Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-14-2001, 01:22 PM   #1
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Default swapping out DOHC 2.5L engine for SOHC 2.5L engine
Does anyone know whether it is possible to swap in a 2.5L DOHC engine with a 2.5L SOHC engine into a 97 legacy (assuming I have the ecu as well)? Also, would the transmissions line up as well? I have the opportunity to buy a new engine and ecu and was thinking that I might as well go for the more "reliable" of the two designs. And NO, I'm not even considering a 2.0L swap - way too much money.
I'm looking for a pretty straight forward "bolt in" swap. I know there will be some issues with rewiring the ecu's (I hope I"m wrong about this though), but other than that I heard the two engines have the same dimensions and use the same mounts.
If anyone has more information about this, I'd greatly appreciate it.
Thanks,
Jason
2.5GT is offline   Reply With Quote
Old 11-14-2001, 02:24 PM   #2
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
the blocks are basically the same. the sohc has been slightly modified on the inside. the swap should be pretty easy. a mechanic told me there have been a lot of problems with the dohc. try looking at the engine projects on www.cobbtuning.com for soem more detailed info.
tydon is offline   Reply With Quote
Old 11-14-2001, 03:58 PM   #3
cakagan
Member#: 251
1998 Impreza 2.5 RS
Or just have the best of both worlds and mate your DOHC heads to a SOHC block. My Phase 1 (what you call GEN 1) engine in my 98RS was eating about 1-1.5 qts of oil every 1000mi. I got the dealer to open the engine block up and SOA warranteed the whole engine. It's now considered a Phase 1.5 engine.
-Chris
cakagan is offline   Reply With Quote
FS (ID) Web Cams for SOHC 2.5L motor new! 84118gc Engine/Power/Exhaust 6 04-28-2010 11:24 PM
Swap 1999 2.5 RS engine for 2001 2.5 RS engine c0mrade Subaru Conversions 5 06-15-2006 09:19 PM
Crankshaft Pulley Restraint Tool for SOHC 2.5L Engine TexasForester Service & Maintenance 4 07-20-2005 08:27 AM
HELP!: need a timing belt tensioner for SOHC 2.5L Elwood Mid West Subaru Owners Club Forum -- MWSOC 11 03-23-2005 12:45 AM
FS: Phenolic manifold spacers for SOHC 2.5 Chuck_Beef Private 'For Sale' Classifieds 10 02-14-2004 02:08 PM
