Old 11-20-2006, 01:32 PM   #1
AllAWD
Member#: 17079
Default STi vs WRX suspension geometry
I always thought the STi suspension geometry was the same as the standard WRX, but I started thinking about it (never good) and could not find anything to afirm this.
Can someone quickly run throught the differences?
Differences that I know of:
Springs
Stuts
Links
Bushings
rear sway bar
anything else?
AllAWD is offline   Reply With Quote
Old 11-20-2006, 05:10 PM   #2
Impreza01
Member#: 152
2002 Impreza WRX
Depending what country's STI you're talking about, the STI may or may not have the same suspension geometry as the WRX. For instance, pre-2004MY Japan-spec STIs had the same geometry. But all Spec C, 2004 to 2006MY US-spec STI and 2004+MY J-spec STIs have different suspension geometry due to different control arms.
Impreza01 is offline   Reply With Quote
Old 11-20-2006, 05:23 PM   #3
AllAWD
Member#: 17079
I was just comparing USDM STI to USDM WRX.
I'm adding RCE springs and struts to my bugeye and was curious if my setup would be at a disadvantage compared to STIs with the same setup.
Old 11-20-2006, 05:27 PM   #4
DuckStu
Member#: 124060
2004 WRX STI
STI's have aluminum front control arms. The pin on the rear that goes into the rear bushing is bolted on, and can be fliped around to give more caster without the need for an ALK. More caster yet WITH an ALK.
DuckStu is offline   Reply With Quote
STi vs. WRX Stock Suspension amoore Brakes, Steering & Suspension 33 06-28-2006 03:20 PM
TS vs. WRX suspension notes Howl Brakes, Steering & Suspension 5 02-21-2006 04:15 PM
Where to find WRX suspension geometrys... MachinesWRX Brakes, Steering & Suspension 0 01-23-2006 09:11 PM
New highway/backroad video sti vs wrx vs evo vs s4 WS6toWRX Off-Topic 88 02-21-2004 08:38 PM
STI vs WRX suspension Question IJust8Chris Brakes, Steering & Suspension 26 09-06-2003 09:34 PM
