Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 11-20-2006, 07:36 PM   #1
HorsepowerFreaks
Vendor
Vendor Sales Rating: (1)
Member#: 57501
Default AEM, TiAL, Precision, CP, Brian Crower, and MORE!!!
IN STOCK!!!
Contace me for Pricing
We also offer complete kits that are READY to go!!! HPF AEM EMS kits include...
AEM EMS for 02-04 WRX
AEM WideBand with or without 2 1/16" gauge display
5 Bar MAP Sensor
Intake Air Temp Sensor & Connector
GM Boost Control Solenoid & Connector
Tru-Boost Boost controller gauges
Brand new to the market is the AEM Boost Controller Gauge! This unit provides an excellent solution for increasing the boost on your turbocharged engine. Packaging the boost controller and the display simplifies the installation and everyday use. Tune your boost and read your current pressure levels with ease. Includes black faceplate and surround allowing the gauge to be customized to your interior. Also included is all of the necessary equipment to complete the install.
Features:
- Complete Stand-alone boost controller gauge.
- On-board pressure sensor included for boost levels up to 29 PSI (External 75 PSI sensor optional)
- Two users selectable boost settings.
- User selectable units.
- Peak boost memory.
- User selectable over boost alarm with overboost shutdown.
- User scaleable bar graph display.
- User selectable scramble boost setting with switched input.
- User selectable waste gate delay for quick turbo spool.
- External warning lamp driver.
- No external interface required for programming.
- Easy to install harness allows for quick and easy installation.
- Boost hose and fittings included for easy hookup to on-board pressure sensor.
AEM UEGO Widebands
OVER STOCKED!!! WE HAVE LOWEST PRICE ANYWHERE GUARANTEED!!!
NEW! Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
NEW! Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
NEW! Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
This is the newest wide-band from AEM. The controller for the wide-band is actually built right into the 52mm guage itself. Everything is plug and play. This unit is awesome.
AEM's wide-band UEGO includes all of the features found in their standard wideband unit. This includes a 0-5V output signal for feedback control to your ECU. AEM's gauge-type wideband UEGO controller features an LED readout and sweeping LED "needle" that changes colors as AFR changes from lean to rich. This standard size gauge fits in most gauge pods and can be remotely mounted virtually anywhere.
Features & Benefits:
1.) 24 Color-coded LED display lights provide immediate reference to engine's air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
2.) Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
3.) User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
4.) Ideal AFR monitoring tool for carbureted applications and engine dynamometers
5.) Does not oscillate AFR like narrow band sensors
6.) Serial data stream included for output of AFR (RS 232)
7.) Accurate to 0.1 AFR
8.) Bosch sensor included
AEM Digital Boost, Temperatute, and Pressure Gauges
AEM's digital Boost display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
AEM's digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels and black and white faceplates to personalize the look of your gauge it's like having four gauge designs in one!
Features:
- Includes easy-to-install harness and sensor
- Complete stand alone gauge requires no additional sensors or programs to operate
- Ideal for both fuel injected and carbureted motors
- LED displays provide precise reference to critical operating conditions and alert driver of potentially damaging operating conditions
- Includes 0-5V analog output for routing to engine management system or data logger
- Easy to read faceplates/displays are designed to complement existing AEM gauge styles
- Included bezels and face plates allow you to personalize the look of your gauge
HPF Eric
1 866 HPF 5600 X 111
[email protected]
www.horsepowerfreaks.com
HorsepowerFreaks is offline   Reply With Quote
Old 11-20-2006, 07:37 PM   #2
HorsepowerFreaks
Vendor
Member#: 57501
TiAL 44mm Gates 350 shipped!
TiAL 38mm Gates 230 shipped!
TiAL 50mm BOV's 215 shipped!
Precicion GT3071RLS (Ported shroud available) (PM FOR PRICING!!!!)
Precision GT3582RLS (Ported shroud available) (PM FOR PRICING!!!!)
Precision SC50-61 ON SALE!!!! 7xx Shipped!
GTQ and GTS chargers on sale!
STi Oil feed and return line kits! PM for information
Perrin products on SALE
Exedy Twin Discs!!!! I wont be undersold
ACT Disc and Pressure plate combo's...lowest prices around
Old 11-28-2006, 06:52 PM   #3
HorsepowerFreaks
Vendor
Member#: 57501
CP Pistons and Brian Crower rods!
Old 12-09-2006, 02:51 PM   #4
BREWPUBEAVER
Member Sales Rating: (67)
Member#: 84547
06, Lafawnduh
Fender rolling king
i need some rods.... pm with priceing, im local
BREWPUBEAVER is offline   Reply With Quote
Old 12-10-2006, 03:56 PM   #5
boostinscooby
Member Sales Rating: (17)
Member#: 91560
2012 STi Hatch
Do your Tial 50mm bov's come with the weld on flanges? And what spring comes with it. I believe I need a 7lb spring.
boostinscooby is offline   Reply With Quote
Old 12-10-2006, 06:14 PM   #6
Forced Induction PG
Member Sales Rating: (1)
Member#: 132369
can you pm me prices on aem gauges wideband on down.
Forced Induction PG is offline   Reply With Quote
Old 02-12-2007, 03:44 PM   #7
TurboDXsti
Member Sales Rating: (9)
Member#: 106671
2006 Sti
grey
bump for a gread deal on the wastegates
TurboDXsti is offline   Reply With Quote
Building Your Motor? This is your last stop! CP/Brian Crower/JE/Eagle + More! Look! RealStreet Engine/Power/Exhaust 21 06-02-2009 06:21 PM
CP Pistons / Eagle / Brian Crower / Wiseco / ARP / ACL / Fuel Systems...and MORE!!! Speed Clinic Engine/Power/Exhaust 44 02-10-2009 11:14 PM
Cobb,Perrin,Turbo XS,HELMETS,Gauges,Autometer,Defi,AEM,DC Sports,HKS,Crower, and MORE JBK Performance Engine/Power/Exhaust 20 08-09-2007 03:36 AM
Tons of stuff...AEM, Kartboy, Megan, Archos, Yamaha, Stock and more!!! oxxsti71 Private 'For Sale' Classifieds 11 01-24-2006 01:16 PM
