Old 11-14-2001, 03:18 PM   #1
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
more mods coming soon!!
Default HELP! CE light after SAFC install....
I just installed my SAFC and I just got a check engine light. Im in the process of resetting the ECU and Im hoping it works. All the wiring I assume is done correctly...I followed the diagram from ravens-blade impreza. There isnt any smoke or weird sounds/smell coming from the ECU or SAFC so I really dont know whats going on. If anyone has any ideas let me know!
Kyle
98RS Owners UNITE!
Impreza25RS is offline   Reply With Quote
Old 11-14-2001, 04:03 PM   #2
Ripper
Member#: 7774
If I recall correctly its normal to have the CE light go off after the SAFC install. It just happens cause the car is angry with you for messing with it. I'm sure it's ok but by all means someone correct me if I'm wrong.
Ripper
Ripper is offline   Reply With Quote
Old 11-14-2001, 04:21 PM   #3
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
yeah, I've also initially had the CE light after installing one.
if one or two resets don't clear it, then there's a problem.
JGard is offline   Reply With Quote
Old 11-14-2001, 04:22 PM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
All wires connected and soldered securely? Once, the output wire from the SAFC to the MAP wire came loose and check engine light came on. Then, idling was funny. So, I checked the wiring on the SAFC, and the wires separated thanks to my crappy soldering skills. So, check your wirings throughly just to be on the safe side.
tmat3 is offline   Reply With Quote
Old 11-14-2001, 04:26 PM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
I NEVER got a CEL from my SAFC install....
STiShawn is offline   Reply With Quote
Old 11-14-2001, 04:37 PM   #6
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
I second that. Double check the harness with diagrams from Kartboy's page.. that helped me install it.
This sounds like an i-Club myth of AFC = CE light, much like the AFC = worthless on MAP cars.
Korey
Longshot is offline   Reply With Quote
Old 11-14-2001, 06:27 PM   #7
bruno
Member#: 2903
1999 Impreza 2.5rs
bmw steel greay
are there any gains in horsepower and torque after you install the afc. and how do you test and tune it properly if we cant get a dyno. when my friend did his afc on a legend he got fifteen extra horses on the dyno to the wheels.
bruno is offline   Reply With Quote
Old 11-14-2001, 10:52 PM   #8
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
Default nevermind
i reset the ECU and everything is cool now. I guess I over reacted but I was a little nervous when the CEL went on because I thought I messed up my car! Thanks anyways guys!
Kyle
Old 11-14-2001, 11:26 PM   #9
smacksube
Member#: 4067
01 2.5 rs
just amke sure your connections are securely covered, I put my plate back on and one of the wires hit the back of it and blew the ignition fuse. I got really freaked out b/c the car wouldn't start, then I forced myself to think about it.....turn the key, all the lights on the dash come on except for the CE....that would mean the ecu isn't getting power to something....bammo, simply swapped the foglamp fuse and I was on my way......and that was my war story....
smacksube is offline   Reply With Quote
Old 11-14-2001, 11:43 PM   #10
Longshot
Member#: 2359
Yes, but you have to tune it first, an EGT or A/F gauge will aid you in that respect. Also in some places there are local AWD dynos.. I found a few in my area.. its always worth it to dyno tune it.
Korey
ce light after changing spark plugs, etc... Blindeye_03 Normally Aspirated Powertrain 5 05-22-2002 03:57 PM
CE light after header install espionage3 Normally Aspirated Powertrain 9 09-25-2001 03:34 PM
Help! CE light and no idea why??? Robmat Normally Aspirated Powertrain 5 08-09-2001 07:25 PM
Blinking CE light after filter install! ugh! jhayzhon Normally Aspirated Powertrain 3 03-12-2001 09:18 AM
CE light after subbox removal...? Orbiter Car Audio, Video & Security 11 03-07-2001 07:50 AM
