Old 06-28-2009, 06:29 AM   #351
XFD
Member#: 170601
Thanks for the info. I'm going to opt out of trying to go anywhere with the car; it seems to be at its limit already. I was hoping for something simple like a turbo swap with a modest increase in flow then call it a day.
XFD is offline   Reply With Quote
Old 06-30-2009, 01:32 PM   #352
dlinares90
Member#: 215701
2008 Impreza 2.5i
Metallic Silver
I have been meaning to buy a turbo for my low grade impreza lol, but it just seems so expensive. And it's good if you know someone that can install it for you.
dlinares90 is offline   Reply With Quote
Old 07-01-2009, 07:41 PM   #353
allday789
Member#: 95511
2005 WRX
Someone needs to find some info about the HTA68 on a EJ205. Sounds like a solid turbo.
allday789 is offline   Reply With Quote
Old 07-02-2009, 11:40 PM   #354
dieselsmoke
Member#: 215986
awesome break down
dieselsmoke is offline   Reply With Quote
Old 07-02-2009, 11:41 PM   #355
dieselsmoke
Member#: 215986
is this list updated as turbos are developed.....?
Old 07-02-2009, 11:41 PM   #356
dieselsmoke
Member#: 215986
or is this just a list of the "norm" out there
Old 07-08-2009, 09:05 PM   #357
GDB FAN
Member#: 105814
You should update with info on the VF52.
Lots of questions on swaps.
GDB FAN is offline   Reply With Quote
Old 07-27-2009, 12:10 PM   #358
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
It says the Dominator 3.0R spools faster than the IHI VF39. But the numbers don't look like they agree. Is the VF39 slower or is the Dom 3.0R faster? Or am I missing a factor all together?
HeMan1320 is offline   Reply With Quote
Old 07-31-2009, 12:46 PM   #359
bzwrx07
Member#: 160236
2007 WRX TR
WR Blue
Thank-you for this impressive list dude, awesome job!
I have been doing research on a turbo swap in my 2007 WRX. I am taking the cheap route for now: used VF39 and the Cobb Stage 2.5/3 OTS map. Nice thing about this is I bought all of the parts for the swap (intercooler, gaskets, vacuum lines, etc) for the cost of a brand new VF39.
I plan on taking plenty of pictures and try to do my own write up on the install.
Thanks again for the post!
bzwrx07 is offline   Reply With Quote
Old 08-12-2009, 05:38 PM   #360
weestar310
Member#: 220113
2007 Impreza WRX STI
very good information!! thanks for the info it will come in handy
weestar310 is offline   Reply With Quote
Old 08-21-2009, 11:43 PM   #361
Subyrex03
Member#: 221198
2003 WRX sedan
Default Hks Gt2835?
I already have a HKS GT2835, modified wrx injectors, BDL industries fuel rails, Walbro 255 pump, AEM short ram catless up pipe, Invidia V3 catless down pipe, a SPT Bosal catback, GFB Hybrid BOV, Perrin Lightened crank pulley, oversized TMIC and a Turbo XS unichip stage 2. I've been slowly gathering things up to put it all together at one time. The other things that I lack still are a FMIC, A/F meter and a water/methanol kit. I'm trying to figure out if the Stage 2 that is on there now is doing any good for the options that I have on it now. I know that when I install the rest it will have to be tuned and I was probably going to go with the Cobb AP for that. Any ideas? Iknow that i'm new to this site, but i've had the car for over 5 years and nobody touches it but me. I have a pretty good idea how things work on it, but I need a little help.
Subyrex03 is offline   Reply With Quote
Old 08-23-2009, 01:23 AM   #362
R--I-D-D-L-E--R
Member#: 221187
2003 Dodge SRT-4
Yellow
One of the best threads on the whole site, great job.
R--I-D-D-L-E--R is offline   Reply With Quote
Old 08-26-2009, 06:18 PM   #363
PDC05WRX
Member#: 221108
2005 WRX
Great post thanks
PDC05WRX is offline   Reply With Quote
Old 09-08-2009, 02:10 AM   #364
howweirdo
Member#: 186257
2015 WRX Premium
CBS
yeup.
howweirdo is offline   Reply With Quote
Old 09-08-2009, 02:18 AM   #365
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
Very awesome thread, subscribed.
ramair18954 is offline   Reply With Quote
Old 09-17-2009, 06:49 PM   #366
stoke
Member#: 164513
2001 2.5RS+EJ20+VF34
'13 WRX Special Ed
Bump for VF48 info. Anyone know where to find some?
stoke is offline   Reply With Quote
Old 09-17-2009, 08:31 PM   #367
PDC05WRX
Member#: 221108
2005 WRX
i am definitley printing this one out! thanks!
Old 09-19-2009, 04:28 AM   #368
Smokin' Joe
Member#: 219679
2011 Impreza WRX
I have only found some general information on the VF52,eventhough I looked everywhere for specs on these things. I have an '09 WRX and with the Omori boost gauge I see it come close to tapping 15. Right up in 14+ for peaks and steady at 13 at higher RPM's. Was told max boost is 28PSI, but that's not factual or proven so dude just guestimated I believe. Some excellent info on here for sure! I just wonder what I can do with what I have at the moment. Any info or links would be greatly appreciated!
Smokin' Joe is offline   Reply With Quote
Old 09-21-2009, 11:02 PM   #369
rexblake
Member#: 178426
2010 S4
Gray
I'm trying to figure out the conversion factor for changing cfm into lbs/min and lbs/min into cfm. Doing a good search I get several different answers, from .0807 to .069, which is supposedly what Turbonetics use for their conversion factor. With that said, trying to do that with the information on this list, the conversion factor is all over the place; anywhere from .065 to .078. So, what's the correct conversion factor? Does every manufacturer use a different one?
rexblake is offline   Reply With Quote
Old 09-23-2009, 05:48 AM   #370
extreme-eg
Member#: 221744
I have always used 0.07 as the factor which is close to the 0.069 you stated ! IIRC Maximum Boost and another Technical How-To book both used 0.07 !
Maybe someone on here has the actual scientific conversion...??
extreme-eg is offline   Reply With Quote
Old 09-26-2009, 09:23 PM   #371
stck4evr
Member#: 201873
2009 Impreza WRX
Smokin' Joe - you are right, 15 or so is what I'm getting on my 2009 wrx. Did not want to bother installing any guages yet, so for now I just hooked up a openecu.org tactrix cable with romraider software to the ECU of my 2009 Subaru WRX. I get a peak boost of around 15.5psi (relative), with the computer "target" boost" of 13.34 or so. I read in an old article that the 2009 was designed for 13.3 psi boost (http://www.edmunds.com/insideline/do...ticleId=130748).
stck4evr is offline   Reply With Quote
Old 09-27-2009, 10:39 PM   #372
Smokin' Joe
Member#: 219679
2011 Impreza WRX
Good to hear Stck4evr, I installed the boost gauge and it's a nice thing to have. I'm still not having any luck with finding the specs on the VF 52 turbo though. IHI is pretty secretive of the stats I guess... I still don't want to push it too hard for ridiculous premature wear and tear. I'll update if I ever find a good link to the specs on this turbo. Thanks.
Old 09-27-2009, 11:39 PM   #373
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
What can you guys tell me about the td06 18G? I foud lots o info on the td05, but close to nothing on td06...
Not planing to buy that turbo right now, but I'm researching for my turbo upgrade next year.
Car: 06 WRX
Power goal: 300WHP average reading dyno
Ferraz is offline   Reply With Quote
Old 10-23-2009, 12:59 PM   #374
coopermack
Member#: 215321
Default Turbo on an Impreza
Would it be worth my time and money to put a turbo on my 06 5MT Impreza??
What would be some good mods i can do it??
coopermack is offline   Reply With Quote
Old 10-27-2009, 11:52 AM   #375
ej20_allday
Member#: 208856
2005 Impreza WRX
seriously!, vf48 info needed
ej20_allday is offline   Reply With Quote
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
