Old 04-29-2008, 10:42 AM   #251
whatthe
Member#: 178224
1992 Toyota Aristo
I don't mind that they can't be rebuilt as I haven't needed to rebuild a turbo on a project I've done in 10+ years. They will likely last many years and kilometers more than I will keep the car for when used in the proper range. I think Mitsubishi, Garret, and IHI are all quality options.
That said, If I could use the other options, I probably would be all over it. The ones you mention are extremely readily available, cost effective and rebuildable. IHIs on the other hand have piss replacement/aftermarket support and they are generally priced too high for new turbos in their range.
The main problem that I have is that this isn't going on a Subaru, and IHI compressors seem to be able to make the highest pressure ratio at the lowest flow compared to any of the maps I've seen by Garrett or Mitsubishi (2.2-2.6 range at low flows). If you can find me something that matches RHF55 for high boost at low flow without hitting the surge line, I would love to see it.
whatthe is offline   Reply With Quote
Old 05-01-2008, 12:57 AM   #252
wrxgeneration
Member#: 170790
2006 wrx cobb stg. 2
cgm
great info, it deffinately helped me out
wrxgeneration is offline   Reply With Quote
Old 05-03-2008, 11:51 PM   #253
Powertec
Member#: 177539
Excelente info, but VF series are the same WBhp :S
Powertec is offline   Reply With Quote
Old 05-04-2008, 09:33 AM   #254
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Originally Posted by keirnna View Post
Skip the IHI Turbos. They are use once and throw away. I would never buy one for an upgrade as they cannot be serviced or rebuilt 99% of the time as IHI doesn't sell rebuild kits or parts. Stick with a Mitsubishi hybrid turbo like the 16/18/20G and FP Green / Anything from Deadbolt. Those turbos are fully rebuildable for very cheap.
Then why is deadbolt rebuilding IHI turbos?
So it is your opinion that a the vf22 and vf23 put out the same hp?
chrisarella is offline   Reply With Quote
Old 05-04-2008, 09:55 AM   #255
keirnna
Member#: 50167
1996 Subaru STI RA
Quit being difficult. Deadbolt can rebuild a few IHI turbos, but the VF22 for sure is not rebuildable.
keirnna is offline   Reply With Quote
Old 05-04-2008, 10:51 AM   #256
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Ok, 1st, thanks for changing you comment from stupid to difficult.
Secondly, I was refuting you statement about them not being rebuildable.
3rd, I never said the vf22 was rebuildable. You're twisting two totally different statement to prove your point.
While I agree there is way more support out there for Mitsubishi turbos than there is for IHI you cannot say there aren't any kits available to rebuild IHI turbos. It just isn't true.
As far as me being difficult is concerned, is everyone supposed to lay down and take everything someone says on a forum as fact and not question or argue other people's statements?
Old 05-04-2008, 05:24 PM   #257
keirnna
Member#: 50167
1996 Subaru STI RA
So what IHI turbos are rebuildable?
Old 05-06-2008, 09:29 PM   #258
litowrx
Member#: 132418
2004 EJ207
hey guys, i would like to know what turbo is featured in the v8 EDM impreza STi EJ207??
also what turbo would you use in a ej207, im what very good spool up time
litowrx is offline   Reply With Quote
Old 05-06-2008, 09:37 PM   #259
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I don't know other than my vf37 and vf36. If you seriously want to know, ask deadbolt.
I know the jdm sti had the vf37 on that motor. Other turbos that Subaru has mated to it successfully are the vf36, vf30, and vf34. a 16g would also be a good match for more power and good spool. Of coarse, the bigger you go the more lag. Going the twin scroll or ball bearing turbos minimizes the lag.
Old 05-10-2008, 08:30 PM   #260
jayjaysti
Member#: 167582
so is the VF22 similar to a big 16g
jayjaysti is offline   Reply With Quote
Old 05-10-2008, 08:40 PM   #261
keirnna
Member#: 50167
1996 Subaru STI RA
I think the TD05-16G (small 16g) outflows the 22 by a bit, but I could be wrong.
Old 05-10-2008, 08:42 PM   #262
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Not quite, more like the Small16G. The Big16G is a chunk bigger. And it spools faster
Audiosavvy is offline   Reply With Quote
Old 05-10-2008, 09:48 PM   #263
jayjaysti
Member#: 167582
so this will be like an evo 9 turbo right?
Old 05-11-2008, 12:07 AM   #264
Audiosavvy
Member#: 150794
Qcab dakota 4x4
The VF22- NO. The Big16/EVOIII16- yes, but you're not expecting similar performance are you? If so, you will be very disappointed, because the Evo can run 11s on that turbo on pump gas, while only a handful of ninjas have done it with a Subaru.
Old 05-11-2008, 12:14 AM   #265
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Their is so many turbos missing from that list .
ASU is offline   Reply With Quote
Old 05-11-2008, 12:24 AM   #266
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Originally Posted by ASU View Post
There are so many turbos missing from that list .
Old 05-11-2008, 11:15 PM   #267
litowrx
Member#: 132418
2004 EJ207
kinda off topic but are EVO turbos bolt on for STi's???
i think the evo 8 turbo is a td05 18g right?? whats the stock turbo on the 9??
Old 05-11-2008, 11:38 PM   #268
Audiosavvy
Member#: 150794
Qcab dakota 4x4
No
EVO9 runs a 16g
Old 05-11-2008, 11:58 PM   #269
litowrx
Member#: 132418
2004 EJ207
Originally Posted by Audiosavvy View Post
No
EVO9 runs a 16g
so the 9 runs on a 16g, what does the 8 runs???
Old 05-12-2008, 12:02 AM   #270
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I'm not entirely sure, that's why I didn't answer. Sorry. Have you tried that fancy search button yet? I bet the answer is there somewhere
Old 05-13-2008, 01:10 AM   #271
byanychance
Member#: 179885
Wow, I basically read this whole thread (too much time on my hands). But it was informative nonetheless.
byanychance is offline   Reply With Quote
Old 05-29-2008, 12:20 PM   #272
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Hi all. Here is an update for the AVO turbo list in post 5...
AVO 500
(55lb/min, Bolt-On)
The AVO550 ball bearing Edge Series turbocharger is the ultimate in high-flow/high-response bolt-on solutions for your WRX or STi 2.0-liter and 2.5-liter. Capable of up to 30psi of boost and able to hit peak boost at 4700rpm on a 2.5-liter, it has all the response and overhead that you can dream of. This our 1/4 mile beast, designed for a blend of high response and devastating power. The absolute best bang for your buck thanks to an enormous research and development program. We would even go so far as suggesting that the Edge range of turbochargers will outperform any other comparable turbo on the market.
Supplied world-wide for street and race applications, you won't find a turbocharger offering better performance.
Purchase $2150
I'm not sure of the cfm conversion or the max power but I'm guessing 550 means 550hp at the crank and 410-440whp.
Note, the pricing has changed and dropped for the full line on their website:
AVO380: $1,799.00
AVO420: $1,850.00
AVO450: $1,950.00
AVO500: $1,970.00
AVO550: $2,150.00
All current turbos are here:
http://www.avoturboworld.com/avoshop...ath=1_22_29_67
And soon there will be twin scroll turbos added to the lineup which will all use the same compressor housings from their other turbos but will have the newly designed twin entry exhaust housings mated to them for twin scroll set-ups. Those are still in production and will be tested shortly before getting released to the public. Stay tuned for the details.
Old 05-30-2008, 12:29 AM   #273
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks chrisarella!
WRXRallyBlue is offline   Reply With Quote
Old 07-09-2008, 01:13 AM   #274
silverongold
Member#: 132599
02 impreza wrx
Default vf 36
who wants to sell me a vf 36 or recomend another turbo that would hold up to rally style anti lag as well?
silverongold is offline   Reply With Quote
Old 07-09-2008, 01:30 AM   #275
JDMraR
Member#: 183999
very good info!
does anyone know whats the difference between the pe1825 and zerosports ar25 turbos?
thanks.
JDMraR is offline   Reply With Quote
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
