greg
Closed Thread
Wrx Seat Trade For Tr Seats Now Available!!! Perfect SWIC Private Classifieds 4 03-08-2010 07:33 AM
GReddy Gauge Package $650 Shipped!! Blitz and HKS! RACETECH Seats Now Available!! GST Motorsports Interior/Dressup/Audio & Security 1 03-01-2007 04:54 PM
fs: Set of Greddy 52mm gauges mpj_becks Bay Area Impreza Club Forum -- BAIC 9 05-28-2002 02:29 PM
Greddy 52mm gauges from Vivid! supermarkus Car Part Reviews 6 12-25-2001 07:57 PM
depth of greddy 52mm gauge? scoop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-11-2001 12:21 AM
