Old 11-19-2006, 11:49 AM   #1
quazimoto
Member#: 70395
Default Grams per second-cfm?IAM of 15?
How do you convert grams per second to cfm?And is it possible to see an IAM of 15?Wasn't sure if it advanced by 2's or not.
quazimoto is offline   Reply With Quote
Old 11-22-2006, 09:16 AM   #2
qoncept
Member#: 44762
2013 BRZ
Grams per second is mass and cfm is volume. You can't really convert them.
I've seen IAM of 15 before. Surprised me too, but apparantly it can be any integer 0-16.
qoncept is offline   Reply With Quote
Old 11-22-2006, 10:47 AM   #3
quazimoto
Member#: 70395
Thanks!What about converting grams/second-lbs/min first and then to cfm?
Doesn't lb/m=14.47 cfm?
Old 11-22-2006, 12:26 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Probably not since the volume will change depending on pressure and temperature. If you knew the intake air temperature as well as atmospheric pressure you could get reasonably close. I got the conversions in a book at home though. Why do you need to know the CFM?
Old 11-22-2006, 12:51 PM   #5
quazimoto
Member#: 70395
Just curious.
Old 04-12-2009, 06:01 PM   #6
Cmckinnonr
Member#: 201042
2003 WRX
Not sure. in one cubic feet per minute there are .0691 LB/min at sea level around 70 degrees. so one lbs/min is equal to 7.5598 grams per second.
Cmckinnonr is offline   Reply With Quote
Old 04-14-2009, 12:22 AM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
A 3-year back from the dead bump to say you don't know the answer?!?!?
Old 07-30-2009, 04:51 PM   #8
fast914gt
Member#: 218864
Default cubic feet -> grams per second
assuming we are talking about mass airflow
gr/s = scfm x 0.075(lbs/cu.ft.) x 453.59237(gr/lb) / 60 (sec/min)
gr/s = (scfm)*(0.075)*(453.59237)/(60)
standard [FONT='Verdana','sans-serif']temperature [/font]= 70 F
standard pressure = 29.92" Hg
standard humidity = 0%
fast914gt is offline   Reply With Quote
IAM at 15, IDC's max on modified XPT stage 2 crofrog Open Source Reflashes 34 01-06-2010 01:59 PM
FS Gram Lights 57 Optimise Bright Silver 15 Pounds per rim H.K. Phooey TXIC Private Classifieds 13 01-04-2010 12:46 PM
$39K? Thats about $3K per second. Cosworth Off-Topic 15 05-01-2006 05:45 PM
48 balls Per Second Per Barrel RR Off-Topic 6 09-10-2004 04:53 PM
Your thoughts on grams per second / volts (maf) MINO Engine Management & Tuning 4 08-27-2004 11:51 AM
