Alaskan Impreza Club
Old 11-19-2006, 03:17 AM   #1
Jaylyons1
Member#: 113884
2013 BRZ
Default What oil do you use?
Figured Id pitch this one out there, already know about the fuel additives ^_^ any oil additives also?
I use Pennzoil platinum full synthetic myself...
Jaylyons1 is offline   Reply With Quote
Old 11-19-2006, 04:19 AM   #2
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
just a regular 5w30 chevron supreme...
SQUAD_907 is offline   Reply With Quote
Old 11-19-2006, 04:55 AM   #3
redl1newrx
Member#: 121977
2009 Impreza2.5i
mobile 1 synthetic
redl1newrx is offline   Reply With Quote
Old 11-19-2006, 05:13 AM   #4
whoaslowdown
Member#: 84792
05 just another
subaru
Originally Posted by redl1newrx View Post
mobile 1 synthetic
+1 same here..
whoaslowdown is offline   Reply With Quote
Old 11-19-2006, 05:23 AM   #5
soldmyboxster
Member#: 65520
Another vote for Mobil 1 synthetic. I tend to use 0-30 in the winter and 5-30 in the summer for my Prius, and since the Boxster is only a summer car, 5-50.
soldmyboxster is offline   Reply With Quote
Old 11-19-2006, 05:30 AM   #6
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
mobil 10/30 in the summer and mobil 5/30 in the winter, syn of course
tribalwrx is offline   Reply With Quote
Old 11-19-2006, 12:08 PM   #7
SparkysJDMSpeedWagon
Member#: 52530
2004 For Sale:
Silver 04 wagon w/18g
mobile 1 synthetic
5/30 year round, it's what the manual recommends so it can't be bad!
SparkysJDMSpeedWagon is offline   Reply With Quote
Old 11-19-2006, 12:53 PM   #8
prometheum
Member#: 92003
04 bicycle!
m1 synthetic
if its good enough for the ls7 its good enough for my car
prometheum is offline   Reply With Quote
Old 11-19-2006, 01:40 PM   #9
xplcitcustmz
Member#: 82935
1972 Ford pinto
Astro Turf
remember not to use synthtic until you have broken in your engine, even still the longer you wait the better.
xplcitcustmz is offline   Reply With Quote
Old 11-19-2006, 02:30 PM   #10
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
mobil 1 synthetic all year long for me.
Mavrik is offline   Reply With Quote
Old 11-19-2006, 02:31 PM   #11
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
same here
EvolvedAK is offline   Reply With Quote
Old 11-19-2006, 02:41 PM   #12
bikefreax
Member#: 110726
2005 WRX Wagon
San Remo Red
Ditto here, just changed mine this morning.
bikefreax is offline   Reply With Quote
Old 11-19-2006, 02:53 PM   #13
Jaylyons1
Member#: 113884
2013 BRZ
didnt know about that, just started using it on mine now, so i figure its fine. But i will remember that for my next one.
Old 11-19-2006, 03:35 PM   #14
ponamy
Member#: 115511
2005 wrx /w babyseat
2011 Forester 2.5x
castrol gtx 5w/30 anti sludge year round
ponamy is offline   Reply With Quote
Old 11-19-2006, 04:00 PM   #15
03bluwrx
Member#: 121858
13 STI
ISM
+1
i tried mobil 1 syn and it made my car tick like craaaaaaaaaaaaaaazy. changed to P.P. and tick went away after about 2 minutes of driving..
03bluwrx is offline   Reply With Quote
Old 11-19-2006, 04:27 PM   #16
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Royal Purple 5/30
Racer Dubya is offline   Reply With Quote
Old 11-19-2006, 04:48 PM   #17
GrinderAK
Member#: 87551
97 OBS, 01 RS
2014 SWP FXT
mobil 1 syn, i love how it makes my car run
GrinderAK is offline   Reply With Quote
Old 11-19-2006, 05:31 PM   #18
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
mobil 1 5/30syn here too
00Maddog is offline   Reply With Quote
Old 11-19-2006, 05:33 PM   #19
02redwagone
Member#: 87067
02 Old but tasty
SRP
Whatever conti uses for now. Have used Mobil in the past as well as Amsoil products.
02redwagone is offline   Reply With Quote
Old 11-19-2006, 05:52 PM   #20
edo2000
Member#: 68709
2012 WRX
red
Mobile 1, 5w30. Since about 10,000 miles.
edo2000 is offline   Reply With Quote
Old 11-19-2006, 08:41 PM   #21
XR4Tim
Member#: 73802
Fast rare cars...
Lots of them
Engine break-ins should be done with dino oil, but if you wait too long to switch, your seals may not be able to hold the synthetic quite so well once they're conditioned to regular oil.
XR4Tim is offline   Reply With Quote
Old 11-19-2006, 08:43 PM   #22
prometheum
Member#: 92003
04 bicycle!
meh i switched to synthetic on my celica with 70k on the clock no leaks
Old 11-19-2006, 09:06 PM   #23
AKGC8
Member#: 1305
2000 Impreza
Mobil 1 is great.
When I did my original WRX swap into a 94 Impreza I had a problem with 1 of the wires that basically caused it to only spark on 3 cylinders. It was still sending gas into the 4th, which would then burn off in the uppipe cat. That caused the turbo to get hot enough to glow bright red during any semi spirited driving(this was in the middle of the winter also, no shortage of cooling air). I drove the car like that for a few weeks till I figured out the wiring issue. Mobil 1 held up to the abuse and that turbo kept working great right up to the day I swapped a VF34 in at about 40000 miles.
AKGC8 is offline   Reply With Quote
Old 11-19-2006, 09:08 PM   #24
soldmyboxster
Member#: 65520
See, I never understood that, nor have I asked. I know conventional oil is recommended for engine break-in, but my '99 Boxster (and maybe my '00, I haven't looked) had a sticker that mentioned Mobil One was the factory fill from Porsche. If that were the case, the engine might never break in. I think the same is true for a few other manufacturers, as well.
Old 11-19-2006, 09:21 PM   #25
soldmyboxster
Member#: 65520
I've heard this before as well. I switched to Castrol Syntec for one oil change back when I had a CRX (40K miles on the engine) and it consumed over a quart of oil (no external leakage) in 1000 miles. I switched back to conventional. I've used Mobil 1 on every car since (including my turbo CRX and my WRX) and I've had no external leakage issues.
What oil do you use? Black07Impreza Service & Maintenance 12 01-30-2007 06:48 PM
What Oil Do You Use? Blk_on_Blk_Wgn Service & Maintenance 58 11-30-2005 03:03 AM
What oil do you use? krnkimche2 Service & Maintenance 69 08-10-2004 12:14 PM
First oil change! = What oil do you use? Italiano New England Impreza Club Forum -- NESIC 7 05-07-2003 07:13 PM
