Old 05-18-2009, 04:57 PM   #326
jlotz19
Member#: 211697
So much help!
jlotz19 is offline   Reply With Quote
Old 05-26-2009, 04:50 PM   #327
foresterbej
Member#: 212303
2009 forester
gray
anyone can tell what kind of turbo is used on the 09 forester with manual transmission?
foresterbej is offline   Reply With Quote
Old 05-27-2009, 11:40 PM   #328
kirbwrx
Member#: 110450
2007 Spec.b Refugee
284hp 320tq Cobb Tuned
you are lucky you get a manual forrester with a turbo.
what turbo is on the legacy s402? i know its a twinscroll and thats it.
kirbwrx is offline   Reply With Quote
Old 05-29-2009, 12:09 PM   #329
1993Jade
Member#: 206856
1993 Impreza AWD
Scion Green
Originally Posted by jmhubbard01 View Post
^ did you read teh beginning of this thread?
haha oops multiple links and multiple replies, my bad, only read the first post.
1993Jade is offline   Reply With Quote
Old 06-02-2009, 10:57 PM   #330
All4BeSpinnin
Member#: 210456
2006 WRX
OBP - How Low Can He Go??
what turbo is stock for the 06 wrx??? and how much do people usually sell them used on average?? about 30k miles, no cracks, no damage...
edit: just read its the td04... correct
All4BeSpinnin is offline   Reply With Quote
Old 06-03-2009, 12:34 AM   #331
candyman
Member#: 23365
2006 WRX Tuned Stg 2
WRB w/Whiteline G4's
All4BeSpinnin,
Why are you looking to sell yours?
candyman is offline   Reply With Quote
Old 06-03-2009, 03:40 PM   #332
All4BeSpinnin
Member#: 210456
2006 WRX
Originally Posted by candyman View Post
All4BeSpinnin,
well... i was looking to do the vf39 or vf43 turbo swap, walbro fp, injectors (even tho i know the 06 wrx injectors should be fine), intake, etc etc. and just do the swap..
so i was wondering once i do the swap how much the stock wrx 06 turbo is worth and all that
EDIT: with the swap, looking to get around 300 or so to the wheels, and after researching these turbos that fits my budget/goals without blowing up the tranny/engine (lol) i think ill go with either the 39 or 43...
Old 06-03-2009, 03:52 PM   #333
unclemat
Member#: 114530
2005 LGT 6MT wagon
Is the OP maintaining this?
Some info about JDM Legacy turbos:
IHI VF38 - turbo on automatic LGT Rev.A - Rev. C (MY04-MY06), rated 260 chp stock, twinscroll, ball bearing and titanium turbine wheel
Mitsu TD04HLA - turbo on manual LGT Rev.A - Rev.C (MY04-MY06), rated 280 chp stock, twinscroll, notably larger turbine and turbine housing than VF38, not sure if ball or journal bearing, probably the latter
IHI VF44 - turbo on all manual/auto LGT Rev.D - Rev. F (MY07-MY09), twinscroll, journal bearing I believe
unclemat is offline   Reply With Quote
Old 06-03-2009, 04:01 PM   #334
kirbwrx
Member#: 110450
2007 Spec.b Refugee
yey unclemat...do you know if IHI has some sort of site that has the flow rates and the like for all their turbos? what does chp stand for?
Old 06-03-2009, 04:06 PM   #335
unclemat
Member#: 114530
2005 LGT 6MT wagon
chp = crank horse power... IHI is secretive about their OEM stuff it seems
Old 06-03-2009, 04:38 PM   #336
kirbwrx
Member#: 110450
2007 Spec.b Refugee
thats what i am noticing, cannot find their info anywhere. what about the vf44/45 and 47? know anything about those?
Old 06-05-2009, 03:44 PM   #337
im2ninja4u
Member#: 183389
No info for the Dom 4?
im2ninja4u is offline   Reply With Quote
Old 06-14-2009, 11:42 PM   #338
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
When our you going to add Borg Warner turbos?
ASU is offline   Reply With Quote
Old 06-16-2009, 10:31 AM   #339
cowdilly
Member#: 199817
2006 WRX STi
WR Blue
Default Thanks for the help
Thanks everyone for your help. Great website.
cowdilly is offline   Reply With Quote
Old 06-16-2009, 10:31 AM   #340
cowdilly
Member#: 199817
2006 WRX STi
WR Blue
Default Thanks
Thanks for the help.
Old 06-19-2009, 09:59 AM   #341
shatteringstar
Member#: 149604
2006 Limited WRX
this thread needs an update. i was looking for VF48 info...?
shatteringstar is offline   Reply With Quote
Old 06-21-2009, 04:04 PM   #342
XFD
Member#: 170601
I'd like to find a drop-in turbo upgrade to get ~310 brake HP without any modifications to my existing setup; a true "bolt-on." From the original post, there are a number of different turbos which list a wide range of possible powers (obviously given a particular setup), but do any of these have the ability to literally be dropped in for a nice smooth 300-310 WHP without any major changes? If not, what turbo would have the least number of changes to hit that power point?
XFD is offline   Reply With Quote
Old 06-21-2009, 04:30 PM   #343
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I think the OPs have already answered that question. Your STI fueling and TMIC will support that goal, and simply tuning your vf39 can get you close if you get a netter flowing exhaust and intake. So a slightly larger turbo like a 18g or equivilant will get you there for a small budget.
EDIT: all performance numbers are dependent upon each dyno's particular design and correction settings.
chrisarella is offline   Reply With Quote
Old 06-21-2009, 04:36 PM   #344
ASU
Member#: 164551
2006 Brotastic STi
This is old info half of these turbos our not even being used anymore and cant be found and there is at least 10 turbo that our being used not even mentioned
Old 06-21-2009, 04:54 PM   #345
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
So stop complaining, step up, and post info that fills in the holes. If you're not part of the solution you are part of the problem.
Old 06-21-2009, 04:59 PM   #346
XmikeX
Member#: 184768
05 WRX
toasted white
any reviews or info on FP HTA 68 would be awesome
thanks guys
mike
XmikeX is offline   Reply With Quote
Old 06-21-2009, 05:42 PM   #347
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
For those asking about which turbo should I go with, as a very general rule, turbocharged gasoline engines will generate 9.5-10.5 horsepower (as measured at the flywheel) for each lb/min of airflow. So, an engine with a target peak horsepower of 400 HP will require 36-44 lb/min of airflow to achieve that target. This is just a rough first approximation to help narrow the turbo selection options, but should get you in the ballpark.
Here is a great PDF with a plethora of information that helps with turbo selections:
http://www.turbobygarrett.com/turbob...007Catalog.pdf
Garrett's site has enough technical info about turbos to give you a headache.
Old 06-22-2009, 12:28 AM   #348
XFD
Member#: 170601
Thanks for your response, the 18g has been superceeded but that's fine. Do you know if these are literally bolt in swaps though? On my track car I upgraded it's turbo from a Garrett T25 to a GT2871R; listed on Garrett's site as a 100% direct bolt-on replacement, the only thing that swapped over was the bolt pattern to the exhaust manifold.
That was a largely painful experience I'd rather not go through again, hence why I put so much stress on not screwing with anything else. Old turbo off, scrub the leftover gasket material off if it sticks, new gaskets on, new turbo on. Startup and drive away.
Old 06-22-2009, 12:50 PM   #349
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
thanks guys
mike
The Proven Power forum has a number of threads about the HTA68 right now, check it out
Audiosavvy is offline   Reply With Quote
Old 06-24-2009, 06:08 PM   #350
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Yeah, the garrett turbos are typically a rotated setup, but ATP makes straight bolt on versions, which I highly recommend. I should mention that upgrading your turbo means you will need to do a tune, so it isn't as simple as install and go, but you probably already know that. You may also need to upgrade your injectors if you start pushing the stockers beyond 80% duty. The stock injectors may get you there but 650cc should be a safe bet for your goal.
BTW, you could go with a bolt-on GT2871R from ATP:
http://www.atpturbo.com/Merchant2/me...egory_Code=SUB
Or go a little bigger with their GT3071R:
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
