#276 |
Member#: 61322
NWIC
Vehicle:2004 Forester XT |
#277 |
Member#: 145069
W. Canada
Vehicle:Keep It Sleazy |
that is ridiculous!
It used to beee. This info is major. |
#278 |
Member#: 159454
SWIC
Vehicle:2006 WRX CGM 6SPD Cornfed GT30R |
#279 |
Member#: 106306
South East
Vehicle:2003 WRX yellow |
wow that was like the answer to life right there! that has anything and everything you could ever ask about turbos!
#280 |
Member#: 49979
Vehicle:11 dgm wrx hatch 08 black TA STI |
Needs an update for the 2008 STI turbo and soon, once we know the specs, the 2009 WRX turbo, which subaru says will be different from the <'09 cars.
2008 STI: vf48: 250-325 hp. This appears to be an update to the vf43. It has a P18 exhaust housing and a slightly smaller compressor housing. The spool-up may be slightly faster than a vf43. Frank |
#281 |
Member#: 114530
NESIC
Vehicle:2005 LGT 6MT wagon |
#282 |
Member#: 35584
South East
Vehicle:1965 FFR Roadster Coyote + TR-6060 |
Nice to see more twin scroll options from IHI
#283 |
Member#: 145069
W. Canada
Please sticky WRXRallyBlue's turbo list!
Thats a lot of work and its gonna get lost. |
#284 | |
Member#: 35584
South East
As far as I know the Zero/Sport A/R25 was a PE 1825f sourced directly from Power Enterprises. Z/S may have upgraded the actuator and/or ported it but not much else if anything. And good luck finding either of them... EDO is their North American distributor and they tell me no more to be had in the world. I even had a buddy in Japan scouring the aftermarket shops in Tokyo and nothing. If anyone finds any LMK... willing to good money for one. |
#285 |
Member#: 184768
SCIC
Vehicle:05 WRX toasted white |
nice write up help clear alot of questions only onem ajor question is between a 16g and an 18g and WHAT company to go with there are good and bad reviews on all companies i jsut need a reliable good turbo for a 05 WRX
#286 |
Member#: 49979
How about ATP? Their hybrids seem to spool at least as fast or faster than the other Garrett-based ones...
Frank |
#287 |
Member#: 186795
Vehicle:2002 WRX Blue |
Thank you for the info
#288 |
Member#: 174346
Thanks for this list!
#289 |
Member#: 31519
Vehicle:2009 Legacy spec.B 2001 2.5RS Coupe |
This could use some update love for the new IHI turbos.
#290 |
Member#: 160690
SCIC
Vehicle:2004 sti wr blue pearl |
very useful....i was unsure wat turbo i was gonna go wit but i think im gonna go wit the gt30r after reading up
#291 |
Member#: 190077
Vehicle:2006 Subaru LGT BP OBP |
Any news on what a VF47 is? (yet another VF38 replacement?)
#292 |
Member#: 194539
Nice thread!
#293 |
Member#: 194623
BAIC
Vehicle:2002 WRX Sedan PSM |
Hey all, newbie to the site, nice thread
#294 |
Member#: 195826
International
Vehicle:2001 JDM STI V7 WRX, White |
VF series turbos are rebuildable as long as the shaft and exhaust turbine are still intack and not bent which is contrary to what everyone says. I have a hybrid VF36 it runs a P20 exhaust housing from a VF22 to convert back to single scroll to fit my headers that has been honed out and hi flowded, the up pipe side of the turbine housing is now the same size as the factory gasket (52mm i think) it has a back cut turbine a evoIII big 16G compressor wheel nissan pulsar GTiR wastegate actuator (12 pound factory spring rate) brass bearing casings inside the roller bearing cartridge instead of polyamide to stop the center bearing failure that all VF turbos are prone to and so i don't have to run it water cooled. At 18psi on a factory version 7 engine STD pink sti injectors and a reflash this setup makes more than 235kw at the wheels (320whp) all the way to 8250 rev cut, it comes on full boost around 2600rpm and i reckon with a set of injectors and a retune i could squeeze another 5psi out of it safely. I got this done extremely cheap way cheaper than any new turbo of equivalent size and spool, food for thought.
#295 |
Member#: 183529
Vehicle:i wanna help teh haters ... love life ... |
BY FAR.... the best write up EVARRR!!!
#296 |
Member#: 199013
Vehicle:2002 Impreza WRX white |
Thanks!! This gives me some different options to look at now!
#297 |
Member#: 199526
Vehicle:2007 UGM WRX TR stg II vf39'd |
Definetly some great info. When the time comes, it will be green
all the way!! Puff Puff Pass anyone??![]() |
#298 |
Trust me, I'm a scientist
Moderator Member#: 150794
SCIC
Vehicle:Qcab dakota 4x4 LT1 Formula Firebird |
#299 |
Member#: 193041
RMIC
Vehicle:74 Pacer poo brown |
Some of the flow rates don't seem to match with the hp ratings. The SBR GT-12 is rated at 55 lb/min but only makes about as much power as a 20G rated at 44 lb/min? Maybe SBR just makes really inefficient turbos or perhaps the numbers need to be looked into a little more.
#300 | |
Member#: 57861
Vehicle:2007 LGT OBP, 04 STi (traded) |
Check some of the threads on here about the SBR turbos...not living up to their hype in many cases. Sorry for the OT. |
| Thread Tools | |
| Display Modes | |
| Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever | pepperjack | News & Rumors | 63 | 08-22-2010 06:19 AM |
| is there a Subaru turbo list? | housedj | General Community | 8 | 03-18-2009 12:48 PM |
| subaru forum list | 949 | General Community | 10 | 11-01-2005 11:32 PM |
| Subaru wish list | carrera | News & Rumors | 9 | 06-19-2002 08:45 PM |
| ('93-'01) Subaru Mailing List | rubadub | Impreza Forum | 3 | 08-18-2001 02:40 PM |
