Old 09-19-2011, 05:39 PM   #501
bugeye sti
Member#: 186691
2011 sti
Originally Posted by badcopnodonut504
What's a good turbo for my 09 wrx wagon. Supporting mods are, Perrin elh, up pipe, down pipe, 3" straight back exhaust, Perrin cai, Perrin turbo inlet hose, Perrin tmic, Perrin ebcs, Perrin lightened crank pulley, deatchwerks 1000cc injectors, aeromotive fpr, walboro 255 fuel pump, boost gauge, aeromotive wide band w/ gauge, and Cobb accessport. I'm trying to go for 400 ish whp and thought about the amr cxr500. Would that be good or is there a better one for my current set up. Im goin to eventually replace short block, beef up the tranny and get a better clutch.
Staying with the LGT style turbo and Top mount is going to hold you back from hitting those numbers. Correct me if I'm wrong but I don't think there's a large enough turbo (LGT style) to hit those numbers.
bugeye sti is offline   Reply With Quote
Old 09-19-2011, 06:14 PM   #502
Disaster646
Member#: 135382
02 6spd hybrid wrx
fpgreen+E85 ftw [email protected]
A 20g is capable of 400whp on e85 easily, but if you have a 09 wrx then you should get rid of that perrin tmic and go fmic so you can fit a (02-07 wrx/04-11) sti location turbo, unless they have bigger sized turbos for your intercooler, a 20g xtr,fp green hta, dom3 etc.. are perfect for 400whp
Disaster646 is offline   Reply With Quote
Old 09-19-2011, 09:06 PM   #503
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
Originally Posted by Disaster646 View Post
A 20g is capable of 400whp on e85 easily, but if you have a 09 wrx then you should get rid of that perrin tmic and go fmic so you can fit a (02-07 wrx/04-11) sti location turbo, unless they have bigger sized turbos for your intercooler, a 20g xtr, fp green hta, dom3 etc.. are perfect for 400whp
Does a 20gxtr not fit a TMIC?
QwaktastiK is offline   Reply With Quote
Old 09-19-2011, 10:06 PM   #504
rexblake
Member#: 178426
2010 S4
Gray
I think the 08+wrx has a different turbo fitment than the earlier models.
rexblake is offline   Reply With Quote
Old 09-19-2011, 10:36 PM   #505
bugeye sti
Member#: 186691
2011 sti
The 20gxtr is an sti style turbo. It will not fit 08+ wrx with a top mount. You would have to get a fmic.
Old 09-19-2011, 10:38 PM   #506
badcopnodonut504
Member#: 271661
2002 WRX Sedan
Cool man thanks. I knew the TMIC would hold me back some. Would any of those fit on the TMIC until I was to get a FMIC?
badcopnodonut504 is offline   Reply With Quote
Old 09-19-2011, 10:45 PM   #507
Disaster646
Member#: 135382
02 6spd hybrid wrx
A 20g xtr does fit a 02-07 wrx or 04-11sti tmic but it won't fit a 08-11 wrx tmic since they are different, if you add this turbo then you need a fmic or some kind of custom tmic, which I havent seen one yet
Old 09-19-2011, 10:50 PM   #508
Disaster646
Member#: 135382
02 6spd hybrid wrx
Nope they won't fit, and I'm not familiar with other turbos like the vf52, but you can do a search of what could fit a 08-11 wrx and keep your perrin tmic
Old 09-19-2011, 11:04 PM   #509
bugeye sti
Member#: 186691
2011 sti
I believe that fast motorsports makes a top mount that you can get a Hose for that allows you to run a sti style turbo without swapping intake manifolds. They also have a fmic that comes with 2 sets of pipes to fit sti or wrx turbos. It's a txs copy.
Old 10-25-2011, 05:54 PM   #510
sonikwrx
Member#: 275967
2003 wrx
sonic yellow
oh my goodness sakes the list never stops
sonikwrx is offline   Reply With Quote
Old 10-25-2011, 10:53 PM   #511
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
just for search reference, there are quite a few guys putting down power in the 400whp range with the new BNR68 turbos which are legacy gt style turbos
amalgrover is offline   Reply With Quote
Old 10-26-2011, 09:49 AM   #512
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
^I've found the solution for running an aftermarket TMIC with the 20gxtr or any other aftermarket LGT style turbo on an 08+ WRX.
Process West and FMS both make an intercooler hose to make these turbo compatible with said TMICs. RallySport sells the PW hose while IIR sells the FMS hose.
Old 12-14-2011, 03:10 PM   #513
mofoSTI
Member#: 236252
08 STi
Best thread ever. Thank you
mofoSTI is offline   Reply With Quote
Old 12-21-2011, 04:06 AM   #514
watson199
Member#: 215042
2006 wrx
So I bought a 06 wrx and I asked for a list of everything that's been done and one thing confuses me, he said it has a vf53 from a 08 sti and according to this thread it should be a vf48. Is there anyway to find out what I have without taking the turbo off the car?
watson199 is offline   Reply With Quote
Old 12-21-2011, 05:59 AM   #515
subieguy87
Member#: 153412
1998 Impreza wrxRS
Open ur hood, READ ur turbo
subieguy87 is offline   Reply With Quote
Old 12-21-2011, 09:02 AM   #516
amalgrover
Member#: 183480
2009 Forester XT
^ what he said...the VF's should have a label plate on the front of them that will have what turbo it is right on it.
Old 12-21-2011, 09:19 AM   #517
watson199
Member#: 215042
2006 wrx
Thanks!
Old 01-09-2012, 06:53 PM   #518
tejack47
Member#: 306384
Default Vf38
Hey anyone know if the VF38 Turbo can be swapped out for other models?
tejack47 is offline   Reply With Quote
Old 01-14-2012, 12:28 PM   #519
charlesholmes33
Member#: 221592
2011 V6 RAV4 Sport
Metallic Gray
Amazing thread and resource. To the OP
IHI VF56
Very similar to the VF42 model in terms of spool and capacity, the VF56 is a roller-bearing turbo and is similar in size to the VF42 turbo, but the twin-scroll exhaust housing is even a little larger still and yields faster spool-up and a superior top-end. The VF56 can be found on the R205 and the S206
FYI: The VF42 is also the turbo they used on the Legacy S402.
Again great thread and resource. Thanks for all of your efforts.
charlesholmes33 is offline   Reply With Quote
Old 01-15-2012, 06:43 PM   #520
WookyMonster
Member#: 306148
Is this turbo on my baja a TD04L 13t? It has gone and I want to upgrade. I see TD04HL 19ts all over ebay but it says Saab. The "HL" is specific to Saab then? I've found plenty of TD05H 20gs on ebay for relatively cheap as well. Would this be a decent upgrade and be able to get me to say 300chp or preferably 300whp?
WookyMonster is offline   Reply With Quote
Old 01-23-2012, 04:58 PM   #521
Ryan_CNU77
Member#: 307730
2004 STI
I have an 04 STI and I only wanted a turbo swap not for power gain but for overall quality. VF43 is the stock STI turbo for i think the 2008+. It worked wonders! Loved it, added a little power and its overall better made! I recommend it!
Ryan_CNU77 is offline   Reply With Quote
Old 01-23-2012, 05:29 PM   #522
bad mutha
Member#: 106747
04 forester xt
crp
^^^ vf43 is from the 07 sti,08+sti's have a vf48.
bad mutha is offline   Reply With Quote
Old 01-25-2012, 09:22 PM   #523
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Okay.
VF8 is found on JDM Legacy RS 1989-1993
VF10 is found on JDM Legacy GT 1989-1993
VF11 is found on all USDM legacy turbo 1990-1994
VF12 is found on AUDM Legacy GT/RS 1989-1993
i_c_the_light is offline   Reply With Quote
Old 02-07-2012, 06:32 PM   #524
02Evoslayer
Member#: 309349
thanks for the info
02Evoslayer is offline   Reply With Quote
Old 02-18-2012, 11:13 PM   #525
bmcpheeloyzelle
Member#: 310729
I have a turbo
bmcpheeloyzelle is offline   Reply With Quote
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
